    MMM-MyScoreboard
    277 Posts 60 Posters 562.1k Views 63 Watching
      sdetweil @sifuhall
      @sifuhall this sounds like the the missing libraries problem. when the screen is blank, can u show the message at mm startup?
      if using pm2, use
      pm2 logs --lines=100
      sifuhallS 1 Reply Last reply Reply Quote 0
      • sifuhallS Offline
        sifuhall @sdetweil
        Yes, this was it exactly. Once I added the request module everything was fine.
        However, I do have one question.
        How can I add the West Ham United Football Club?
        • BKeyportB Offline
          BKeyport Module Developer @sifuhall
          @sifuhall it looks like it’s not supported based on the code.
          • sifuhallS Offline
            sifuhall @BKeyport
            @bkeyport Thank you for the reply
            • E Offline
              Egnos
              Hello everybody,
              I’m having trouble with this module, are any of you using it?
              The following errors MM returns me:
              [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] 2-Sep-22 10:52 ** ERROR ** Couldn't retrieve ITA_SERIE_A data for provider ESPN: Error: getaddrinfo ENOTFOUND site.api.espn.com
              [02.09.2022 10:52.55.068] [LOG]   [MMM-MyScoreboard] http://site.api.espn.com/apis/site/v2/sports/soccer/ita.1/scoreboard?dates=20220902&limit=200
              Starting module: MMM-MyScoreboard MMM-MyScoreboard.js:560
              All modules started!
              MMM-MyScoreboard.js:552
              [MMM-MyScoreboard] Updating Scores module.js:195
              MMM-MyScoreboard is suspended.
              Below my configuration
              		  module: "MMM-MyScoreboard",
              		  classes: "default everyone",
              		  header: "My Scoreboard",
              			showLeagueSeparators: true,
              			colored: true,
              			viewStyle: "mediumLogos",
              			sports: [
              				league: "ITA_SERIE_A",
              				//teams: ["JUV"]
              				//label: "Seria A TIM 2022/23"
              Can you help me?
                sdetweil @Egnos
                @Egnos looks like the provider changed their API. so the module will have to be changed
                • E Offline
                  Egnos @sdetweil
                  @sdetweil said in MMM-MyScoreboard:
                  Hi @sdetweil
                  I understand. Do you know if the developer still maintains the module?
                    sdetweil @Egnos
                    @Egnos no idea, go look at the GitHub site, post an issue.
                    • E Offline
                      Egnos @sdetweil
                      I tried to do the recommended fix but nothing has changed.
                      https://github.com/jclarke0000/MMM-MyScoreboard/pull/61
                      I opened a problem on GitHub as you advised me, I await an answer.
                      If someone had solved … give a whistle ;-)
                        sdetweil @Egnos
                        @Egnos but that PR fixes the wrong provider… the espn provider is broken
                        the error u posted
                        that module is 5 years old… these providers change things every year…
                        • 21
                        • 22
                        • 23
                        • 24
                        • 25
                        • 26
                        • 27
                        • 28
                        • 23 / 28
