    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 480.4k Views 31 Watching
      Dinschal @sdetweil
      @sdetweil yeah this one ;) i want to change it cause the mirror is a gift for my parents and if i had to change something i only have my phone.
      I changed it to 0.0.0.0 so i get the qr but know my device is not allowed to access my mirror :D
        sdetweil @Dinschal
        @dinschal also have to edit the ipWhitelist.
        I set it to []
        ipWhitelist:[],
          Dinschal @sdetweil
          @sdetweil i did it let me check ;)
          okay i got it… but now i only have the "configuration window without the possibility to configure,
          i tryed it with a new pull and an new installation of your module :(
          • A
            Alyx
            amazing work!!! are users able to make module communicate with each other? Such as using voice commands to use another module via notifications?
              sdetweil @Alyx
              @alyx I don’t understand your question
                sdetweil @Dinschal
                @dinschal is this from the qr?
                or did u enter a url?
                note the url is
                http://mmipaddr:mmport/modules/MMM-Config/review
                  sdetweil @Alyx
                  @alyx voiceCommander is built on top of MMM-Voice and Hello-Lucy
                  so, CAN you, certainly… take a voice audio -> recognizer -> send notification to other modules…
                  HOW depends on the module being used…
                  sometimes there is some config
                  sometimes there is file editing
                  sometimes there is coding
                  • A
                    Alyx @sdetweil
                    @sdetweil No worries I’ll install and play around with this tomorrow, I was wondering if it would help with setting up modules to talk to each other, as you know I’ve been having a few issues with that xD
                      sdetweil @Alyx
                      @alyx My Module ONLY addresses configuration of EACH module (stuff that goes in config.js)
                      what that stuff DOES/MEANS, my module does not know…
                      I read the source code to figure out the variables defined
                      and merge that with any info from config.js
                      and build a form to collect the data
                      then on save, I take the elements with data and build a new config.js
                      (rename the old and write the new)
                      and if restart , then I restart MM to use that new config
                      • A
                        Alyx @sdetweil
                        @sdetweil Sounds great as is Sam cant wait to try it tomorrow!
                          Dinschal @sdetweil
                          @sdetweil ah okay i used the wrong one… i used the one with config.html
                            Dinschal
                            Is it possible to add a css section in the future? that would be really nice…
                            thanks for your work and thanks for helping me ;)
                              Dinschal
                              @sdetweil your module is running well, but if i changed something and create the config, it deleted the location, the locationid and the weather api from the default weather module :( this is really bad… and if i change the timefomat and the analog size in the same module and push the save, create config button it didnt save the canges.
                                sdetweil @Dinschal
                                @dinschal what do u mean css section?
                                D S 2 Replies Last reply Reply Quote 0
                                  Dinschal @sdetweil
                                  @sdetweil first off all good morning ;)
                                  a section where you can edit the css sections of the modules… like the size or something else…
                                    sdetweil @Dinschal
                                    @dinschal did u set the position in the positions section?
                                    can u add debug:true to my module config
                                    copy back the prior config.js
                                    start mm like this
                                    npm start >somefile.txt
                                    then do the change again
                                    press save
                                    then stop mm (ctrl-q)
                                    and send me the somefile.txt
                                    and the two config file, prior and new
                                    and the defaults.js from the module folder
                                    via email. my email is this same userid at gmail
                                    u will have to rename the .js files to
                                    like .txt as js files are not allowed
                                      sdetweil @Dinschal
                                      @dinschal ah, I think that would be very difficult.
                                      unless it was a text box w the same thing u would put in custom.css
                                        @sdetweil one thing on position.
                                        I write them out in the same order by
                                        position:
                                        all the top_left together, then the top_right, etc
                                        using the module position order value, u can adjust the order of a module in a position list
                                        ( I add order: to the module info, so I can continue to keep them that way)
                                        as mm shows them that way
                                        they may NOT be in the same location( line number) in the new file
                                          Dinschal @sdetweil
                                          @sdetweil you got mail ;)
                                            sdetweil @Dinschal
                                            @dinschal I replied
                                            • 14
                                            • 15
                                            • 6 / 15
