    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
      sdetweil @pastormingle
      @pastormingle no, shouldn’t have to
      that error is typically from bad position:
      P 1 Reply Last reply
        pastormingle @sdetweil
        @sdetweil OK it’s working now… Thanks for all the hard work… So I unistalled the shbatm version and installed the schramkef. now it’s working fine…
          @pastormingle great… glad its working
            pastormingle
            I am trying to use the carouselId:“1” function on multiple calendars. But when in use i am getting a module load error… not sure i am doing this right…
            code_text
            ```[{name:'calendar', classes:'zoom200', position:"middle_center", carouselId:"1"} ],
            			colored: true,
                                    header: "Mikes Calendar",
            			position: "left",
                                    timeFormat: 'absolute',
                                    broadcastPastEvents: false,
                                    fade: false,
                                    showEnd: false,
                                    color: '#ffffff',
                                            carouselId:"1"
                                            tableClass: "medium",
            					  symbol: "calendar-day",
            					  url:"https://outlook.office365.com/owa/f2033a09d6504d21833241fb44df8c3c@dxc.com/a53b29290ce3e0405428856/calendar.ics"
              @sdetweil I am having an intermittent issue now with displaying my office 365 work calendar… Sometimes it comes back with an "error in calendar module check logs for more details. I don’t see anything in the development console… Any direction here, please?
                pastormingle @pastormingle
                @pastormingle i changed the time intervals on the fetch and that seems to have worked… thanks…
                  @pastormingle messages for fetching would be in the place u start mm
                  npm start or pm2
                    @sdetweil Thanks Sam…
                    Can you help me with an mmm-calendarext issue? I have a basic config for it and all I get is a blank screen… If I do console window it just hangs…
                              module: 'MMM-CalendarExt',
                              position: "center",
                          url:"https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-349ihavethisblocked/basic.ics"
                      @pastormingle see
                        @sdetweil Still not able to display… I ran the following command and it didn’t return any errors…
                        pi@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt $ npm init -y
                        Wrote to /home/pi/MagicMirror/modules/MMM-CalendarExt/package.json:
                          "name": "MMM-CalendarExt",
                          "version": "1.0.0",
                          "description": "Alternative calendar module for [MagicMirror](https://magicmirror.builders/)",
                          "main": "MMM-CalendarExt.js",
                          "scripts": {
                            "test": "echo \"Error: no test specified\" && exit 1"
                          "repository": {
                            "type": "git",
                            "url": "git+https://github.com/eouia/MMM-CalendarExt.git"
                          "keywords": [],
                          "author": "",
                          "license": "ISC",
                          "bugs": {
                            "url": "https://github.com/eouia/MMM-CalendarExt/issues"
                          "homepage": "https://github.com/eouia/MMM-CalendarExt#readme",
                          "dependencies": {
                            "all": "0.0.0"
                          "devDependencies": {}
                          @pastormingle all that does is built the empty packjson,which will be used by the
                          npm install xxx -save
                          that second step is what fixes the missing library xxx once you figure out it’s name from the log messages.
                          ps. there are more than one potential missing library… so I teach u how to find it so next time you don’t have to post here to find the fix.
                            @sdetweil guess i"m not following what the xxx file would be?
                              @pastormingle if i do a ctrl I i get the following
                                @pastormingle from the linked topic
                                then regardless do
                                npm install xxx
                                where xxx is the library noted in the message
                                cannot find module xxx
                                to find this message, look in the output of npm start. or if you use pm2 to launch mm do
                                pm2 logs --lines=50
                                __----------------
                                so you look for the message and get the name from it and replace xxx with the name
                                  @sdetweil ```
                                  pi@raspberrypi:~ $ pm2 logs --lines=50 MagicMirror
                                  [TAILING] Tailing last 50 lines for [MagicMirror] process (change the value with --lines option)
                                  /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                                  0|MagicMir | - /home/pi/MagicMirror/js/electron.js
                                  0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                  0|MagicMir | -
                                  0|MagicMir | [14.12.2021 16:02.14.185] [ERROR] App threw an error during load
                                  0|MagicMir | [14.12.2021 16:02.14.187] [ERROR] Error: Cannot find module ‘valid-url’
                                  0|MagicMir | Require stack:
                                  0|MagicMir | - /home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js
                                  0|MagicMir | - /home/pi/MagicMirror/js/app.js
                                  0|MagicMir | -
                                  0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                                  0|MagicMir | at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                                  0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                  0|MagicMir | at Module._load (internal/modules/cjs/loader.js:848:27)
                                  0|MagicMir | at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                                  0|MagicMir | at Module.require (internal/modules/cjs/loader.js:1032:19)
                                  0|MagicMir | at require (internal/modules/cjs/helpers.js:72:18)
                                  0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:3:18)
                                  0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1152:30)
                                  0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10)
                                  0|MagicMir | [14.12.2021 16:02.14.197] [ERROR] Whoops! There was an uncaught exception…
                                  0|MagicMir | [14.12.2021 16:02.14.203] [ERROR] Error: Cannot find module ‘valid-url’
                                  0|MagicMir | -
                                    @pastormingle said in MMM-Carousel not displaying:
                                    what is so hard about this?
                                      @sdetweil the module name is valid-url… i though it’s looking for a URL… http://url…
                                        @pastormingle then
                                        npm install valid-url --save
                                        in the mm module folder
                                        because xxx is valid-url in that error message
                                          @sdetweil ```
                                          ^C
                                          pi@raspberrypi:~ $ npm install valid-url --save
                                          npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                                          • valid-url@1.0.9
                                            updated 1 package and audited 964 packages in 19.443s
                                          112 packages are looking for funding
                                          run npm fund for details
                                          found 22 vulnerabilities (19 moderate, 3 high)
                                          run npm audit fix to fix them, or npm audit for details
                                          pi@raspberrypi:~ $ cd MagicMirror
                                          pi@raspberrypi:~/MagicMirror $ cd modules
                                          pi@raspberrypi:~/MagicMirror/modules $ dir
                                          Archive calendar_monthly default MMM-CalendarExt MMM-CalendarExtMinimonth MMM-CalendarExtTimeline MMM-Carousel MMM-GoogleTasks MMM-ip MMM-PaprikaMenu MMM-RAIN-MAP MMM-RAIN-MAP-L MMM-RAIN-MAPold
                                          pi@raspberrypi:~/MagicMirror/modules $ npm install valid-url --save
                                          • valid-url@1.0.9
                                            added 1 package and audited 967 packages in 20.435s
                                          found 20 vulnerabilities (18 moderate, 2 high)
                                            in the folder of the mm module having trouble
                                            • 4 / 5
