    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      Dinschal @sdetweil
      @sdetweil thanks a lot… sometimes this is the best time to go to bed :D
      my brain isnt working much longer today :D
        sdetweil @Dinschal
        @dinschal I’ve been there… get some rest
          Dinschal @sdetweil
          first of all… my english is very bad :D
          today my goal is that your module is working… i have configure it cause i have the mm with localhost and use bitvise for ssh.
          So i have to change the localhost in my config :D
          I tired to read the error message but its to tiny :D the only thing i can read is localhost :D
            sdetweil @Dinschal
            @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
            I tired to read the error message but its to tiny the only thing i can read is localhost
            what error message?
            u mean the module output when address:“localhost” is set??
            localhost means ONLY apps running inside the SAME system can access
            so a phone (use the qr code) , or another computer (use the url) cannot…
              Dinschal @sdetweil
              @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
              I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
                sdetweil @Dinschal
                @dinschal also have to edit the ipWhitelist.
                I set it to []
                ipWhitelist:[],
                  Dinschal @sdetweil
                  @sdetweil i did it let me check ;)
                  okay i got it… but now i only have the "configuration window without the possibility to configure,
                  i tryed it with a new pull and an new installation of your module :(
                  • A
                    Alyx
                    amazing work!!! are users able to make module communicate with each other? Such as using voice commands to use another module via notifications?
                      sdetweil @Alyx
                      @alyx I don’t understand your question
                        sdetweil @Dinschal
                        @dinschal is this from the qr?
                        or did u enter a url?
                        note the url is
                        http://mmipaddr:mmport/modules/MMM-Config/review
                          sdetweil @Alyx
                          @alyx voiceCommander is built on top of MMM-Voice and Hello-Lucy
                          so, CAN you, certainly… take a voice audio -> recognizer -> send notification to other modules…
                          HOW depends on the module being used…
                          sometimes there is some config
                          sometimes there is file editing
                          sometimes there is coding
                          • A
                            Alyx @sdetweil
                            @sdetweil No worries I’ll install and play around with this tomorrow, I was wondering if it would help with setting up modules to talk to each other, as you know I’ve been having a few issues with that xD
                              sdetweil @Alyx
                              @alyx My Module ONLY addresses configuration of EACH module (stuff that goes in config.js)
                              what that stuff DOES/MEANS, my module does not know…
                              I read the source code to figure out the variables defined
                              and merge that with any info from config.js
                              and build a form to collect the data
                              then on save, I take the elements with data and build a new config.js
                              (rename the old and write the new)
                              and if restart , then I restart MM to use that new config
                              • A
                                Alyx @sdetweil
                                @sdetweil Sounds great as is Sam cant wait to try it tomorrow!
                                  Dinschal @sdetweil
                                  @sdetweil ah okay i used the wrong one… i used the one with config.html
                                    Dinschal
                                    Is it possible to add a css section in the future? that would be really nice…
                                    thanks for your work and thanks for helping me ;)
                                      Dinschal
                                      @sdetweil your module is running well, but if i changed something and create the config, it deleted the location, the locationid and the weather api from the default weather module :( this is really bad… and if i change the timefomat and the analog size in the same module and push the save, create config button it didnt save the canges.
                                        sdetweil @Dinschal
                                        @dinschal what do u mean css section?
                                        D S 2 Replies Last reply Reply Quote 0
                                          Dinschal @sdetweil
                                          @sdetweil first off all good morning ;)
                                          a section where you can edit the css sections of the modules… like the size or something else…
                                            sdetweil @Dinschal
                                            @dinschal did u set the position in the positions section?
                                            can u add debug:true to my module config
                                            copy back the prior config.js
                                            start mm like this
                                            npm start >somefile.txt
                                            then do the change again
                                            press save
                                            then stop mm (ctrl-q)
                                            and send me the somefile.txt
                                            and the two config file, prior and new
                                            and the defaults.js from the module folder
                                            via email. my email is this same userid at gmail
                                            u will have to rename the .js files to
                                            like .txt as js files are not allowed
                                            • 14
                                            • 15
                                            • 6 / 15
