    Any plan to replace "request" and "moment"?
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    61 Posts 8 Posters 42.7k Views 8 Watching
    • BKeyportB
      BKeyport Module Developer @0m4r
      @0m4r When I’m testing something, I’ll load it up on my local machine, which is a Mac, and yes, I use Safari. :)
      0m4r0 1 Reply Last reply
      • 0m4r0
        0m4r Module Developer @BKeyport
        @bkeyport same for me, even tho I am aware like 99% of MM users are running it out of a raspberry pi with a Chromium browser.
        That is the reason I say the main focus could be on Chromium-based browsers rather than others.
        https://github.com/0m4r
        • cowboysdudeC
          cowboysdude Module Developer @0m4r
          I’m using Brave which is Chrome based without all the tracking and such ;)
          • 0m4r0
            0m4r Module Developer @cowboysdude
            @cowboysdude technically it is based on Chromium (https://www.chromium.org/).
            • cowboysdudeC
              cowboysdude Module Developer @BKeyport
              @bkeyport I wouldn’t worry about it. Moment will be around for a while. Easy to use and yes you can add it to your own package json file and still use it.
              Request…not so much LOL
              BKeyportB 1 Reply Last reply
              • cowboysdudeC
                @0m4r meh either way LOL
                • BKeyportB
                  BKeyport Module Developer @cowboysdude
                  @cowboysdude Been playing with changing over anyway (to luxon), and all I’ve been able to do for sure is make MM not come up at all.
                  There needs to be MUCH better documentation on how to build out with external modules. It don’t make sense.
                    sdetweil @BKeyport
                    @bkeyport explain more. externals are used in node_helper, and some can be used in module name.js as loaded by getScripts()
                    if the lib shows useage as a < script … />
                    link, then u can use it in getScripts
                    • BKeyportB
                      @sdetweil I’m trying to get luxon up and running.
                      Supports Node.js 6+. Install via NPM:
                      npm install --save luxon
                      const { DateTime } = require("luxon");
                      Do I need to use node_helper to get it going, then?
                      https://moment.github.io/luxon/#/install
                        sdetweil @BKeyport
                        @bkeyport require only works in node_helper
                        the doc also gives u a < script approach
                        still npm install
                        then getScripts to load the file from node_modules folder/luxon folder
                        the use in modulename.js as shown for browser
                        • BKeyportB
                          @sdetweil Oh, so I set up the require in node_helper, and use it accordingly in the main module script? Nice.
                            sdetweil @BKeyport
                            @bkeyport no. one OR the other
                            • BKeyportB
                              @sdetweil OK, I’m lost.
                              If Moment goes away, I’ll delete my modules.
                                sdetweil @BKeyport
                                @bkeyport if you don’t have a node_helper, the you use the getScripts approach
                                if u have both, then u have to do both
                                • BKeyportB
                                  I give up.
                                  Suggestion for the main app -
                                  Create a date-time service that hides what library you’re using. If you decide to replace the library in the future, you’ll need to update only one file.
                                  That way, we don’t have to move at all - just convert from accessing moment directly to accessing the internal service.
                                  In the meantime, I’m indeed dropping it.
                                    sdetweil @BKeyport
                                    @bkeyport I don’t understand dropping the library…
                                    sadly its never that easy. code has to change.
                                    as for the other.
                                    can u do all you app in the browser side (module name.js)
                                    if so then u load the new moment library with
                                    npm install --save libname
                                    and then (check syntax)
                                    getScripts:
                                      return [ this.file("node_modules/libname/....")]
                                         // the file is whatever would be in the script tag
                                    of u need to use node_helper, and need moment like stuff,
                                    const ???? = require('libname')
                                    if u need both, then u have to do both
                                    • BKeyportB
                                      Dropping it = Not going to bother until I have to.
                                      mumblebajM 1 Reply Last reply
                                      • mumblebajM
                                        mumblebaj Module Developer @BKeyport
                                        EDIT: Reference path to luxon.min.js
                                        @bkeyport I think the following should work for you.
                                        Add luxon.min.js to your project in the root of your project.
                                        Then add the following to you project, I have used your MMM-Multimonth as an example project.
                                        getScripts: function() {
                                                      return[this.file("/node_modules/luxon/build/global/luxon.min.js")]
                                        Once added you should be able to use it like this:
                                        In your project you have the following for moment:
                                        monthTitle = moment().add(-1, "month").format("MMMM YYYY")
                                        You an now do the following in luxon:
                                        const luxMonth = luxon.DateTime.now().plus({month: -1}).toFormat("MMMM yyyy")
                                        Hope this gives you a start in the right direction.
                                        You can find luxon.min.js here
                                          sdetweil @mumblebaj
                                          @mumblebaj don’t copy the file to the root of your module. just use it from the linstalled location.
                                          • mumblebajM
                                            @sdetweil I have now found it in the /node_modules/luxon/build/global
                                            I should have searched some more. :beaming_face_with_smiling_eyes:
                                            But, yes, you are correct. You can just point to that location.
                                            • 3 / 4
