    PIR Sensor: false positive detections
    18 Posts 6 Posters 7.8k Views 6 Watching
    • thgmirrorT Offline
      thgmirror @Stefan723
      @stefan723 May be, a so called “Step Down” resp. “Step Up”-resistor is needed. The PI has built-in Step Down/Up functionality.
      The issue may arise due to interferencies from other parts around the sensor and the PI. First follow the idea of @Stefan723 and try to use short cables.
      Use Google to search for “Step Down/Up and Raspberry PI”.
      But I’m a programmer…not an electrician:-)
        philmavedzenge
        I had the same issue for some time, it turned out to be the time in between detections was too long. the sensor would detect movement and keep that state until the set time and then checks again. Play around with adjusting one of the orange screws on the sensor until the detection time is very low.
        • FoziF Offline
          Fozi Project Sponsor @MZ-BER
          @mz-ber said in PIR Sensor: false positive detections:
          HC-SR501 PIR
          I’m with @Stefan723. I had used MMM-NewPIR in the past but switched back to MMM-PIR-Sensor again for reasons. MMM-PIR-Sensor is simple, robust and does the job reliably. May be you have some intereferences, too, which trigger false positives.
          Due to the proximity of the Vout and GND wires to the WLAN module, unwanted interferences may occur which might prevent the PIR sensor to switch from high (motion detected) to low state (no motion detected). The wires work like an antenna in that case. As a result, the display will stay on. A ferrite bead attached to those wires, e.g. taken from an old VGA cable, reduces the interferences and allows for correct state change.
          Hope that helps.
          Z 1 Reply Last reply Reply Quote 0
          • Z Offline
            Zoltan @Fozi
            @fozi I also had false triggers. It turned out that my PIR was too close to my Pi and the WiFi chip induced EMF into the PIR. By moving the PIR further away and introducing a low pass filter i solved my issue. Have a look at my circuit and comments
            https://forum.magicmirror.builders/topic/15458/smartmirror-dashboard
            FoziF MZ-BERM 2 Replies Last reply Reply Quote 0
            • FoziF Offline
              Fozi Project Sponsor @Zoltan
              @zoltan Really nice build!Congrats!
              Yeah, a low-pass filter can solve the interferences from the WiFi module, too, of course. But due to my lazyness and impatience I sacrificed an old VGA cable and re-used the ferrite bead:beaming_face_with_smiling_eyes:
              • MZ-BERM Offline
                MZ-BER
                Hey folks - thanks for your answers. I decided to goahed with a RCWL-0516. But have the same issues. I’m testing the sensitivity with a python script. I also covered it in alu foil - no change. Now I ordered a ferrite beat and will add to the cables (around all of the them or only GND, 5v or Output?)
                I’m also thinking about adding a low pass filter, but I have no experience with that. Where do I have to add that? GND & Output?
                • FoziF Offline
                  @mz-ber Just put all wires through the bead.
                  With the RCWL-0516 you should note that they can be very sensitive (up to 7m on free sight) and detect motion even through walls. First I went the alu foil route, too, but then modded my RCWL-0516 with a trimmer. Now the mirror is triggered when I approach the mirror less than 1m. Check the link in my signature for details, if you like.
                  MZ-BERM 1 Reply Last reply Reply Quote 0
                  • MZ-BERM Offline
                    MZ-BER @Fozi
                    @fozi Yes! I followed your instructions in detail - that was very helpful. And yes, I noticed how sensitive it is. In your tutorial you removed the the tiny SMD resistor soldered and replaced that. What if I just remove it and not replace it. Is the range than completely gone and doesent work anymore?
                    • MZ-BERM Offline
                      MZ-BER @Zoltan
                      Hi @zoltan - I was reviewing your tutorial. Really good documented. I have a question about the wiring drawing you shared. I’m new to it and dont understand everything. But I’m a fast learner :-)
                      In your drawing you added a couple of symbols. I guess these are resistors and filters, right?
                      Numbers 1, 2 and 3 look similar, only with a diffrent capacity. Is that a Capacitor?
                      What are 4 and 5? Is that a conductor? What capacity is here needed?
                      And number 6, not sure. Is that a RND or a resistor?
                      Z 2 Replies Last reply Reply Quote 0
                      • FoziF Offline
                        @mz-ber If you remove the resistor completely without any replacement the sensor won’t work any more.
