    PIR Sensor: false positive detections
    18 Posts 6 Posters 10.0k Views 6 Watching
    • MZ-BERM
      MZ-BER
      Hey folks - thanks for your answers. I decided to goahed with a RCWL-0516. But have the same issues. I’m testing the sensitivity with a python script. I also covered it in alu foil - no change. Now I ordered a ferrite beat and will add to the cables (around all of the them or only GND, 5v or Output?)
      I’m also thinking about adding a low pass filter, but I have no experience with that. Where do I have to add that? GND & Output?
      • FoziF
        Fozi Project Sponsor @MZ-BER
        @mz-ber Just put all wires through the bead.
        With the RCWL-0516 you should note that they can be very sensitive (up to 7m on free sight) and detect motion even through walls. First I went the alu foil route, too, but then modded my RCWL-0516 with a trimmer. Now the mirror is triggered when I approach the mirror less than 1m. Check the link in my signature for details, if you like.
        MZ-BERM 1 Reply Last reply Reply Quote 0
        • MZ-BERM
          MZ-BER @Fozi
          @fozi Yes! I followed your instructions in detail - that was very helpful. And yes, I noticed how sensitive it is. In your tutorial you removed the the tiny SMD resistor soldered and replaced that. What if I just remove it and not replace it. Is the range than completely gone and doesent work anymore?
          • MZ-BERM
            MZ-BER @Zoltan
            Hi @zoltan - I was reviewing your tutorial. Really good documented. I have a question about the wiring drawing you shared. I’m new to it and dont understand everything. But I’m a fast learner :-)
            In your drawing you added a couple of symbols. I guess these are resistors and filters, right?
            Numbers 1, 2 and 3 look similar, only with a diffrent capacity. Is that a Capacitor?
            What are 4 and 5? Is that a conductor? What capacity is here needed?
            And number 6, not sure. Is that a RND or a resistor?
            Z 2 Replies Last reply Reply Quote 0
            • FoziF
              @mz-ber If you remove the resistor completely without any replacement the sensor won’t work any more.
              • thgmirrorT
                thgmirror
                Didn’t I said, I’m not an electrician?
                It is not a step-down/up … it is called Pull-Up, resp Pull-Down.
                Please see here for detailed (german) explanation: https://www.elektronik-kompendium.de/sites/raspberry-pi/2006051.htm
                MZ-BERM FoziF 2 Replies Last reply Reply Quote 1
                • MZ-BERM
                  MZ-BER @thgmirror
                  @thgmirror Yep, that is what I’ll do next. Already ordered a starter kit with resistors, inductors and capacitors.
                  I also noticed, even if I added the ferrite beat, that the sensor recevied every minute excact on the second a signal
                  • FoziF
                    Fozi Project Sponsor @thgmirror
                    @thgmirror said in PIR Sensor: false positive detections:
                    Are you dealing with 3D printing? Just asking, because step-down converters are quite popular for modding cooling fans in that hobby :beaming_face_with_smiling_eyes:
                    thgmirrorT 1 Reply Last reply Reply Quote 0
                    • thgmirrorT
                      thgmirror @Fozi
                      @fozi no, currently no 3D-printing, but may be in the future:-)
                      • Z
                        Zoltan @MZ-BER
                        @mz-ber
                        Apologies for the late response
                        1, 2 and 3 is capacitors yes
                        4 & 5 is inductors or coils. The rule is a Capacitor conduct high frequency but block low frequency. The coil or inductor is doing the opposite, and conduct low frequency but block high frequency. The whole idea is to short circuit any spikes on the power line as well as the data line to ground. This is quite a big low pass filter and you can make it smaller with less components.
                        Remove 1
                        Leave 4 & 2
                        Replace 5 with a wire
                        6 is a resister yes. 10 Kilo Ohm 1/4 watt is perfect
                        The coils you can strip out of an old circuit board. If it looks like a wire wind coil and it measure less than 3 ohm then its perfect
                        • Z
                          Zoltan @MZ-BER
                          @mz-ber
                          The controller board with the low pass filter
