    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 316.1k Views 42 Watching
    • JalibuJ
      Jalibu Module Developer
      The latest version 2.2.0 now also has an optional timeline feature.
      swvalentiS 1 Reply Last reply Reply Quote 1
      • swvalentiS
        swvalenti Project Sponsor @Jalibu
        @jalibu Killing it keep it up!
          causerino
          I don’t know what I am doing wrong, but I can’t get the map to centre on my location.
          //New Module                    Rain Map
                                  module: "MMM-RAIN-MAP",
                                          animationSpeedMs: 400,
                                          colorizeTime: true,
                                          defaultZoomLevel: 8,
                                          displayTime: true,
                                          displayTimeline: true,
                                          displayClockSymbol: true,
                                          displayOnlyOnRain: false,
                                          extraDelayLastFrameMs: 1000,
                                          extraDelayCurrentFrameMs: 3000,
                                          markers: [
          //                                      { lat: 49.41, lng: 8.717, color: "red" },
                                                  { lat: 50.212, lng: 5.29, color: "green" },
                                          mapPositions: [
                                                  { lat: 50.212, lng: 5.29, zoom: 9, loops: 1 },
                                          mapUrl: "https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png",
                                          mapHeight: "420px",
                                          mapWidth: "420px",
                                          substitudeModules: [],
                                          updateIntervalInSeconds: 300,
          Am I doing something completely wrong? It just centres around Rochefort, and not Cornwall.
          EDIT: I’m an idiot… it should be -5 not 5 for lng. Fixed. Thank you for this!
          M 1 Reply Last reply Reply Quote 3
            MajorC Project Sponsor @causerino
            The new rain-map is working wonderful. Does anyone know a map, with transparent or light transparent background?
            M karsten13K 2 Replies Last reply Reply Quote 0
              MajorC Project Sponsor @MajorC
              @majorc
              Found it, in the custom.css use:
               * MMM-RAIN-MAP
              .MMM-RAIN-MAP {
                 opacity: 0.7;
                @Jalibu is there an option to limit the time period into the past and into the future?
                JalibuJ 1 Reply Last reply Reply Quote 0
                • JalibuJ
                  Jalibu Module Developer @MajorC
                  @majorc not yet.
                  But you can open a feature request issue and say “please please please please”
                  • swvalentiS
                    @jalibu said in MMM-RAIN-MAP (new: version 2.x):
                    @majorc not yet.
                    I second. Please.
                    • karsten13K
                      karsten13 @MajorC
                      @majorc said in MMM-RAIN-MAP (new: version 2.x):
                      may not exactly what you want but I’m using this map
                              mapUrl: "https://tiles.wmflabs.org/bw-mapnik/{z}/{x}/{y}.png",
                      which is nearly uncoloured.
                        PH1TCH
                        Hey @Jalibu,
                        I noticed that the module started to throw errors in the logs.
                        Do you have an idea how this could be addressed?
                        0|mm       | [29.08.2021 13:07.10.633] [ERROR] ERROR! Could not validate main module js file.
                        0|mm       | [29.08.2021 13:07.10.638] [ERROR] ReferenceError: window is not defined
                        0|mm       |     at /home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:1913
                        0|mm       |     at Object.243 (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:142305)
                        0|mm       |     at e (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:151019)
                        0|mm       |     at Object.138 (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:142720)
                        0|mm       |     at /home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:151060
                        0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:1:151067)
                        0|mm       |     at Module._compile (internal/modules/cjs/loader.js:1078:30)
                        0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
                        0|mm       |     at Module.load (internal/modules/cjs/loader.js:935:32)
                        Thanks again for your help!
                        • JalibuJ
                          Jalibu Module Developer @PH1TCH
                          @ph1tch
                          I can’t reproduce that.
                          Please open a Github issue for that, if the problem still exists.
                            MajorC Project Sponsor @karsten13
                            @karsten13 said in MMM-RAIN-MAP (new: version 2.x):
                            mapUrl: “https://tiles.wmflabs.org/bw-mapnik/{z}/{x}/{y}.png”,
                            Thank you. I will go now with:
                            mapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/light_all/{z}/{x}/{y}.png",
                            I think, this one is even more “lighter”.
                            earnestrichardsE 1 Reply Last reply Reply Quote 1
                            • earnestrichardsE
                              earnestrichards @MajorC
                              @Jalibu I love the new module… got it going just in time to track Tropical Storm Nicholas
                              earnestrichardsE 1 Reply Last reply Reply Quote 0
                              • earnestrichardsE
                                earnestrichards @earnestrichards
                                • L
                                  lishmalinyjames
                                  Displays Rainviewer.com radar layers on OpenStreetMap
                                  Every 10 minutes a new weather snapshot is published
                                  The snapshots of the last 2 hours are available, which show the weather events of the past
                                  Additionally 3 layers are displayed as forecast of the next 30 minutes
                                  Option to place multiple markers on map
                                  Option for multiple, alternating map positions
                                  Option to only show in current rainy weather conditions. Works only together with weather or MMM-OpenWeatherForecast as dependency.
                                  Option to hide other modules in case of rain in favor to get more space.
                                  • G
                                    gabrielm9 Project Sponsor @lishmalinyjames
                                    Thanks @Jalibu for a fantastic module!
                                    Last year I modified the v1 code to change the color of the radar images to RainViewer color 4. My wife associates blue with snow, not rain, hence the preference for the Weather Channel scheme.
                                    I accomplished this by modifying 2 instances of the URL in utils.js, consistent with the API documentation. Where I found “/256/{z}/{x}/{y}/2/1_1.png” in the code, I simply changed it to “/256/{z}/{x}/{y}/4/1_1.png”, with the 4 being the preferred radar color.
                                    I’m unable to do the same in version 2.x. I found the URL in Client.ts, but modifying it had no effect on the output.
                                    I’m happy to file an enhancement request if that’s the best route. I’m skilled enough to do find and replace in code, but I’m not a JS dev!
                                    Thanks!
                                    JalibuJ 2 Replies Last reply Reply Quote 0
                                    • JalibuJ
                                      Jalibu Module Developer @gabrielm9
                                      Hi @gabrielm9 ,
                                      contribution is always welcome :-)
                                      You have to compile the Typescript sources using npm run build.
                                      Let me know, if you have problems. I‘m waiting for your PR
                                      • JalibuJ
                                        Hi @gabrielm9,
                                        the latest version 2.5.x supports different color schemes now.
                                        swvalentiS G 2 Replies Last reply Reply Quote 0
                                        • swvalentiS
                                          Outstanding work fellas
                                          • G
                                            gabrielm9 Project Sponsor @Jalibu
                                            Hi @jalibu,
                                            Thanks very much! I was about to spend time figuring it out how to variabalize the code but I’ve learned from what you did. I would have taken me a week to figure it out :slightly_smiling_face:. The wife thanks you as well.
                                            • 10
                                            • 7 / 10
