    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
    • A
      Alyx @sdetweil
      @sdetweil Sounds great as is Sam cant wait to try it tomorrow!
        Dinschal @sdetweil
        @sdetweil ah okay i used the wrong one… i used the one with config.html
          Dinschal
          Is it possible to add a css section in the future? that would be really nice…
          thanks for your work and thanks for helping me ;)
            Dinschal
            @sdetweil your module is running well, but if i changed something and create the config, it deleted the location, the locationid and the weather api from the default weather module :( this is really bad… and if i change the timefomat and the analog size in the same module and push the save, create config button it didnt save the canges.
              sdetweil @Dinschal
              @dinschal what do u mean css section?
              D S 2 Replies Last reply Reply Quote 0
                Dinschal @sdetweil
                @sdetweil first off all good morning ;)
                a section where you can edit the css sections of the modules… like the size or something else…
                  sdetweil @Dinschal
                  @dinschal did u set the position in the positions section?
                  can u add debug:true to my module config
                  copy back the prior config.js
                  start mm like this
                  npm start >somefile.txt
                  then do the change again
                  press save
                  then stop mm (ctrl-q)
                  and send me the somefile.txt
                  and the two config file, prior and new
                  and the defaults.js from the module folder
                  via email. my email is this same userid at gmail
                  u will have to rename the .js files to
                  like .txt as js files are not allowed
                    sdetweil @Dinschal
                    @dinschal ah, I think that would be very difficult.
                    unless it was a text box w the same thing u would put in custom.css
                      @sdetweil one thing on position.
                      I write them out in the same order by
                      position:
                      all the top_left together, then the top_right, etc
                      using the module position order value, u can adjust the order of a module in a position list
                      ( I add order: to the module info, so I can continue to keep them that way)
                      as mm shows them that way
                      they may NOT be in the same location( line number) in the new file
                        Dinschal @sdetweil
                        @sdetweil you got mail ;)
                          sdetweil @Dinschal
                          @dinschal I replied
                            Dinschal @sdetweil
                            @sdetweil yeah i have to search the right one :D
                            • A
                              Alyx
                              Hi Sam,
                              I installed this just there on a fresh image and MM install. All good except my web-view is blank. Well the title comes up with the light brown background but there’s no content beyond that.
                              Do I need to begin installing other modules in tandem with this?
                                sdetweil @Alyx
                                @alyx no… should work as is for the defaults…
                                let me look
                                • A
                                  Alyx @sdetweil
                                  @sdetweil Sure what file/ image do you want to see?
                                    sdetweil @Alyx
                                    @alyx hang on… let me test here… I am working on other fixes…
                                    • A
                                      Alyx @sdetweil
                                      @sdetweil no worries cheers buddy lemme know if you need anything
                                        sdetweil @Alyx
                                        @alyx did you do the npm install in the module folder?? I need libs installed
                                        http://mmip:mmport/modules/MMM-Config/review
                                        I got
                                        • A
                                          Alyx @sdetweil
                                          @sdetweil Yep I did it within the MMM-Config directory, did it again there with no luck. Got some audit issues for npm but nothing big
                                          A S 2 Replies Last reply Reply Quote 0
                                          • A
                                            Alyx @Alyx
                                            @alyx actually i had a harder look, does this seem important?
                                            smartmirror@smartmirror-ThinkCentre-M72e:~/MagicMirror/modules/MMM-Config$ sudo npm install
                                            npm WARN lifecycle mmm-config@1.0.0~postinstall: cannot run in wd mmm-config@1.0.0 node exec_script.js ./postinstall:postinstall.cmd (wd=/home/smartmirror/MagicMirror/modules/MMM-Config)
                                            npm WARN mmm-config@1.0.0 No repository field.
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
                                            audited 136 packages in 1.22s
                                            7 packages are looking for funding
                                            run npm fund for details
                                            found 3 moderate severity vulnerabilities
                                            run npm audit fix to fix them, or npm audit for details
                                            • 14
                                            • 15
                                            • 6 / 15
