      Mykle1 Project Sponsor Module Developer @Lagmin
      @Lagmin
      Yes, understood. I’m using my darksky api key until it is no longer valid. Like you, my OpenWeather api key doesn’t show the 4 day forecast. I spoke with the author and he is extremely busy with work so he doesn’t have much time to troubleshoot his modules. You can fork the repo and fix it if you like. :-)
        sdetweil @Mykle1
        @Mykle1 yeh hourly for 4 days, or daily for 7 days are in the openweather free apikey access, but ONLY by using the one all api
          Yes, I know. I’m using it in my MMM-BMW-OW module. :-)
            sdetweil @Mykle1
            @Mykle1 I know. we did it at the same time.
            was adding info for others
              majdzik84 @Pielo
              @Pielo how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt
                msulzer
                Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?
                • cowboysdudeC Offline
                  cowboysdude Module Developer @msulzer
                  @msulzer Anything is possible LOL Just go in and edit them out of the getDom section then they can’t show.
                  If you need help let me know. I can whittle it down for you, PM me ;)
                  • N Offline
                    n0v4
                    Dear cowboysdude,
                    thanks a lot for the great Module. I’m trying to implement it.
                    Just to know…totally new to it.
                    Full install and config added. But now the MagicMirror staies black completally.
                    When i remove the config information, the Mirror is working nomarlly.
                    Has this to do with the API’s?
                    Thanks for your help.
                      sdetweil @n0v4
                      @n0v4 probably this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                      • N Offline
                        n0v4 @sdetweil
                        @sdetweil thanks for your link.
                        but the Mirror is working without the MMM-NOAA-Another Weather Module activated.
                        As soons as i activate it, the screen stayes black.
                        in the link i couldn’t find any solution.
                        Any other ideas?
                        Thanks.
                          sdetweil @n0v4
                          @n0v4 the topic posted defined work for you to do
                          when the screen is black, what do the messages say in the place u start MM.
                          either npm start or
                          pm2
                          if pm2, then pm2 logs --lines=nnn show the results (nnn= number, default 15)
                          • N Offline
                            n0v4 @sdetweil
                            sorry…like i’ve said…totally new to the topic.
                            i’m i right:
                            /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                            0|MagicMir | at require (internal/modules/cjs/helpers.js:88:18)
                            0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:8:15)
                            0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1078:30)
                            0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
                            0|MagicMir | code: ‘MODULE_NOT_FOUND’,
                            0|MagicMir | requireStack: [
                            0|MagicMir | ‘/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js’,
                            0|MagicMir | ‘/home/pi/MagicMirror/js/app.js’,
                            0|MagicMir | ‘/home/pi/MagicMirror/js/electron.js’,
                            0|MagicMir | ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                            0|MagicMir | undefined
                            0|MagicMir | ]
                            0|MagicMir | }
                            0|MagicMir | [29.11.2021 23:32.46.509] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|MagicMir | [29.11.2021 23:32.46.510] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              sdetweil @n0v4
                              @n0v4 said in MMM-NOAA - Another Weather Module:
                              so, it IS the issue of the topic… u need to get a few more lines of output to identify the missing library
                              –lines=50
                              • N Offline
                                n0v4 @sdetweil
                                i went throu the link you’ve send before.
                                got the information “missing module request”.
                                just finished npm install request…all’s working.
                                Great thanks a lot
                                • 31
                                • 32
                                • 33
                                • 34
                                • 35
                                • 35 / 35
