      sdetweil @Mykle1
      @Mykle1 yeh hourly for 4 days, or daily for 7 days are in the openweather free apikey access, but ONLY by using the one all api
        Yes, I know. I’m using it in my MMM-BMW-OW module. :-)
          sdetweil @Mykle1
          @Mykle1 I know. we did it at the same time.
          was adding info for others
            majdzik84 @Pielo
            @Pielo how did you make the frame with temperature and humidity? I would like to get something like this by sending data via mqtt
              msulzer
              Hi everyone, this module looks really great. Is there a possibility not to show certain items such as AQI, UV etc.?
              • cowboysdudeC Offline
                cowboysdude Module Developer @msulzer
                @msulzer Anything is possible LOL Just go in and edit them out of the getDom section then they can’t show.
                If you need help let me know. I can whittle it down for you, PM me ;)
                • N Offline
                  n0v4
                  Dear cowboysdude,
                  thanks a lot for the great Module. I’m trying to implement it.
                  Just to know…totally new to it.
                  Full install and config added. But now the MagicMirror staies black completally.
                  When i remove the config information, the Mirror is working nomarlly.
                  Has this to do with the API’s?
                  Thanks for your help.
                    sdetweil @n0v4
                    @n0v4 probably this https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later
                    • N Offline
                      n0v4 @sdetweil
                      @sdetweil thanks for your link.
                      but the Mirror is working without the MMM-NOAA-Another Weather Module activated.
                      As soons as i activate it, the screen stayes black.
                      in the link i couldn’t find any solution.
                      Any other ideas?
                      Thanks.
                        sdetweil @n0v4
                        @n0v4 the topic posted defined work for you to do
                        when the screen is black, what do the messages say in the place u start MM.
                        either npm start or
                        pm2
                        if pm2, then pm2 logs --lines=nnn show the results (nnn= number, default 15)
                        • N Offline
                          n0v4 @sdetweil
                          sorry…like i’ve said…totally new to the topic.
                          i’m i right:
                          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                          0|MagicMir | at require (internal/modules/cjs/helpers.js:88:18)
                          0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js:8:15)
                          0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1078:30)
                          0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {
                          0|MagicMir | code: ‘MODULE_NOT_FOUND’,
                          0|MagicMir | requireStack: [
                          0|MagicMir | ‘/home/pi/MagicMirror/modules/MMM-NOAA/node_helper.js’,
                          0|MagicMir | ‘/home/pi/MagicMirror/js/app.js’,
                          0|MagicMir | ‘/home/pi/MagicMirror/js/electron.js’,
                          0|MagicMir | ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                          0|MagicMir | undefined
                          0|MagicMir | ]
                          0|MagicMir | }
                          0|MagicMir | [29.11.2021 23:32.46.509] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          0|MagicMir | [29.11.2021 23:32.46.510] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            sdetweil @n0v4
                            @n0v4 said in MMM-NOAA - Another Weather Module:
                            so, it IS the issue of the topic… u need to get a few more lines of output to identify the missing library
                            –lines=50
                            • N Offline
                              n0v4 @sdetweil
                              i went throu the link you’ve send before.
                              got the information “missing module request”.
                              just finished npm install request…all’s working.
                              Great thanks a lot
                              • 31
                              • 32
                              • 33
                              • 34
                              • 35
                              • 35 / 35
