    Newsfeeder is going way to fast when showing news
    27 Posts 10 Posters 11.7k Views 11 Watching
    • F Offline
      fribse @fribse
      @sdetweil Ok, I finally got it tested again.
      If I go to my computer and open the webpage via remote it shows the right interval (this was what I did earlier), and the news cycles slowly as it should.
      But on the raspberry pi, it still races through the news.
      I haven’t restarted the Rpi just to keep the problem, but for me it’s not an easy test on the RPi itself, as the RPi is of course behind the mirror and headless.
      • JalibuJ Offline
        Jalibu Module Developer
        I assume that for some reason some intervals are going crazy during runtime. The problem is gone, if you refresh the page, but it may come again after an uncertain time.
          sek_is_back
          As a workaround, till a solution is found
          crontab -e
          @daily sudo reboot
          this will reboot the pi every night at 00:00 am.
          swvalentiS 1 Reply Last reply Reply Quote 0
          • JalibuJ Offline
            @sdetweil I opened a Github issue for that: https://github.com/MichMich/MagicMirror/issues/2638
            • O Offline
              OberfragGER @Jalibu
              I got the same issue since 2.16.
              I have one image from 2.15 - no problem so far!
              The strange thing… first after boot. It working some time like i should… Later… you see the news flashing… so the mirror is mostly black then.
              Im using also MM-Pages tho flip to another page every minute.
                sek_is_back
                updated to develop version from GitHub
                https://github.com/MichMich/MagicMirror/tree/develop
                everything is fine now, Newsfeeder runs like expected since 1 Week
                J I 2 Replies Last reply Reply Quote 0
                  JoeFranz @sek_is_back
                  @sek_is_back How do I do that?
                  • swvalentiS Offline
                    swvalenti Project Sponsor @sek_is_back
                    @sek_is_back said in Newsfeeder is going way to fast when showing news:
                    crontab -e
                    @daily sudo reboot
                    No need to reboot the whole pie
                    0 */5 * * * pm2 restart MagicMirror
                    • JalibuJ Offline
                      We found the reason for that issue. A fix is merged into the develop branch.
                      F 1 Reply Last reply Reply Quote 1
                      • F Offline
                        fribse @Jalibu
                        @jalibu Weeheee, sounds great! Good work on such an tough problem.
                        • I Offline
                          icemanmw @sek_is_back
                          @sek_is_back
                          how can i update to the development branch ? sorry for this question, but i am not the coding
                          expert :-(
                            sdetweil @icemanmw
                            @icemanmw see this
                            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
