    MMM-Fuel zeigt nur Lade...... MMM-Fuel show only load......
    29 Posts 12 Posters 15.2k Views 12 Watching
    • JalibuJ
      Jalibu Module Developer @Biebermann
      @biebermann Weil Zertifikate ein Ablaufdatum haben. Danach wird ihnen nicht mehr vertraut und gesicherte Verbindungen abgelehnt.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @Biebermann
        @biebermann you can also read this for more details https://github.com/MichMich/MagicMirror/issues/2671
        A 1 Reply Last reply
        • A
          andyyy @strawberry 3.141
          I did update to latest MM version 2.17.1, but the MMM-Fuel just says loading (laden). My config hasn’t changed since months.
          Any idea?
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @andyyy
            @andyyy which fuel provider are you using? tankerkoenig, spritpreisrechner or nsw
            • A
              @strawberry-3-141
              tankerkoenig I am using from the beginning. In Germany there is no other API I could you I suppose.
              • strawberry 3.141S
                @andyyy I just tested it, please make sure you use the newest version of MagicMirror + dependencies to contain the fix https://github.com/MichMich/MagicMirror/pull/2674
                • A
                  @strawberry-3-141
                  I am on the latest MM version, but something screwed up in the background.
                  I did load the backup with MM 2.16 and started over again. No success.
                  Eventually I loaded my oldest available backup with MM 2.9. Interestingly, all modules still worked in this old setup incl. MMM Fuel. From there I updated the MM to 2.17.1 and surprisingly MMM Fuel kept working. :)
                  Apart from the fuel module 3 other module seem to be incompatible with latest MM version resulting in a black screen on startup. Most likely some required dependencies got removed in the MM core.
                  It would be great if we could introduce a community maintained compatiblity list of all 3rd party modules. I mean the status “maintained” or not gives a hint, but it does not necessarily mean it will not work any longer.
                  For now, I am happy. :)
                    sdetweil @andyyy
                    @andyyy said in MMM-Fuel zeigt nur Lade...... MMM-Fuel show only load......:
                    it would be great if we could introduce a community maintained compatiblity list
                    we have that list, which is really not well maintained
                    3rd party modules
                    https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                    as for black screen
                    we’ve been talking about that non stop for almost 4 months.
                    request
                    valid-url
                    rrule-alt
                    are the three libraries removed. all the failures are because module authors didn’t document their dependency on them.
                    which one I needed will be shown in the mm startup messages.
                    https://forum.magicmirror.builders/topic/15743/no-javascript-experience-config-js-not-working/11?_=1634730550751
                    • F
                      Fufu1408
                      Hello everyone,
                      i have the problem, when the pi started , the MMM-Fuel modules shows me “load…” sometimes i can see the module, but most times i see the loading screen.
                      any ideas why?
                      and can i see the price from e10 and e5?
                      my config
                      module: “MMM-Fuel”,
                      position: ‘bottom_bar’,
                      updateInterval: 200,
                      api_key: “my key”,
                      lat: 49.56324,
                      lng: 11.34776,
                      types: [“e5, e10”],
                      sortBy: [“e5”, “e10”],
                      W 1 Reply Last reply
                      • W
                        Wuschel4711 @Fufu1408
                        @fufu1408 I had the thame Problem, but i solved it.
                        The Problem is nodered and the dependencies which are neede by the module.
                        1. fs-extra
                        2. node-fetch
                        They need node > 12 !
                        How to solve:
                        1. Update your System: sudo apt-get update && sudo apt-get upgrade
                        2. Install NodeRed: bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered) --node14
                        3. be patient. This will take about 20-30 minutes !! The Script will do ALL the work for you!!
                        4. install fs-extra + node-fetsch: npm install fs-extra node_fetch
                        5. Update your MM: git pull
                        6. Install MM with: npm install (from inside your MM Directory)
                        7. Update MMM-Fuel: git pull
                        8. Install MMM-Fuel: npm install (from inside your MMM-Fuel Directory)
                          Restart your System !!
                        Thats it !!
