    PIR Sensor: false positive detections
    18 Posts 6 Posters 10.0k Views 6 Watching
    • FoziF
      Fozi Project Sponsor @MZ-BER
      @mz-ber said in PIR Sensor: false positive detections:
      HC-SR501 PIR
      I’m with @Stefan723. I had used MMM-NewPIR in the past but switched back to MMM-PIR-Sensor again for reasons. MMM-PIR-Sensor is simple, robust and does the job reliably. May be you have some intereferences, too, which trigger false positives.
      Due to the proximity of the Vout and GND wires to the WLAN module, unwanted interferences may occur which might prevent the PIR sensor to switch from high (motion detected) to low state (no motion detected). The wires work like an antenna in that case. As a result, the display will stay on. A ferrite bead attached to those wires, e.g. taken from an old VGA cable, reduces the interferences and allows for correct state change.
      Hope that helps.
      Z 1 Reply Last reply
      • Z
        Zoltan @Fozi
        @fozi I also had false triggers. It turned out that my PIR was too close to my Pi and the WiFi chip induced EMF into the PIR. By moving the PIR further away and introducing a low pass filter i solved my issue. Have a look at my circuit and comments
        https://forum.magicmirror.builders/topic/15458/smartmirror-dashboard
        FoziF MZ-BERM 2 Replies Last reply
        • FoziF
          Fozi Project Sponsor @Zoltan
          @zoltan Really nice build!Congrats!
          Yeah, a low-pass filter can solve the interferences from the WiFi module, too, of course. But due to my lazyness and impatience I sacrificed an old VGA cable and re-used the ferrite bead:beaming_face_with_smiling_eyes:
          • MZ-BERM
            MZ-BER
            Hey folks - thanks for your answers. I decided to goahed with a RCWL-0516. But have the same issues. I’m testing the sensitivity with a python script. I also covered it in alu foil - no change. Now I ordered a ferrite beat and will add to the cables (around all of the them or only GND, 5v or Output?)
            I’m also thinking about adding a low pass filter, but I have no experience with that. Where do I have to add that? GND & Output?
            FoziF 1 Reply Last reply
            • FoziF
              @mz-ber Just put all wires through the bead.
              With the RCWL-0516 you should note that they can be very sensitive (up to 7m on free sight) and detect motion even through walls. First I went the alu foil route, too, but then modded my RCWL-0516 with a trimmer. Now the mirror is triggered when I approach the mirror less than 1m. Check the link in my signature for details, if you like.
              MZ-BERM 1 Reply Last reply
              • MZ-BERM
                MZ-BER @Fozi
                @fozi Yes! I followed your instructions in detail - that was very helpful. And yes, I noticed how sensitive it is. In your tutorial you removed the the tiny SMD resistor soldered and replaced that. What if I just remove it and not replace it. Is the range than completely gone and doesent work anymore?
                • MZ-BERM
                  MZ-BER @Zoltan
                  Hi @zoltan - I was reviewing your tutorial. Really good documented. I have a question about the wiring drawing you shared. I’m new to it and dont understand everything. But I’m a fast learner :-)
                  In your drawing you added a couple of symbols. I guess these are resistors and filters, right?
                  Numbers 1, 2 and 3 look similar, only with a diffrent capacity. Is that a Capacitor?
                  What are 4 and 5? Is that a conductor? What capacity is here needed?
                  And number 6, not sure. Is that a RND or a resistor?
                  Z 2 Replies Last reply
                  • FoziF
                    @mz-ber If you remove the resistor completely without any replacement the sensor won’t work any more.
                    • thgmirrorT
                      thgmirror
                      Didn’t I said, I’m not an electrician?
                      It is not a step-down/up … it is called Pull-Up, resp Pull-Down.
                      Please see here for detailed (german) explanation: https://www.elektronik-kompendium.de/sites/raspberry-pi/2006051.htm
                      MZ-BERM FoziF 2 Replies Last reply
                      • MZ-BERM
                        MZ-BER @thgmirror
                        @thgmirror Yep, that is what I’ll do next. Already ordered a starter kit with resistors, inductors and capacitors.
                        I also noticed, even if I added the ferrite beat, that the sensor recevied every minute excact on the second a signal
                        • FoziF
                          Fozi Project Sponsor @thgmirror
                          @thgmirror said in PIR Sensor: false positive detections:
                          Are you dealing with 3D printing? Just asking, because step-down converters are quite popular for modding cooling fans in that hobby :beaming_face_with_smiling_eyes:
                          thgmirrorT 1 Reply Last reply
                          • thgmirrorT
                            thgmirror @Fozi
                            @fozi no, currently no 3D-printing, but may be in the future:-)
                            • Z
                              Zoltan @MZ-BER
                              @mz-ber
                              Apologies for the late response
                              1, 2 and 3 is capacitors yes
                              4 & 5 is inductors or coils. The rule is a Capacitor conduct high frequency but block low frequency. The coil or inductor is doing the opposite, and conduct low frequency but block high frequency. The whole idea is to short circuit any spikes on the power line as well as the data line to ground. This is quite a big low pass filter and you can make it smaller with less components.
                              Remove 1
                              Leave 4 & 2
                              Replace 5 with a wire
                              6 is a resister yes. 10 Kilo Ohm 1/4 watt is perfect
                              The coils you can strip out of an old circuit board. If it looks like a wire wind coil and it measure less than 3 ohm then its perfect
                              • Z
                                Zoltan @MZ-BER
                                @mz-ber
                                The controller board with the low pass filter
