    Weather one call reason for "onecall"
    8 Posts 4 Posters 2.1k Views 3 Watching
      A Former User
        sdetweil @Guest
        @hango not the way the API works. choose which data u want. can’t get all in one call
        one call means one endpoint instead of multiple
        • cowboysdudeC Offline
          I say look for another module that’ll give you what you want. This isn’t going to do what you want it to do. The ONLY way you can get this to work is use your original mirror as your main mirror and clone that on other mirrors that way you’re only making ‘onecall’.
          BUT as far as getting ALL the info that’s not how it’s built. It’s built to pick onecall to get the info you need. There are 3 options:
          Current weather
          Daily forecast
          Hourly forecast
            sdetweil @cowboysdude
            @cowboysdude no. the only way to get this to work is to have multiple userids with different API keys
            three mirrors w the same apikey counts against the requests for that apikey ( ask me how I know!)
            I added the Climacell support to the smart-mirror weather plugin, after @Mykle1 showed me how easy it could be.
              @hango you can increase the time, every module has some update interval
              currently the node_helper does not cache or share data between modulename.js callers
                @sdetweil said in Weather one call reason for "onecall":
                Huh? What?
                Don’t accuse me of doing something correctly.
                  sdetweil @Mykle1
                  @mykle1 lol! you are my inspiration… you have more modules than I ever thought about!!
                    Well, thanks to you and John I had the best help available when I got stuck (which was quite often). John gets the lion’s share of credits in my readMe files. I am indebted to you both and am forever in your debt.
