    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 69.5k Views 4 Watching
      pastormingle @sdetweil
      @sdetweil Still not able to display… I ran the following command and it didn’t return any errors…
      pi@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt $ npm init -y
      Wrote to /home/pi/MagicMirror/modules/MMM-CalendarExt/package.json:
        "name": "MMM-CalendarExt",
        "version": "1.0.0",
        "description": "Alternative calendar module for [MagicMirror](https://magicmirror.builders/)",
        "main": "MMM-CalendarExt.js",
        "scripts": {
          "test": "echo \"Error: no test specified\" && exit 1"
        "repository": {
          "type": "git",
          "url": "git+https://github.com/eouia/MMM-CalendarExt.git"
        "keywords": [],
        "author": "",
        "license": "ISC",
        "bugs": {
          "url": "https://github.com/eouia/MMM-CalendarExt/issues"
        "homepage": "https://github.com/eouia/MMM-CalendarExt#readme",
        "dependencies": {
          "all": "0.0.0"
        "devDependencies": {}
        sdetweil @pastormingle
        @pastormingle all that does is built the empty packjson,which will be used by the
        npm install xxx -save
        that second step is what fixes the missing library xxx once you figure out it’s name from the log messages.
        ps. there are more than one potential missing library… so I teach u how to find it so next time you don’t have to post here to find the fix.
          @sdetweil guess i"m not following what the xxx file would be?
            pastormingle @pastormingle
            @pastormingle if i do a ctrl I i get the following
              @pastormingle from the linked topic
              then regardless do
              npm install xxx
              where xxx is the library noted in the message
              cannot find module xxx
              to find this message, look in the output of npm start. or if you use pm2 to launch mm do
              pm2 logs --lines=50
              __----------------
              so you look for the message and get the name from it and replace xxx with the name
                @sdetweil ```
                pi@raspberrypi:~ $ pm2 logs --lines=50 MagicMirror
                [TAILING] Tailing last 50 lines for [MagicMirror] process (change the value with --lines option)
                /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                0|MagicMir | - /home/pi/MagicMirror/js/electron.js
                0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                0|MagicMir | -
                0|MagicMir | [14.12.2021 16:02.14.185] [ERROR] App threw an error during load
                0|MagicMir | [14.12.2021 16:02.14.187] [ERROR] Error: Cannot find module ‘valid-url’
                0|MagicMir | Require stack:
                0|MagicMir | - /home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js
                0|MagicMir | - /home/pi/MagicMirror/js/app.js
                0|MagicMir | -
                0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                0|MagicMir | at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                0|MagicMir | at Module._load (internal/modules/cjs/loader.js:848:27)
                0|MagicMir | at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                0|MagicMir | at Module.require (internal/modules/cjs/loader.js:1032:19)
                0|MagicMir | at require (internal/modules/cjs/helpers.js:72:18)
                0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:3:18)
                0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1152:30)
                0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10)
                0|MagicMir | [14.12.2021 16:02.14.197] [ERROR] Whoops! There was an uncaught exception…
                0|MagicMir | [14.12.2021 16:02.14.203] [ERROR] Error: Cannot find module ‘valid-url’
                0|MagicMir | -
                  @pastormingle said in MMM-Carousel not displaying:
                  what is so hard about this?
