      Mykle1 Project Sponsor Module Developer @Lagmin
      @Lagmin said in MMM-NOAA - Another Weather Module:
      Do you know maybe what can be a solution to my problem showing only 3 results, please?
      Have you installed the dependencies?
      • L Offline
        Lagmin @Mykle1
        @Mykle1 Ok, I got it, it is “working”.
        I used this simple config:
           module: 'MMM-NOAA3',
        position: 'top_left',
               provider: "must be in quotes", // From list above
               apiKey: "YOUR API KEY",        // From one of the providers listed above
               airKey: "YOUR API KEY",
               css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
           userlat: "xxxx", //MUST HAVE BOTH
               userlon: "xxxx"  //MUST HAVE BOTH
        But:
        1. I don’t have % for Humidity, inHg for Pressure…
        2. How I can translate WIND? I don’t have it in translation file (same for AQI, UV).
        3. I don’t have forecast for 4 days below.
        Do you know what can be the problem?
          @Lagmin
          I’m guessing that the data is not complete for all locations so you may not see % for Humidity, inHg for Pressure… or that information is not present in the data (for some reason).
          You can add “Wind” to the translation file of your language and put in the translation. I’ve given an example below. Then send a PR to the author and he will add it to the repo.
          "Sun":"Sun",
          "No Wind": "No Wind",
          "Wind": "Yours",
          "Humidity": "Humidity",
            @Lagmin
            Just spoke with the author. Some of the providers are not supplying the data they once were or they’ve changed the way they provide the data. This module uses several different providers so try another one and see if you get better results.
            Keeping this module functioning using all the different providers must be a monumental task. It may take a long time for the author to fix any of it, assuming he has the time.
            • L Offline
              Lagmin @Mykle1
              @Mykle1 Well I tried changing coordinates for our capital city of Poland - Warsaw, but it is still not showing forecast. I also tried to change for weatherbit (previously used openweather) but with weatherbit it doesn’t even show forecast - (Prognoza na 4 dni).
                @Lagmin
                Yes, understood. I’m using my darksky api key until it is no longer valid. Like you, my OpenWeather api key doesn’t show the 4 day forecast. I spoke with the author and he is extremely busy with work so he doesn’t have much time to troubleshoot his modules. You can fork the repo and fix it if you like. :-)
                  sdetweil @Mykle1
                  @Mykle1 yeh hourly for 4 days, or daily for 7 days are in the openweather free apikey access, but ONLY by using the one all api
                    Yes, I know. I’m using it in my MMM-BMW-OW module. :-)
                      sdetweil @Mykle1
                      @Mykle1 I know. we did it at the same time.
                      was adding info for others
                        majdzik84 @Pielo
                        @Pielo how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt
                          msulzer
                          Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?
                          • cowboysdudeC Offline
                            cowboysdude Module Developer @msulzer
                            @msulzer Anything is possible LOL Just go in and edit them out of the getDom section then they can’t show.
                            If you need help let me know. I can whittle it down for you, PM me ;)
                            • N Offline
                              n0v4
                              Dear cowboysdude,
                              thanks a lot for the great Module. I’m trying to implement it.
                              Just to know…totally new to it.
                              Full install and config added. But now the MagicMirror staies black completally.
                              When i remove the config information, the Mirror is working nomarlly.
                              Has this to do with the API’s?
                              Thanks for your help.
                                sdetweil @n0v4
                                @n0v4 probably this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                                • N Offline
                                  n0v4 @sdetweil
                                  @sdetweil thanks for your link.
                                  but the Mirror is working without the MMM-NOAA-Another Weather Module activated.
                                  As soons as i activate it, the screen stayes black.
                                  in the link i couldn’t find any solution.
                                  Any other ideas?
                                  Thanks.
                                    sdetweil @n0v4
                                    @n0v4 the topic posted defined work for you to do
                                    when the screen is black, what do the messages say in the place u start MM.
                                    either npm start or
                                    pm2
                                    if pm2, then pm2 logs --lines=nnn show the results (nnn= number, default 15)
                                    • N Offline
                                      n0v4 @sdetweil
                                      sorry…like i’ve said…totally new to the topic.
                                      i’m i right:
                                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                      0|MagicMir | at require (internal/modules/cjs/helpers.js:88:18)
                                      0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:8:15)
                                      0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1078:30)
                                      0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
                                      0|MagicMir | code: ‘MODULE_NOT_FOUND’,
                                      0|MagicMir | requireStack: [
                                      0|MagicMir | ‘/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js’,
                                      0|MagicMir | ‘/home/pi/MagicMirror/js/app.js’,
                                      0|MagicMir | ‘/home/pi/MagicMirror/js/electron.js’,
                                      0|MagicMir | ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                                      0|MagicMir | undefined
                                      0|MagicMir | ]
                                      0|MagicMir | }
                                      0|MagicMir | [29.11.2021 23:32.46.509] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [29.11.2021 23:32.46.510] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        sdetweil @n0v4
                                        @n0v4 said in MMM-NOAA - Another Weather Module:
                                        so, it IS the issue of the topic… u need to get a few more lines of output to identify the missing library
                                        –lines=50
                                        • N Offline
                                          n0v4 @sdetweil
                                          i went throu the link you’ve send before.
                                          got the information “missing module request”.
                                          just finished npm install request…all’s working.
                                          Great thanks a lot
                                          • 31
                                          • 32
                                          • 33
                                          • 34
                                          • 35
                                          • 35 / 35
