    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      Dinschal @sdetweil
      first of all… my english is very bad :D
      today my goal is that your module is working… i have configure it cause i have the mm with localhost and use bitvise for ssh.
      So i have to change the localhost in my config :D
      I tired to read the error message but its to tiny :D the only thing i can read is localhost :D
        sdetweil @Dinschal
        @dinschal said in Are you tired of editing config.js, or have trouble doing it, see my new module:
        I tired to read the error message but its to tiny the only thing i can read is localhost
        what error message?
        u mean the module output when address:“localhost” is set??
        localhost means ONLY apps running inside the SAME system can access
        so a phone (use the qr code) , or another computer (use the url) cannot…
          Dinschal @sdetweil
          @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
          I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
            sdetweil @Dinschal
            @dinschal also have to edit the ipWhitelist.
            I set it to []
            ipWhitelist:[],
              Dinschal @sdetweil
              @sdetweil i did it let me check ;)
              okay i got it… but now i only have the "configuration window without the possibility to configure,
              i tryed it with a new pull and an new installation of your module :(
              • A
                Alyx
                amazing work!!! are users able to make module communicate with each other? Such as using voice commands to use another module via notifications?
                  sdetweil @Alyx
                  @alyx I don’t understand your question
                    sdetweil @Dinschal
                    @dinschal is this from the qr?
                    or did u enter a url?
                    note the url is
                    http://mmipaddr:mmport/modules/MMM-Config/review
                      sdetweil @Alyx
                      @alyx voiceCommander is built on top of MMM-Voice and Hello-Lucy
                      so, CAN you, certainly… take a voice audio -> recognizer -> send notification to other modules…
                      HOW depends on the module being used…
                      sometimes there is some config
                      sometimes there is file editing
                      sometimes there is coding
                      • A
                        Alyx @sdetweil
                        @sdetweil No worries I’ll install and play around with this tomorrow, I was wondering if it would help with setting up modules to talk to each other, as you know I’ve been having a few issues with that xD
                          sdetweil @Alyx
                          @alyx My Module ONLY addresses configuration of EACH module (stuff that goes in config.js)
                          what that stuff DOES/MEANS, my module does not know…
                          I read the source code to figure out the variables defined
                          and merge that with any info from config.js
                          and build a form to collect the data
                          then on save, I take the elements with data and build a new config.js
                          (rename the old and write the new)
                          and if restart , then I restart MM to use that new config
                          • A
                            Alyx @sdetweil
                            @sdetweil Sounds great as is Sam cant wait to try it tomorrow!
                              Dinschal @sdetweil
                              @sdetweil ah okay i used the wrong one… i used the one with config.html
                                Dinschal
                                Is it possible to add a css section in the future? that would be really nice…
                                thanks for your work and thanks for helping me ;)
                                  Dinschal
                                  @sdetweil your module is running well, but if i changed something and create the config, it deleted the location, the locationid and the weather api from the default weather module :( this is really bad… and if i change the timefomat and the analog size in the same module and push the save, create config button it didnt save the canges.
                                    sdetweil @Dinschal
                                    @dinschal what do u mean css section?
                                    D S 2 Replies Last reply Reply Quote 0
                                      Dinschal @sdetweil
                                      @sdetweil first off all good morning ;)
                                      a section where you can edit the css sections of the modules… like the size or something else…
                                        sdetweil @Dinschal
                                        @dinschal did u set the position in the positions section?
                                        can u add debug:true to my module config
                                        copy back the prior config.js
                                        start mm like this
                                        npm start >somefile.txt
                                        then do the change again
                                        press save
                                        then stop mm (ctrl-q)
                                        and send me the somefile.txt
                                        and the two config file, prior and new
                                        and the defaults.js from the module folder
                                        via email. my email is this same userid at gmail
                                        u will have to rename the .js files to
                                        like .txt as js files are not allowed
                                          sdetweil @Dinschal
                                          @dinschal ah, I think that would be very difficult.
                                          unless it was a text box w the same thing u would put in custom.css
                                            @sdetweil one thing on position.
                                            I write them out in the same order by
                                            position:
                                            all the top_left together, then the top_right, etc
                                            using the module position order value, u can adjust the order of a module in a position list
                                            ( I add order: to the module info, so I can continue to keep them that way)
                                            as mm shows them that way
                                            they may NOT be in the same location( line number) in the new file
                                            • 14
                                            • 15
                                            • 6 / 15
