    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
    • FoziF
      Fozi Project Sponsor @Jalibu
      @jalibu Thanks for the update, man! You rock!
      I installed the update, but unfortunatelly no map is displayed at all. No matter if displayOnlyOnRain: is set true or false.
      I opened an issue an github https://github.com/jalibu/MMM-RAIN-MAP/issues/12
      • FoziF
        @Jalibu Awsome, thanks for the quick fix!
        As far as I can see the forecast for 30 min. works fine. At the moment I can’t discover any issues. I dunno how you found a way to pull those forecasts, but thanks for your effort!
        swvalentiS 1 Reply Last reply
        • swvalentiS
          swvalenti Project Sponsor @Fozi
          @Jalibu 30min works great thanks! Only thing I could think of is it possible to put a delay between zoom levels?
          • JalibuJ
            Jalibu Module Developer
            The latest version 2.2.0 now also has an optional timeline feature.
            • swvalentiS
              swvalenti Project Sponsor @Jalibu
              @jalibu Killing it keep it up!
                causerino
                I don’t know what I am doing wrong, but I can’t get the map to centre on my location.
                //New Module                    Rain Map
                                        module: "MMM-RAIN-MAP",
                                                animationSpeedMs: 400,
                                                colorizeTime: true,
                                                defaultZoomLevel: 8,
                                                displayTime: true,
                                                displayTimeline: true,
                                                displayClockSymbol: true,
                                                displayOnlyOnRain: false,
                                                extraDelayLastFrameMs: 1000,
                                                extraDelayCurrentFrameMs: 3000,
                                                markers: [
                //                                      { lat: 49.41, lng: 8.717, color: "red" },
                                                        { lat: 50.212, lng: 5.29, color: "green" },
                                                mapPositions: [
                                                        { lat: 50.212, lng: 5.29, zoom: 9, loops: 1 },
                                                mapUrl: "https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png",
                                                mapHeight: "420px",
                                                mapWidth: "420px",
                                                substitudeModules: [],
                                                updateIntervalInSeconds: 300,
                Am I doing something completely wrong? It just centres around Rochefort, and not Cornwall.
                EDIT: I’m an idiot… it should be -5 not 5 for lng. Fixed. Thank you for this!
                M 1 Reply Last reply
                Reply Quote 3
                  MajorC Project Sponsor @causerino
                  The new rain-map is working wonderful. Does anyone know a map, with transparent or light transparent background?
                  M karsten13K 2 Replies Last reply
                    MajorC Project Sponsor @MajorC
                    @majorc
                    Found it, in the custom.css use:
                     * MMM-RAIN-MAP
                    .MMM-RAIN-MAP {
                       opacity: 0.7;
                      @Jalibu is there an option to limit the time period into the past and into the future?
                      JalibuJ 1 Reply Last reply
                      • JalibuJ
                        Jalibu Module Developer @MajorC
                        @majorc not yet.
                        But you can open a feature request issue and say “please please please please”
                        • swvalentiS
                          @jalibu said in MMM-RAIN-MAP (new: version 2.x):
                          @majorc not yet.
                          I second. Please.
                          • karsten13K
                            karsten13 @MajorC
                            @majorc said in MMM-RAIN-MAP (new: version 2.x):
                            may not exactly what you want but I’m using this map
                                    mapUrl: "https://tiles.wmflabs.org/bw-mapnik/{z}/{x}/{y}.png",
                            which is nearly uncoloured.
                              PH1TCH
                              Hey @Jalibu,
                              I noticed that the module started to throw errors in the logs.
                              Do you have an idea how this could be addressed?
                              0|mm       | [29.08.2021 13:07.10.633] [ERROR] ERROR! Could not validate main module js file.
                              0|mm       | [29.08.2021 13:07.10.638] [ERROR] ReferenceError: window is not defined
                              0|mm       |     at /home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:1913
                              0|mm       |     at Object.243 (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:142305)
                              0|mm       |     at e (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:151019)
                              0|mm       |     at Object.138 (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:142720)
                              0|mm       |     at /home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:151060
                              0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:151067)
                              0|mm       |     at Module._compile (internal/modules/cjs/loader.js:1078:30)
                              0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                              0|mm       |     at Module.load (internal/modules/cjs/loader.js:935:32)
                              Thanks again for your help!
                              • JalibuJ
                                Jalibu Module Developer @PH1TCH
                                @ph1tch
                                I can’t reproduce that.
                                Please open a Github issue for that, if the problem still exists.
                                  MajorC Project Sponsor @karsten13
                                  @karsten13 said in MMM-RAIN-MAP (new: version 2.x):
                                  mapUrl: “https://tiles.wmflabs.org/bw-mapnik/{z}/{x}/{y}.png”,
                                  Thank you. I will go now with:
                                  mapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/light_all/{z}/{x}/{y}.png",
                                  I think, this one is even more “lighter”.
                                  earnestrichardsE 1 Reply Last reply
                                  • earnestrichardsE
                                    earnestrichards @MajorC
                                    @Jalibu I love the new module… got it going just in time to track Tropical Storm Nicholas
                                    • earnestrichardsE
                                      earnestrichards @earnestrichards
                                      Reply Quote 2
                                      • L
                                        lishmalinyjames
                                        Displays Rainviewer.com radar layers on OpenStreetMap
                                        Every 10 minutes a new weather snapshot is published
                                        The snapshots of the last 2 hours are available, which show the weather events of the past
                                        Additionally 3 layers are displayed as forecast of the next 30 minutes
                                        Option to place multiple markers on map
                                        Option for multiple, alternating map positions
                                        Option to only show in current rainy weather conditions. Works only together with weather or MMM-OpenWeatherForecast as dependency.
                                        Option to hide other modules in case of rain in favor to get more space.
                                        G 1 Reply Last reply
                                        • G
                                          gabrielm9 Project Sponsor @lishmalinyjames
                                          Thanks @Jalibu for a fantastic module!
                                          Last year I modified the v1 code to change the color of the radar images to RainViewer color 4. My wife associates blue with snow, not rain, hence the preference for the Weather Channel scheme.
                                          I accomplished this by modifying 2 instances of the URL in utils.js, consistent with the API documentation. Where I found “/256/{z}/{x}/{y}/2/1_1.png” in the code, I simply changed it to “/256/{z}/{x}/{y}/4/1_1.png”, with the 4 being the preferred radar color.
                                          I’m unable to do the same in version 2.x. I found the URL in Client.ts, but modifying it had no effect on the output.
                                          I’m happy to file an enhancement request if that’s the best route. I’m skilled enough to do find and replace in code, but I’m not a JS dev!
                                          Thanks!
                                          JalibuJ 2 Replies Last reply
                                          • JalibuJ
                                            Jalibu Module Developer @gabrielm9
                                            Hi @gabrielm9 ,
                                            contribution is always welcome :-)
                                            You have to compile the Typescript sources using npm run build.
                                            Let me know, if you have problems. I‘m waiting for your PR
                                            • 10
                                            • 7 / 10
