    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
    • mumblebajM
      @sdetweil Lets see which one he is using. I am off to bed. Been a long day.
        pastormingle
          pastormingle @sdetweil
          @sdetweil so do i need to upgrade my magicmirror ?
            pastormingle
              sdetweil @pastormingle
              @pastormingle you need to get into the MMM-Carousel folder
              cd ~/MagicMirror/modules/MMM-Carousel
              git remote -v
                @pastormingle no, shouldn’t have to
                that error is typically from bad position:
                P 1 Reply Last reply
                  @sdetweil OK it’s working now… Thanks for all the hard work… So I unistalled the shbatm version and installed the schramkef. now it’s working fine…
                    @pastormingle great… glad its working
                      pastormingle
                      I am trying to use the carouselId:“1” function on multiple calendars. But when in use i am getting a module load error… not sure i am doing this right…
                      code_text
                      ```[{name:'calendar', classes:'zoom200', position:"middle_center", carouselId:"1"} ],
                      			colored: true,
                                              header: "Mikes Calendar",
                      			position: "left",
                                              timeFormat: 'absolute',
                                              broadcastPastEvents: false,
                                              fade: false,
                                              showEnd: false,
                                              color: '#ffffff',
                                                      carouselId:"1"
                                                      tableClass: "medium",
                      					  symbol: "calendar-day",
                      					  url:"https://outlook.office365.com/owa/f2033a09d6504d21833241fb44df8c3c@dxc.com/a53b29290ce3e0405428856/calendar.ics"
                        @sdetweil I am having an intermittent issue now with displaying my office 365 work calendar… Sometimes it comes back with an "error in calendar module check logs for more details. I don’t see anything in the development console… Any direction here, please?
                          pastormingle @pastormingle
                          @pastormingle i changed the time intervals on the fetch and that seems to have worked… thanks…
                            @pastormingle messages for fetching would be in the place u start mm
                            npm start or pm2
                              @sdetweil Thanks Sam…
                              Can you help me with an mmm-calendarext issue? I have a basic config for it and all I get is a blank screen… If I do console window it just hangs…
                                        module: 'MMM-CalendarExt',
                                        position: "center",
                                    url:"https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-349ihavethisblocked/basic.ics"
                                @pastormingle see
                                  @sdetweil Still not able to display… I ran the following command and it didn’t return any errors…
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt $ npm init -y
                                  Wrote to /home/pi/MagicMirror/modules/MMM-CalendarExt/package.json:
                                    "name": "MMM-CalendarExt",
                                    "version": "1.0.0",
                                    "description": "Alternative calendar module for [MagicMirror](https://magicmirror.builders/)",
                                    "main": "MMM-CalendarExt.js",
                                    "scripts": {
                                      "test": "echo \"Error: no test specified\" && exit 1"
                                    "repository": {
                                      "type": "git",
                                      "url": "git+https://github.com/eouia/MMM-CalendarExt.git"
                                    "keywords": [],
                                    "author": "",
                                    "license": "ISC",
                                    "bugs": {
                                      "url": "https://github.com/eouia/MMM-CalendarExt/issues"
                                    "homepage": "https://github.com/eouia/MMM-CalendarExt#readme",
                                    "dependencies": {
                                      "all": "0.0.0"
                                    "devDependencies": {}
                                    @pastormingle all that does is built the empty packjson,which will be used by the
                                    npm install xxx -save
                                    that second step is what fixes the missing library xxx once you figure out it’s name from the log messages.
                                    ps. there are more than one potential missing library… so I teach u how to find it so next time you don’t have to post here to find the fix.
                                      @sdetweil guess i"m not following what the xxx file would be?
                                        @pastormingle if i do a ctrl I i get the following
                                          @pastormingle from the linked topic
                                          then regardless do
                                          npm install xxx
                                          where xxx is the library noted in the message
                                          cannot find module xxx
                                          to find this message, look in the output of npm start. or if you use pm2 to launch mm do
                                          pm2 logs --lines=50
                                          __----------------
                                          so you look for the message and get the name from it and replace xxx with the name
                                            @sdetweil ```
                                            pi@raspberrypi:~ $ pm2 logs --lines=50 MagicMirror
                                            [TAILING] Tailing last 50 lines for [MagicMirror] process (change the value with --lines option)
                                            /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                                            0|MagicMir | - /home/pi/MagicMirror/js/electron.js
                                            0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                            0|MagicMir | -
                                            0|MagicMir | [14.12.2021 16:02.14.185] [ERROR] App threw an error during load
                                            0|MagicMir | [14.12.2021 16:02.14.187] [ERROR] Error: Cannot find module ‘valid-url’
                                            0|MagicMir | Require stack:
                                            0|MagicMir | - /home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js
                                            0|MagicMir | - /home/pi/MagicMirror/js/app.js
                                            0|MagicMir | -
                                            0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                                            0|MagicMir | at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                                            0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                            0|MagicMir | at Module._load (internal/modules/cjs/loader.js:848:27)
                                            0|MagicMir | at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                                            0|MagicMir | at Module.require (internal/modules/cjs/loader.js:1032:19)
                                            0|MagicMir | at require (internal/modules/cjs/helpers.js:72:18)
                                            0|MagicMir | at Object. (/home/pi/MagicMirror/modules/MMM-CalendarExt/node_helper.js:3:18)
                                            0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:1152:30)
                                            0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:1173:10)
                                            0|MagicMir | [14.12.2021 16:02.14.197] [ERROR] Whoops! There was an uncaught exception…
                                            0|MagicMir | [14.12.2021 16:02.14.203] [ERROR] Error: Cannot find module ‘valid-url’
                                            0|MagicMir | -
                                            • 4 / 5
