    eaddress in use
    10 Posts 5 Posters 2.8k Views 5 Watching
      Binog
      Hey, do have a blank screen. and the logs show:
      0|mm | [01.09.2021 18:00.08.684] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      0|mm | [01.09.2021 18:09.09.021] [ERROR] Whoops! There was an uncaught exception…
      0|mm | [01.09.2021 18:09.09.036] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
      0|mm | at Server.setupListenHandle [as _listen2] (net.js:1313:16)
      0|mm | at listenInCluster (net.js:1361:12)
      0|mm | at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)
      0|mm | at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) {
      0|mm | code: ‘EADDRINUSE’,
      0|mm | errno: ‘EADDRINUSE’,
      0|mm | syscall: ‘listen’,
      0|mm | address: ‘127.0.0.1’,
      0|mm | port: 8080
      0|mm | }
      0|mm | [01.09.2021 18:09.09.038] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm | [01.09.2021 18:09.09.039] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      this is with a clean install of Magicmirror and the sample.config.
        Binog @BKeyport
        @bkeyport
        As the new system is running, I did change the port !
        Thx !
        • mumblebajM Online
          mumblebaj Module Developer @Binog
          @binog said in eaddress in use:
          EADDRINUSE
          The EADDRINUSE error usually means that another instance of the mirror is running. If you start the mirror with pm2, you can do a pm2 list to show the current processes that are running under pm2. You can then stop that process with pm2 stop #id or process stop all. Then you should be able to start the mirror again.
            Binog @mumblebaj
            @mumblebaj
            Thank You for reply ! None the less, there was no other instance running, I double checked it, nore was an instance under npm running. I finally decided to format the card and start over,… thx
            • BKeyportB Offline
              BKeyport Module Developer @Binog
              @binog Even though it’s fixed, there could be another issue - something else running on port 8080. I always change the default ports… 60001, 60002, etc. Less mess.
              • N Offline
                nickthebeer
                Can you run the following commands from the CLI to check if anything is using that port
                sudo netstat -punta | grep LIST
                sudo netstat -punta | grep 8080
                  Binog @nickthebeer
                  Thank You, Nickthebeer and BKeyport
                  I’ll try in future, I finally decided to reinstall the whole system.
                  • mumblebajM Online
                    @binog That is a pity. We could probably have found the issue and save your current state prior to the issue. Hope it is running fine now though.
                    • cowboysdudeC Offline
                      cowboysdude Module Developer @BKeyport
                      @bkeyport 1st thing I do is change the port always :)
                      • BKeyportB Offline
                        BKeyport Module Developer @cowboysdude
                        @cowboysdude
                        As well as the sample config is documented, I’m shocked that the port line is blank.
                        I’d totally have it:
                        port: 8080 // Change this! Recommended over 60000 to avoid conflict
                        But, hey, I’m just a hack, ya know? 😉
                          Binog @BKeyport
                          @bkeyport
                          Thx !
