Trying to write my own Module...
Hi all,
I am trying to write my own module from scratch and I am a bit of a crossroads of confusion. I have attached my .js code and my .css code is below. I am stuck trying to tie it all together. I have the output from a generic API call to the website I am getting data from, and I have a basic .js and .css file. However, with my lack of javascript experience, I am having trouble getting to the next level.
The first basic thing I am trying to do is to display the current Watts that is output from the API call (the output of the call is shown below). I have the basic format of the .js file, and a basic format for my .css file. I was wondering if anyone can take a look at my .js file and let me know what else is needed in order to get something basic working (like just displaying the wattage).
My .css file only contains the following:
.watts { font-size: 75%; line-height: 65px; display: inline-block; }The non-JSON format when I go to the following website (https://api.emonitor.us/location/getCurrentData?security_key=xxxxx) is as follows:
<GetCurrentData> <Location Location="2744"> <name>Home</name> <address>REDACTED</address> <city>REDACTED</city> <state>REDACTED</state> <country>USA</country> <zip>REDACTED</zip> <timezone>REDACTED</timezone> <data> <channelData> <channel channel="194882"> <channelNumber>1 + 2</channelNumber> <eMonitorSerial>14881</eMonitorSerial> <name>Main Power Main Panel</name> <circuitType>Mains</circuitType> <phase/> <CTSize>150</CTSize> <BreakerSize>200</BreakerSize> <timestamp>2016-12-22 15:54:00</timestamp> <watts>-9</watts> </channel> <channel channel="194886"> <channelNumber>5</channelNumber> <eMonitorSerial>14881</eMonitorSerial> <name>West Solar 1</name> <circuitType>Solar Panels</circuitType> <phase/> <CTSize>20</CTSize> <BreakerSize>20</BreakerSize> <timestamp>2016-12-22 15:54:00</timestamp> <watts>-165</watts> </channel> <channel channel="194887"> <channelNumber>6</channelNumber> <eMonitorSerial>14881</eMonitorSerial> <name>West Solar 2</name> <circuitType>Solar Panels</circuitType> <phase/> <CTSize>20</CTSize> <BreakerSize>20</BreakerSize> <timestamp>2016-12-22 15:54:00</timestamp> <watts>-143</watts> </channel> <channel channel="194888"> <channelNumber>7</channelNumber> <eMonitorSerial>14881</eMonitorSerial> <name>Both Bathroom Outlets</name> <circuitType>Outlets/Lighting</circuitType> <phase/> <CTSize>20</CTSize> <BreakerSize>20</BreakerSize> <timestamp>2016-12-22 15:54:00</timestamp> <watts>0</watts> </channel> <channel channel="194889"> <channelNumber>8</channelNumber> <eMonitorSerial>14881</eMonitorSerial> <name>1st Floor Lights</name> <circuitType>Lighting</circuitType> <phase/> <CTSize>20</CTSize> <BreakerSize>15</BreakerSize> <timestamp>2016-12-22 15:54:00</timestamp> <watts>0</watts> </channel> </channelData> </data> </Location> <totalRecords>107</totalRecords> </GetCurrentData>Thanks for looking!
The .js file I have written so far is below:
Module.register ("MMM-EMonitor", { //default module config. defaults: { // Insert defaults here interval: 900000 // Every 15 mins }, getStyles: function() { return ["MMM-Emonitor.css"]; }, // Define the start sequence start: function() { Log.info("Starting module: " + this.name); this.securitykey = REDACTED; this.url = 'https://api.emonitor.us/location/getCurrentData?security_key=' + this.SecurityKey this.getCurrentData(this); }, getCurrentData: function(that) { that.sendSocketNotification('GET-CURRENT-DATA', that.url); setTimeout(that.getCurrentData, that.config.interval, that); }, getDom: function() { var wrapper = null; if (this.loaded) { wrapper = document.createElement('div'); wrapper.className = 'data table'; -
Can you paste your MMM-Emonitor.js using markdown? It looks like you’re missing a bunch of code.
