    eaddress in use
    10 Posts 5 Posters 2.4k Views 5 Watching
      Binog @mumblebaj
      @mumblebaj
      Thank You for reply ! None the less, there was no other instance running, I double checked it, nore was an instance under npm running. I finally decided to format the card and start over,… thx
      • BKeyportB Offline
        BKeyport Module Developer @Binog
        @binog Even though it’s fixed, there could be another issue - something else running on port 8080. I always change the default ports… 60001, 60002, etc. Less mess.
        • N Offline
          nickthebeer
          Can you run the following commands from the CLI to check if anything is using that port
          sudo netstat -punta | grep LIST
          sudo netstat -punta | grep 8080
            Binog @nickthebeer
            Thank You, Nickthebeer and BKeyport
            I’ll try in future, I finally decided to reinstall the whole system.
            • mumblebajM Offline
              mumblebaj Module Developer @Binog
              @binog That is a pity. We could probably have found the issue and save your current state prior to the issue. Hope it is running fine now though.
              • cowboysdudeC Offline
                cowboysdude Module Developer @BKeyport
                @bkeyport 1st thing I do is change the port always :)
                • BKeyportB Offline
                  BKeyport Module Developer @cowboysdude
                  @cowboysdude
                  As well as the sample config is documented, I’m shocked that the port line is blank.
                  I’d totally have it:
                  port: 8080 // Change this! Recommended over 60000 to avoid conflict
                  But, hey, I’m just a hack, ya know? 😉
                    Binog @BKeyport
                    @bkeyport
                    As the new system is running, I did change the port !
                    Thx !
