    690 Posts 77 Posters 3.0m Views 70 Watching
      Yes, I know. I’m using it in my MMM-BMW-OW module. :-)
        sdetweil @Mykle1
        @Mykle1 I know. we did it at the same time.
        was adding info for others
          majdzik84 @Pielo
          @Pielo how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt
            msulzer
            Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?
            • cowboysdudeC Offline
              cowboysdude Module Developer @msulzer
              @msulzer Anything is possible LOL Just go in and edit them out of the getDom section then they can’t show.
              If you need help let me know. I can whittle it down for you, PM me ;)
              • N Offline
                n0v4
                Dear cowboysdude,
                thanks a lot for the great Module. I’m trying to implement it.
                Just to know…totally new to it.
                Full install and config added. But now the MagicMirror staies black completally.
                When i remove the config information, the Mirror is working nomarlly.
                Has this to do with the API’s?
                Thanks for your help.
                  sdetweil @n0v4
                  @n0v4 probably this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                  • N Offline
                    n0v4 @sdetweil
                    @sdetweil thanks for your link.
                    but the Mirror is working without the MMM-NOAA-Another Weather Module activated.
                    As soons as i activate it, the screen stayes black.
                    in the link i couldn’t find any solution.
                    Any other ideas?
                    Thanks.
                      sdetweil @n0v4
                      @n0v4 the topic posted defined work for you to do
                      when the screen is black, what do the messages say in the place u start MM.
                      either npm start or
                      pm2
                      if pm2, then pm2 logs --lines=nnn show the results (nnn= number, default 15)
                      • N Offline
                        n0v4 @sdetweil
                        sorry…like i’ve said…totally new to the topic.
                        i’m i right:
                        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                        0|MagicMir | at require (internal/modules/cjs/helpers.js:88:18)
                        0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:8:15)
                        0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1078:30)
                        0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
                        0|MagicMir | code: ‘MODULE_NOT_FOUND’,
                        0|MagicMir | requireStack: [
                        0|MagicMir | ‘/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js’,
                        0|MagicMir | ‘/home/pi/MagicMirror/js/app.js’,
                        0|MagicMir | ‘/home/pi/MagicMirror/js/electron.js’,
                        0|MagicMir | ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                        0|MagicMir | undefined
                        0|MagicMir | ]
                        0|MagicMir | }
                        0|MagicMir | [29.11.2021 23:32.46.509] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|MagicMir | [29.11.2021 23:32.46.510] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          sdetweil @n0v4
                          @n0v4 said in MMM-NOAA - Another Weather Module:
                          so, it IS the issue of the topic… u need to get a few more lines of output to identify the missing library
                          –lines=50
                          • N Offline
                            n0v4 @sdetweil
                            i went throu the link you’ve send before.
                            got the information “missing module request”.
                            just finished npm install request…all’s working.
                            Great thanks a lot
                            • 31
                            • 32
                            • 33
                            • 34
                            • 35
                            • 35 / 35
