    7" and 5" displays
    16 Posts 10 Posters 9.6k Views 12 Watching
      Saabman Project Sponsor
      That looks neat,
      how do you find the brightness in the bedroom of a night. I made a clock out of and Iphone but found the backlight was way too bright.
      do you have absolute control over your back light?
      • H Offline
        harney @Saabman
        @saabman I did some testing and found a brightness that didnt light up the room but still enabled the display to be seem
        The Sun and Moon icons on the left have commands attached to them
        | command: “echo 20 | sudo tee /sys/class/backlight/rpi_backlight/brightness”, |
        I just changed the “echo xxx” number to a value that works for me. I’m using Raspberry screens.
          Saabman Project Sponsor @harney
          @harney Thats good Your on a winner :)
          I shelved my Iphone project till I can get my hands on some dark window tint to bring it under control -
            carltonb
            @harney These look great. I have built something similar on larger screens.
            Can you please let me know what models of the 5 and 7" screens you are using.
            carltonb
            • G Offline
              Gr1dL0ck @harney
              @harney
              how did you get the sun/moon to come up and in color like that ?
              could you post some of the code to that
              • H Offline
                harney @carltonb
                @carltonb the 7inch screen is the raspberry pi unit https://www.raspberrypi.org/products/raspberry-pi-touch-display/
                and the 5 inch is from DFRobot, https://www.dfrobot.com/product-1784.html
                i chose both these as they use a flat ribbon cable to hook up instead of HDMI or the GPIO pins
                • H Offline
                  harney @Gr1dL0ck
                  @gr1dl0ck that is the 5inch screen using MMM-weatherforecast https://github.com/jharttech/MMM-weatherforecast/blob/master/README.md
                  which comes with deviant art icons. I reduced the size of the icins to fit the area i had, and saved them in the CSS file as instructed but used different names. then change the MMM-weatherforcast.css file to point to the icos i wanted shown rather than the default selection. Theres quite a few icons to select from in the icon folder of the git file. I just chose the ones i liked the best based on the fortecast
                  • O Offline
                    osfersa
                    How did you get to use the whole 7’ screen, when I build mine, it cropped the top and bottom?
                      mm does not know it’s a touch screen the browser draws on the screen and it so happens that it supports touch events , like mouse events. click here , click there.
                      the thing under the click point reacts to the event or not, depending on what browser element it is.
                      if the screen doesn’t support touch, then there is not click event, but the html widget is the same
                      O 1 Reply Last reply Reply Quote 1
                      • H Offline
                        harney @osfersa
                        @osfersa In the Main.Css file
                        body {
                        margin: 10px;
                        position: absolute;
                        height: calc(100% - 20px); ##Change this to 100% - xx
                        width: calc(100% - 20px);
                        • Robin GarnerR Offline
                          Robin Garner @harney
                          @harney how long did it take you to make this? and does it have any bugs? I’m just curious to how does it work!!
                          • O Offline
                            osfersa @sdetweil
                            @sdetweil Works now Thank you.
                            • H Offline
                              harney @Robin Garner
                              @robin-garner It took longer to print the cases than it did to do the software. Its all relatively straightforward modules. Just follow the instructions and you wont have any problems.
                              Although, for some reason Speedtest module no longer works since Ookla made some changes to their software. This would be the only bug I have fown and that was only recently (since August I think)
                              • freddiewoodsF Offline
                                freddiewoods
                                very good efforts
                                • K Offline
                                  kimcat
