    MMM-Carousel not displaying
    Scheduled Pinned Locked Moved Forum
    96 Posts 4 Posters 73.1k Views 4 Watching
    • mumblebajM
      @sdetweil And there is this one as well:
      https://github.com/schramkef/MMM-Carousel
        sdetweil @mumblebaj
        @mumblebaj yep, thats the newest… 9months old, shbatm is 3 years, and the barnaby is 5 years old
        mumblebajM P 2 Replies Last reply
        • mumblebajM
          @sdetweil Lets see which one he is using. I am off to bed. Been a long day.
            pastormingle
              pastormingle @sdetweil
              @sdetweil so do i need to upgrade my magicmirror ?
                pastormingle
                  sdetweil @pastormingle
                  @pastormingle you need to get into the MMM-Carousel folder
                  cd ~/MagicMirror/modules/MMM-Carousel
                  git remote -v
                    @pastormingle no, shouldn’t have to
                    that error is typically from bad position:
                    P 1 Reply Last reply
                      @sdetweil OK it’s working now… Thanks for all the hard work… So I unistalled the shbatm version and installed the schramkef. now it’s working fine…
                        @pastormingle great… glad its working
                          pastormingle
                          I am trying to use the carouselId:“1” function on multiple calendars. But when in use i am getting a module load error… not sure i am doing this right…
                          code_text
                          ```[{name:'calendar', classes:'zoom200', position:"middle_center", carouselId:"1"} ],
                          			colored: true,
                                                  header: "Mikes Calendar",
                          			position: "left",
                                                  timeFormat: 'absolute',
                                                  broadcastPastEvents: false,
                                                  fade: false,
                                                  showEnd: false,
                                                  color: '#ffffff',
                                                          carouselId:"1"
                                                          tableClass: "medium",
                          					  symbol: "calendar-day",
                          					  url:"https://outlook.office365.com/owa/f2033a09d6504d21833241fb44df8c3c@dxc.com/a53b29290ce3e0405428856/calendar.ics"
                            @sdetweil I am having an intermittent issue now with displaying my office 365 work calendar… Sometimes it comes back with an "error in calendar module check logs for more details. I don’t see anything in the development console… Any direction here, please?
                              pastormingle @pastormingle
                              @pastormingle i changed the time intervals on the fetch and that seems to have worked… thanks…
                                @pastormingle messages for fetching would be in the place u start mm
                                npm start or pm2
                                  @sdetweil Thanks Sam…
                                  Can you help me with an mmm-calendarext issue? I have a basic config for it and all I get is a blank screen… If I do console window it just hangs…
                                            module: 'MMM-CalendarExt',
                                            position: "center",
                                        url:"https://calendar.google.com/calendar/ical/pastormike%40htni.org/private-349ihavethisblocked/basic.ics"
                                    @pastormingle see
                                      @sdetweil Still not able to display… I ran the following command and it didn’t return any errors…
                                      pi@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt $ npm init -y
                                      Wrote to /home/pi/MagicMirror/modules/MMM-CalendarExt/package.json:
                                        "name": "MMM-CalendarExt",
                                        "version": "1.0.0",
                                        "description": "Alternative calendar module for [MagicMirror](https://magicmirror.builders/)",
                                        "main": "MMM-CalendarExt.js",
                                        "scripts": {
                                          "test": "echo \"Error: no test specified\" && exit 1"
                                        "repository": {
                                          "type": "git",
                                          "url": "git+https://github.com/eouia/MMM-CalendarExt.git"
                                        "keywords": [],
                                        "author": "",
                                        "license": "ISC",
                                        "bugs": {
                                          "url": "https://github.com/eouia/MMM-CalendarExt/issues"
                                        "homepage": "https://github.com/eouia/MMM-CalendarExt#readme",
                                        "dependencies": {
                                          "all": "0.0.0"
                                        "devDependencies": {}
                                        @pastormingle all that does is built the empty packjson,which will be used by the
                                        npm install xxx -save
                                        that second step is what fixes the missing library xxx once you figure out it’s name from the log messages.
                                        ps. there are more than one potential missing library… so I teach u how to find it so next time you don’t have to post here to find the fix.
                                          @sdetweil guess i"m not following what the xxx file would be?
                                            @pastormingle if i do a ctrl I i get the following
                                            • 4 / 5