So the API sends you XML data and you want to pull out the wattage? Just the first one or all of them?
@mochman
Thanks for the link to the markdown page! My OP is edited accordingly. I do understand that I’m missing necessary code in order to make it function. I’m just not really sure what.I would like to print the
<name>and<watts>if possible. The XML returned has a lot more data, but for the sake of this post, I cut it down to just include the first three items. I would like to print all three. -
Your code seems to abruptly end in the middle of the
getDom()function, but from what I see, it looks like you are sending the URL to a node_helper.js that I assume will get the data you want.My recommendation would be to look at this page and see how to parse the XML to take out what you want. You then can use this data to create a simple table to display each
<name>and<watts>in thegetDom()function. I don’t think you’ll need anode_helper.jsto do this though. You can probably just do it in the main .js file. Unless you’re running into a Access-Control-Allow-Origin error. Then you can get around it by usingnode_helper.jsAnother way people have done this has been described here.
@mochman
Thanks for the response and the examples. Are some of the XML methods in the tutorial you linked to, often used in Mirror modules?I wasn’t planning on using a node_helper.js and my code does abruptly end in the middle of the
getDOM(). I got stuck when trying to find out how to extract specifics from the XML, like<name>and<watts>.Do you know of any other good module examples that would have similar XML structure, where specific objects were extracted from?
Assuming xml is the xml file you get as response from the server
var channels = xml.getElementsByTagName("channel"); for(var i = 0; i < channels.length; i++){ for(var n = 0; n < channels[i].children.length; n++){ if(channels[i].children[n].tagName === "name" || channels[i].children[n].tagName === "watts"){ console.log(channels[i].children[n].textContent); } } }will ouput
"Main Power Main Panel" "-9" "West Solar 1" "-165" "West Solar 2" "-143" "Both Bathroom Outlets" "0" "1st Floor Lights" "0" -
I am kind of in the same boat. I actually have an old JS file which would return data in JSON format using the MTA API for the MM1. This allowed me to see if my train was delayed or not before leaving the house. I am trying to figure out an easy way to port to over to the new mirror but I am not at all a JavaScript programmer. If anyone would like to have a look at the current code for the MM1 and maybe try to port it over it might help some folks who live in the NYC area. Or if anyone knows if there is a current module which takes JSON results and displays them on the screen I can try to mock that up to integrate this. Thanks!
@strawberry-3.141 Thanks for the snippet! I have a better idea of how to extract the data from the XML with your example.
If I want to simply output what you have provided in your post, would I need to simply put your snippet into my
getDom()function and add the.nameto my.cssfile (similar to how I have the.watts)?So I know that’s probably incorrect, but I just tried it and an error returned:
Cannot read property getElementsByClassName of null. I think that I am having trouble understanding how to create thedivobject for which to add in the data. -
@nbrenn post what you’ve rewritten so they can better understand where your error may be and what I do [whcn I added humidity to the stock weather app] was to look at other modules and pick it apart to see how they were using div and such for styling to better get an understanding how it fit together. These guys are awesome, they like to help!
Actually posting what you have now would help me too! :) I’m trying to create something myself.
strawberry 3.141 Project Sponsor Module Developerlast edited by strawberry 3.141 Dec 24, 2016, 10:05 AM Dec 24, 2016, 10:05 AM
@nbrenn I’m assuming that you saved your server response into this.xml
getDom: function(){ var wrapper = document.createElement("div"); if(this.xml){ var channels = this.xml.getElementsByTagName("channel"); for(var i = 0; i < channels.length; i++){ for(var n = 0; n < channels[i].children.length; n++){ if(channels[i].children[n].tagName === "name" || channels[i].children[n].tagName === "watts"){ var element = document.createElement("div"); element.classList.add(channels[i].children[n].tagName); element.innerHTML = channels[i].children[n].textContent; wrapper.appendChild(element); } } } } else { wrapper.innerHTML = "NO DATA"; } return wrapper; }this would create two
divcontainer for every channel one for thenameand the other forwatts. each of them would have the css class.nameor.watts