                    @sdetweil the module name is valid-url… i though it’s looking for a URL… http://url…
                      @pastormingle then
                      npm install valid-url --save
                      in the mm module folder
                      because xxx is valid-url in that error message
                        @sdetweil ```
                        ^C
                        pi@raspberrypi:~ $ npm install valid-url --save
                        npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                        • valid-url@1.0.9
                          updated 1 package and audited 964 packages in 19.443s
                        112 packages are looking for funding
                        run npm fund for details
                        found 22 vulnerabilities (19 moderate, 3 high)
                        run npm audit fix to fix them, or npm audit for details
                        pi@raspberrypi:~ $ cd MagicMirror
                        pi@raspberrypi:~/MagicMirror $ cd modules
                        pi@raspberrypi:~/MagicMirror/modules $ dir
                        Archive calendar_monthly default MMM-CalendarExt MMM-CalendarExtMinimonth MMM-CalendarExtTimeline MMM-Carousel MMM-GoogleTasks MMM-ip MMM-PaprikaMenu MMM-RAIN-MAP MMM-RAIN-MAP-L MMM-RAIN-MAPold
                        pi@raspberrypi:~/MagicMirror/modules $ npm install valid-url --save
                        • valid-url@1.0.9
                          added 1 package and audited 967 packages in 20.435s
                        found 20 vulnerabilities (18 moderate, 2 high)
                          in the folder of the mm module having trouble
                            @sdetweil ```
                            pi@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt $ npm install valid-url --save
                            • valid-url@1.0.9
                              added 1 package and audited 2 packages in 0.951s
                              found 0 vulnerabilities
                            S P 2 Replies Last reply Reply Quote 0
                              @pastormingle yes and then start MagicMirror
                              if u still get a black screen the check again…
                                @pastormingle ```
                                pi@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt $ pm2 logs --lines=50 MagicMirror
                                0|MagicMir | -
                                0|MagicMir | -
                                0|MagicMir | -
                                0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10) {
                                0|MagicMir | code: ‘MODULE_NOT_FOUND’,
                                0|MagicMir | requireStack: [
                                0|MagicMir | ‘/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js’,
                                0|MagicMir | ‘/home/pi/MagicMirror/js/app.js’,
                                0|MagicMir | ‘/home/pi/MagicMirror/js/electron.js’,
                                0|MagicMir | ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                                0|MagicMir | undefined
                                  @pastormingle that message is from
                                  16:02.14.187
                                  so not recently
                                  pm2 stop all
                                  pm2 flush
                                  pm2 start 0
                                  wait
                                  pm2 stop all
                                  pm2 logs…
                                    @sdetweil ```
                                    0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                    /home/pi/.pm2/logs/MagicMirror-out.log last 50 lines:
                                    0|MagicMir | > magicmirror@2.16.0 start /home/pi/MagicMirror
                                    0|MagicMir | > ./run-start.sh $1
                                    0|MagicMir |
                                    0|MagicMir | [14.12.2021 16:56.24.531] [LOG] Starting MagicMirror: v2.16.0
                                    0|MagicMir | [14.12.2021 16:56.24.538] [LOG] Loading config …
                                    0|MagicMir | [14.12.2021 16:56.24.545] [LOG] Loading module helpers …
                                    0|MagicMir | [14.12.2021 16:56.24.547] [LOG] No helper found for module: alert.
                                    0|MagicMir | [14.12.2021 16:56.25.838] [LOG] Initializing new module helper …
                                    0|MagicMir | [14.12.2021 16:56.25.840] [LOG] Module helper loaded: MMM-GoogleTasks
                                    0|MagicMir | [14.12.2021 16:56.25.978] [LOG] Initializing new module helper …
                                    0|MagicMir | [14.12.2021 16:56.25.978] [LOG] Module helper loaded: updatenotification
                                    0|MagicMir | [14.12.2021 16:56.25.980] [LOG] No helper found for module: weather.
                                    0|MagicMir | [14.12.2021 16:56.25.981] [LOG] No helper found for module: clock.
                                    0|MagicMir | [14.12.2021 16:56.25.982] [LOG] No helper found for module: MMM-Carousel.
                                    0|MagicMir | [14.12.2021 16:56.25.983] [LOG] No helper found for module: MMM-RAIN-MAP.
                                    0|MagicMir | [14.12.2021 16:56.26.361] [LOG] Initializing new module helper …
                                    0|MagicMir | [14.12.2021 16:56.26.362] [LOG] Module helper loaded: MMM-PaprikaMenu
                                    0|MagicMir | [14.12.2021 16:56.26.462] [LOG] Initializing new module helper …
                                    0|MagicMir | [14.12.2021 16:56.26.463] [LOG] Module helper loaded: calendar
                                    0|MagicMir | [14.12.2021 16:56.26.464] [LOG] No helper found for module: calendar_monthly.
                                    0|MagicMir | [14.12.2021 16:56.26.465] [LOG] No helper found for module: helloworld.
                                    0|MagicMir | [14.12.2021 16:56.26.804] [LOG] Initializing new module helper …
                                    0|MagicMir | [14.12.2021 16:56.26.805] [LOG] Module helper loaded: MMM-CalendarExt
                                    0|MagicMir | [14.12.2021 16:56.26.808] [LOG] Initializing new module helper …
                                    0|MagicMir | [14.12.2021 16:56.26.809] [LOG] Module helper loaded: MMM-ip
                                    0|MagicMir | [14.12.2021 16:56.26.809] [LOG] All module helpers loaded.
