    Any plan to replace "request" and "moment"?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    61 Posts 8 Posters 38.2k Views 8 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @0m4r
      I’m using Brave which is Chrome based without all the tracking and such ;)
      0m4r0 1 Reply Last reply Reply Quote 0
      • 0m4r0 Offline
        0m4r Module Developer @cowboysdude
        @cowboysdude technically it is based on Chromium (https://www.chromium.org/).
        https://github.com/0m4r
          cowboysdude Module Developer @BKeyport
          @bkeyport I wouldn’t worry about it. Moment will be around for a while. Easy to use and yes you can add it to your own package json file and still use it.
          Request…not so much LOL
            @0m4r meh either way LOL
            • BKeyportB Offline
              BKeyport Module Developer @cowboysdude
              @cowboysdude Been playing with changing over anyway (to luxon), and all I’ve been able to do for sure is make MM not come up at all.
              There needs to be MUCH better documentation on how to build out with external modules. It don’t make sense.
                sdetweil @BKeyport
                @bkeyport explain more. externals are used in node_helper, and some can be used in module name.js as loaded by getScripts()
                if the lib shows useage as a < script … />
                link, then u can use it in getScripts
                • BKeyportB Offline
                  @sdetweil I’m trying to get luxon up and running.
                  Supports Node.js 6+. Install via NPM:
                  npm install --save luxon
                  const { DateTime } = require("luxon");
                  Do I need to use node_helper to get it going, then?
                  https://moment.github.io/luxon/#/install
                    sdetweil @BKeyport
                    @bkeyport require only works in node_helper
                    the doc also gives u a < script approach
                    still npm install
                    then getScripts to load the file from node_modules folder/luxon folder
                    the use in modulename.js as shown for browser
                    • BKeyportB Offline
                      @sdetweil Oh, so I set up the require in node_helper, and use it accordingly in the main module script? Nice.
                        sdetweil @BKeyport
                        @bkeyport no. one OR the other
                        • BKeyportB Offline
                          @sdetweil OK, I’m lost.
                          If Moment goes away, I’ll delete my modules.
                            sdetweil @BKeyport
                            @bkeyport if you don’t have a node_helper, the you use the getScripts approach
                            if u have both, then u have to do both
                            • BKeyportB Offline
                              I give up.
                              Suggestion for the main app -
                              Create a date-time service that hides what library you’re using. If you decide to replace the library in the future, you’ll need to update only one file.
                              That way, we don’t have to move at all - just convert from accessing moment directly to accessing the internal service.
                              In the meantime, I’m indeed dropping it.
                                sdetweil @BKeyport
                                @bkeyport I don’t understand dropping the library…
                                sadly its never that easy. code has to change.
                                as for the other.
                                can u do all you app in the browser side (module name.js)
                                if so then u load the new moment library with
                                npm install --save libname
                                and then (check syntax)
                                getScripts:
                                  return [ this.file("node_modules/libname/....")]
                                     // the file is whatever would be in the script tag
                                of u need to use node_helper, and need moment like stuff,
                                const ???? = require('libname')
                                if u need both, then u have to do both
                                • BKeyportB Offline
                                  Dropping it = Not going to bother until I have to.
                                  • mumblebajM Offline
                                    mumblebaj Module Developer @BKeyport
                                    EDIT: Reference path to luxon.min.js
                                    @bkeyport I think the following should work for you.
                                    Add luxon.min.js to your project in the root of your project.
                                    Then add the following to you project, I have used your MMM-Multimonth as an example project.
                                    getScripts: function() {
                                                  return[this.file("/node_modules/luxon/build/global/luxon.min.js")]
                                    Once added you should be able to use it like this:
                                    In your project you have the following for moment:
                                    monthTitle = moment().add(-1, "month").format("MMMM YYYY")
                                    You an now do the following in luxon:
                                    const luxMonth = luxon.DateTime.now().plus({month: -1}).toFormat("MMMM yyyy")
                                    Hope this gives you a start in the right direction.
                                    You can find luxon.min.js here
                                      sdetweil @mumblebaj
                                      @mumblebaj don’t copy the file to the root of your module. just use it from the linstalled location.
                                        @sdetweil I have now found it in the /node_modules/luxon/build/global
                                        I should have searched some more. :beaming_face_with_smiling_eyes:
                                        But, yes, you are correct. You can just point to that location.
                                        BKeyportB 1 Reply Last reply Reply Quote 1
                                        • BKeyportB Offline
                                          BKeyport Module Developer @mumblebaj
                                          @mumblebaj Yeah, I got irritated enough that it wasn’t working I realized I was being a total idiot and not pointing at the JS correctly. Why the hell it’s buried so deep, well…
                                            sdetweil @BKeyport
                                            @bkeyport
                                            why is it buried so deep?
                                            cause everybody does their own thing
                                            • 3 / 4
