    MMM-MyScoreboard
    277 Posts 60 Posters 641.8k Views 63 Watching
    • W
      Wenike @sifuhall
      @sifuhall You won’t get anything until the UK football team has a game, which won’t be for a few weeks. Until then, this module displays nothing.
      sifuhallS 1 Reply Last reply Reply Quote 0
      • sifuhallS
        sifuhall @Wenike
        @wenike Thank you for the reply. But I’m saying the entire screen is blank. Not just the scores section.
        W S 2 Replies Last reply Reply Quote 0
        • W
          Wenike @sifuhall
          @sifuhall So, other modules aren’t showing either?
            sdetweil @sifuhall
            @sifuhall this sounds like the the missing libraries problem. when the screen is blank, can u show the message at mm startup?
            if using pm2, use
            pm2 logs --lines=100
            • sifuhallS
              sifuhall @sdetweil
              Yes, this was it exactly. Once I added the request module everything was fine.
              However, I do have one question.
              How can I add the West Ham United Football Club?
              • BKeyportB
                BKeyport Module Developer @sifuhall
                @sifuhall it looks like it’s not supported based on the code.
                • sifuhallS
                  sifuhall @BKeyport
                  @bkeyport Thank you for the reply
                  • E
                    Egnos
                    Hello everybody,
                    I’m having trouble with this module, are any of you using it?
                    The following errors MM returns me:
                    [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] 2-Sep-22 10:52 ** ERROR ** Couldn't retrieve ITA_SERIE_A data for provider ESPN: Error: getaddrinfo ENOTFOUND site.api.espn.com
                    [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] http://site.api.espn.com/apis/site/v2/sports/soccer/ita.1/scoreboard?dates=20220902&limit=200
                    Starting module: MMM-MyScoreboard MMM-MyScoreboard.js:560
                    All modules started!
                    MMM-MyScoreboard.js:552
                    [MMM-MyScoreboard] Updating Scores module.js:195
                    MMM-MyScoreboard is suspended.
                    Below my configuration
                    		  module: "MMM-MyScoreboard",
                    		  classes: "default everyone",
                    		  header: "My Scoreboard",
                    			showLeagueSeparators: true,
                    			colored: true,
                    			viewStyle: "mediumLogos",
                    			sports: [
                    				league: "ITA_SERIE_A",
                    				//teams: ["JUV"]
                    				//label: "Seria A TIM 2022/23"
                    Can you help me?
                      sdetweil @Egnos
                      @Egnos looks like the provider changed their API. so the module will have to be changed
                      • E
                        Egnos @sdetweil
                        @sdetweil said in MMM-MyScoreboard:
                        Hi @sdetweil
                        I understand. Do you know if the developer still maintains the module?
                          sdetweil @Egnos
                          @Egnos no idea, go look at the GitHub site, post an issue.
                          • E
                            Egnos @sdetweil
                            I tried to do the recommended fix but nothing has changed.
                            https://github.com/jclarke0000/MMM-MyScoreboard/pull/61
                            I opened a problem on GitHub as you advised me, I await an answer.
                            If someone had solved … give a whistle ;-)
                              sdetweil @Egnos
                              @Egnos but that PR fixes the wrong provider… the espn provider is broken
                              the error u posted
                              that module is 5 years old… these providers change things every year…
                              • BKeyportB
                                @sdetweil ESPN sneezes and the data format changes. Not a reliable source.
                                E 1 Reply Last reply Reply Quote 1
                                • E
                                  Egnos @BKeyport
                                  @BKeyport said in MMM-MyScoreboard:
                                  Hi @BKeyport do you know a valid alternative?
                                  • BKeyportB
                                    BKeyport Module Developer @Egnos
                                    @Egnos sadly, no, i don’t. Gave up on scores on my mirror long ago.
                                      Sorry folks that I haven’t been around to fix this. There URL for the ticker changed for the SportsNet provider. I’ll be publishing a fix in the cominn g days, but if you want to address it now, make a change in the file providers/SNET.js.
                                      Change line #122 from
                                          var url = "https://d290qmen6zswb.cloudfront.net/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                                      to
                                         var url = "https://mobile-statsv2.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                                      This should get you back up and running until I publish the official fix.
                                      • Jeff
                                      • E
                                        Egnos @j.e.f.f
                                        @j-e-f-f said in MMM-MyScoreboard:
                                        Thanks @j-e-f-f we look forward to the official release!:thumbs_up:
                                          From my standpoint, the only thing that stopped working for me were any of the feeds that used the Sportsnet provider. But I am seeing some anecdotal reports of the ESPN provider also not working? Could anyone provide some examples of this? ESPN is working for me as-is.
                                            New update released. This is a big one. Addresses the following:
                                            • Correction of SNET provider ticker URL
                                            • Change of ESPN provider URL to HTTPS
                                            • Replacement of deprecated library Request with Axios
                                            • Addition of WNBA and NCAAW womens’ basketball leagues
                                            • Team logo updates for North American leagues
                                            • Correction of NCAA team shortcode for Wisconsin Badgers from WIS to WISC
                                            As this has a replacement of a module, you’ll need to run npm install after doing a git pull in the MMM-MyScoreBoard directory
                                            A note on ESPN’s feed. I have seen a number of posts reporting that the it sporadically stops working. As of right now the ESPN feed works properly for me, but I did notice over the course of the last couple of day’s testing that sometimes the request out to ESPN is not answered in a timely manner. Eventually ESPN will update, but sometimes it is slow. I have made a change so that the request is made over HTTPS instead of HTTP, and my testing since then has shown the feed to be more reliable. Of course, this could just be a complete coincidence, and it’s equally as likely that we’ll continue to see issues with ESPN-sourced scoreboard data.
                                            Once again, sorry for the LOOOOOOONG delay in addressing this. My mirror has sat unattended to for quite some time, and I only recently got around to rebuilding things. A number of my modules had stopped working, not just this one. Hopefully, this gets everyone back up and running.
                                            W E 2 Replies Last reply Reply Quote 2
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 12 / 14