                                    0|MagicMir | [14.12.2021 16:56.26.921] [LOG] Starting server on port 8080 …
                                    0|MagicMir | [14.12.2021 16:56.26.936] [LOG] Server started …
                                    0|MagicMir | [14.12.2021 16:56.26.937] [LOG] Connecting socket for: MMM-GoogleTasks
                                    0|MagicMir | [14.12.2021 16:56.26.938] [LOG] Starting node helper for: MMM-GoogleTasks
                                    0|MagicMir | [14.12.2021 16:56.26.939] [LOG] Connecting socket for: updatenotification
                                    0|MagicMir | [14.12.2021 16:56.26.940] [LOG] Connecting socket for: MMM-PaprikaMenu
                                    0|MagicMir | [14.12.2021 16:56.26.940] [LOG] Starting node_helper for module [MMM-PaprikaMenu]
                                    0|MagicMir | [14.12.2021 16:56.26.941] [LOG] Connecting socket for: calendar
                                    0|MagicMir | [14.12.2021 16:56.26.942] [LOG] Starting node helper for: calendar
                                    0|MagicMir | [14.12.2021 16:56.26.943] [LOG] Connecting socket for: MMM-CalendarExt
                                    0|MagicMir | [14.12.2021 16:56.26.944] [LOG] Connecting socket for: MMM-ip
                                    0|MagicMir | [14.12.2021 16:56.26.945] [LOG] Starting module helper: MMM-ip
                                    0|MagicMir | [14.12.2021 16:56.26.945] [LOG] Available network interface types: lo, wlan0
                                    0|MagicMir | [14.12.2021 16:56.26.946] [LOG] Sockets connected & modules started …
                                    0|MagicMir | [14.12.2021 16:56.27.226] [LOG] Launching application.
                                    0|MagicMir | [14.12.2021 16:56.29.659] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-34995d14cf5e15efc8bd68f680c508e3/basic.ics - Interval: 50000
                                    0|MagicMir | [14.12.2021 16:56.29.715] [LOG] Create new calendarfetcher for url: http://outlook.office365.com/owa/calendar/f2033a09d6504d21833241fb44df8c3c@dxc.com/a53b201c85bf4825a9290ce3ec96a8b2457585490405428856/calendar.ics - Interval: 50000
                                    0|MagicMir | [14.12.2021 16:56.29.857] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastorcharlotte%40htni.org/private-448bd9e0646a570df025700cdd3f7155/basic.ics - Interval: 50000
                                    0|MagicMir | [14.12.2021 16:56.30.213] [INFO] Calendar-Fetcher: Broadcasting 6 events.
                                    0|MagicMir | [14.12.2021 16:56.30.556] [INFO] Calendar-Fetcher: Broadcasting 2 events.
                                    0|MagicMir | [14.12.2021 16:56.30.678] [LOG] MMM-PaprikaMenu: Week starts: 2021-12-13, next week starts: 2021-12-20
                                    0|MagicMir | [14.12.2021 16:56.30.699] [LOG] MMM-PaprikaMenu: Waiting on 0 Paprika recipe calls.
                                    0|MagicMir | [14.12.2021 16:56.30.700] [LOG] MMM-PaprikaMenu: All recipe queries returned.
                                    0|MagicMir | [14.12.2021 16:56.39.598] [INFO] Calendar-Fetcher: Broadcasting 10 events.
                                      @pastormingle see no errors there
                                      let’s stop using pm2 during debug
                                      pm2 stop all
                                      npm start &>somefile.txt
                                      wait til black screen
                                      ctrl-q
                                      the examine the contents of somefile.txt
                                        @sdetweil npm ERR! missing script: start
                                        npm ERR! /home/pi/.npm/_logs/2021-12-14T23_05_21_577Z-debug.log
                                          @pastormingle ```
                                          ./run-start.sh $1
                                          [14.12.2021 17:06.53.311] [LOG] Starting MagicMirror: v2.16.0
                                          [14.12.2021 17:06.53.315] [LOG] Loading config …
                                          [14.12.2021 17:06.53.322] [LOG] Loading module helpers …
                                          [14.12.2021 17:06.53.324] [LOG] No helper found for module: alert.
                                          [14.12.2021 17:06.54.616] [LOG] Initializing new module helper …
                                          [14.12.2021 17:06.54.618] [LOG] Module helper loaded: MMM-GoogleTasks
                                          [14.12.2021 17:06.54.753] [LOG] Initializing new module helper …
                                          [14.12.2021 17:06.54.753] [LOG] Module helper loaded: updatenotification
                                          [14.12.2021 17:06.54.754] [LOG] No helper found for module: weather.
                                          [14.12.2021 17:06.54.755] [LOG] No helper found for module: clock.
                                          [14.12.2021 17:06.54.756] [LOG] No helper found for module: MMM-Carousel.
                                          [14.12.2021 17:06.54.756] [LOG] No helper found for module: MMM-RAIN-MAP.
                                          [14.12.2021 17:06.55.135] [LOG] Initializing new module helper …
                                          [14.12.2021 17:06.55.136] [LOG] Module helper loaded: MMM-PaprikaMenu
                                          [14.12.2021 17:06.55.236] [LOG] Initializing new module helper …
                                          [14.12.2021 17:06.55.237] [LOG] Module helper loaded: calendar
                                          [14.12.2021 17:06.55.238] [LOG] No helper found for module: calendar_monthly.
                                          [14.12.2021 17:06.55.238] [LOG] No helper found for module: helloworld.
                                          [14.12.2021 17:06.55.577] [LOG] Initializing new module helper …
                                          [14.12.2021 17:06.55.577] [LOG] Module helper loaded: MMM-CalendarExt
                                          [14.12.2021 17:06.55.580] [LOG] Initializing new module helper …
                                          [14.12.2021 17:06.55.581] [LOG] Module helper loaded: MMM-ip
                                          [14.12.2021 17:06.55.581] [LOG] All module helpers loaded.
                                          [14.12.2021 17:06.55.694] [LOG] Starting server on port 8080 …
                                          [14.12.2021 17:06.55.708] [LOG] Server started …
                                          [14.12.2021 17:06.55.709] [LOG] Connecting socket for: MMM-GoogleTasks
                                          [14.12.2021 17:06.55.710] [LOG] Starting node helper for: MMM-GoogleTasks
                                          [14.12.2021 17:06.55.710] [LOG] Connecting socket for: updatenotification
                                          [14.12.2021 17:06.55.711] [LOG] Connecting socket for: MMM-PaprikaMenu
                                          [14.12.2021 17:06.55.712] [LOG] Starting node_helper for module [MMM-PaprikaMenu]
                                          [14.12.2021 17:06.55.712] [LOG] Connecting socket for: calendar
                                          [14.12.2021 17:06.55.713] [LOG] Starting node helper for: calendar
                                          [14.12.2021 17:06.55.713] [LOG] Connecting socket for: MMM-CalendarExt
                                          [14.12.2021 17:06.55.714] [LOG] Connecting socket for: MMM-ip
                                          [14.12.2021 17:06.55.715] [LOG] Starting module helper: MMM-ip
                                          [14.12.2021 17:06.55.715] [LOG] Available network interface types: lo, wlan0
                                          [14.12.2021 17:06.55.716] [LOG] Sockets connected & modules started …
                                          [14.12.2021 17:06.55.995] [LOG] Launching application.
                                          [14.12.2021 17:06.58.663] [LOG] Create new calendarfetcher for url: http://outlook.office365.com/owa/calendar/f2033a09d654825a9290ce3ec9657585490405428856/calendar.ics - Interval: 50000
                                          [14.12.2021 17:06.58.696] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-34995d14cf5e15efc8bd68f680c508e3/basic.ics - Interval: 50000
                                          [14.12.2021 17:06.58.766] [LOG] TASKS SERVICE ALREADY RUNNING, DONT NEED TO AUTHENTICATE AGAIN
                                          [14.12.2021 17:06.58.884] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/pastorcharlotte%40htni.org/private-448bd900cdd3f7155/basic.ics - Interval: 50000
                                          [14.12.2021 17:06.59.198] [INFO] Calendar-Fetcher: Broadcasting 6 events.
                                          [14.12.2021 17:06.59.540] [INFO] Calendar-Fetcher: Broadcasting 2 events.
                                          [14.12.2021 17:06.59.674] [LOG] MMM-PaprikaMenu: Week starts: 2021-12-13, next week starts: 2021-12-20
                                          [14.12.2021 17:06.59.696] [LOG] MMM-PaprikaMenu: Waiting on 0 Paprika recipe calls.
                                          [14.12.2021 17:06.59.697] [LOG] MMM-PaprikaMenu: All recipe queries returned.
                                          [14.12.2021 17:07.02.676] [LOG] Shutting down server…
                                          [14.12.2021 17:07.02.678] [LOG] Stopping module helper: MMM-GoogleTasks
                                          [14.12.2021 17:07.02.679] [LOG] Stopping module helper: updatenotification
                                          [14.12.2021 17:07.02.680] [LOG] Stopping module helper: MMM-PaprikaMenu
                                          [14.12.2021 17:07.02.682] [LOG] Stopping module helper: calendar
                                          [14.12.2021 17:07.02.683] [LOG] Stopping module helper: MMM-CalendarExt
                                          [14.12.2021 17:07.02.684] [LOG] Stopping module helper: MMM-ip
                                            @pastormingle no errors but still not displaying the calendar…
                                            • 4 / 5
