    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 58.9k Views 21 Watching
    • cowboysdudeC
      cowboysdude Module Developer @hedmik
      @hedmik Been trying to get it to work for a couple weeks now… no luck for me either… @Snille where you at? LOL
        sdetweil @cowboysdude
        @cowboysdude that error doesn’t line up with the code on GitHub
        line 40 col 83 is inside a routine making the url string, not handling a request response
        so, what code is actually being run?
        hedmikH 1 Reply Last reply Reply Quote 0
        • hedmikH
          hedmik @sdetweil
          @sdetweil my code looks like this, perhaps it’s a need for an update…?
            sdetweil @hedmik
            @hedmik well, only the error part at the moment
            typically on error there is no body
               error.response.body
            I would change that to
              JSON.stringify(error,null,2)
            that way u see the whole error object
            then, on e we know the error, we can work on the cause
              joecas65 @Snille
              @snille Hi, I’m using this module , and today suddenly magic mirror doesn’t show anymore the pictures from ha sensors (persons). The web interface from a remote computer with chrome works as usual. How can i solve ?
              SnilleS 1 Reply Last reply Reply Quote 0
              • SnilleS
                Snille Module Developer @joecas65
                @joecas65 Hi! Yes, I do have this issue as well, I have not yet figured out how to solve it. It has to do with the “CORS Policy”. But I’m not sure how to fix it yet. I have to read up a bit and for the moment I’m out of time… Any PR:s would be appreciated! :)
                • karsten13K
                  karsten13 @Snille
                  @snille
                  the cors policies are more restricted with newer chromium releases and therefore in electron too.
                  There are already some issues here 1, 2 …
                  If HomeAssistent and mm are running on the same pi this may works when changing the host in the module config to localhost or 127.0.01.
                  In other cases it will be difficult to access the picture urls from inside the <module-name>.js file, accessing them from the node_helper.js should work. So one solution could be to fetch them with node_helper.js to a mm directory and use these urls in <module-name>.js.
                  Because I have no HomeAssistant I can not test this so this are only my thoughts so far …
                  • A
                    aseadc86
                    I just set this module up and I love it. Great job. I was wondering if there was anyway to bring in 2 sensors on the same row? I’m mostly using it for temperature and humidity sensors in different rooms. Just to streamline, eliminate redundancy and save space.
                    This:
                    Master Bedroom: 70 / 40 F / %
                    Instead of:
                    Master Bedroom Temp: 70 F
                    Master Bedroom Humidity: 40 %
                    It would be really cool to have the icons directly after the value and then the units could be set to false:
                    Master Bedroom: 70 mdi:thermostat / 40 mdi:water-percent
                    I just comically dove through the code thinking I might be able to copy/paste my way through the changes. I know my limits…
                    cowboysdudeC SnilleS 2 Replies Last reply Reply Quote 0
                    • cowboysdudeC
                      cowboysdude Module Developer @aseadc86
                      This works so nice :) Thank you @Snille
                      • SnilleS
                        Snille Module Developer @aseadc86
                        @aseadc86 Thank you! :) It is not possible to get two values on the same row (I think) in it’s current form… And also the “pictures” from the sensors does not work. I’m just out of time to fix it… :)
                        • I
                          Ivanov_d
                          I have the same issue as some of the other users here “Error fetching stats” with no errors in MM or HA. I generated a new token and changed it in the config, still no luck.
                          What version of HA are you running?
                          It was working for me until HA 2021.10: https://forum.magicmirror.builders/topic/15751/mmm-homeassistant-sensors-stopped-working-after-ha-2021-10-update?_=1645122750604
                          • SnilleS
                            Snille Module Developer @Ivanov_d
                            @ivanov_d Hm… Am I missing something? It’s working fine here (except for the pictures), I’m on: Core Version core-2022.2.8 and Supervisor Version supervisor-2022.01.1
                            Where do you get the error?
                            • I
                              Ivanov_d @Snille
                              @snille I don’t see any errors in either MM or HA, however I am still getting Error fetching stats in the module front end. Any suggestions for additional places where I could look? I checked the config and all seems fine to me.
                              • SnilleS
                                @ivanov_d Strange… I’m running HA on it’s own machine and MM on it’s own machine as well, don’t know if that matters… The HA module works on both my “Development” build and the “Real” mirror…
                                Oh, I’m NOT using a password for the API, that has in deed been deprecated…
                                This is my “top” part of the Module:
                                	disabled: false,
                                	module: 'MMM-homeassistant-sensors',
                                	hiddenOnStartup: true,
                                	position: 'top_center',
                                	classes: "Me Work Weather",
                                		host: "X.X.X.X",
                                		port: "8123",
                                		https: false,
                                		title: "Information",
                                		updateInterval: 60000,
                                		fade: 0,
                                		token: "Very-Long-MM-Token...",
                                		values:
                                When did it stop working?
                                • I
                                  Ivanov_d @Snille
                                  @snille it stopped working after HA version 2021.10 when the API discovery feature was deprecated. I am running HA Supervised on one raspberry pi and MM on another raspberry pi in the same network.
                                  Here is the config of the MM module:
                                    position: 'top_right',
                                      title:  'Сензори',
                                      rowClass: 'normal',
                                      host: "192.168.1.19",
                                      port: "8123",
                                      https: true, //I have SSL enables since my instance is exposed to the Internet
                                      token: "here_goes_my_token",
                                      values: [
                                          sensor: "sensor.bathroom_temp_temperature",
                                          icons: [{
                                            "default": "thermometer"
                                          sensor: "sensor.bathroom_temp_humidity",
                                          icons: [{
                                            "default": "water-percent"
                                          sensor: "switch.bathroom_fan_1",
                                          icons: [{
                                            "on": "fan",
                                            "off": "fan-off"
                                          replace: [{
                                            "on": "вкл.",
                                            "off": "изкл."
                                          sensor: "switch.bathroom_fan_2",
                                          icons: [{
                                            "on": "fan",
                                            "off": "fan-off"
                                          replace: [{
                                            "on": "вкл.",
                                            "off": "изкл."
                                  Here is the changelog of HA 2021.10:
                                  The API endpoint /api/discovery_info now only return blank values. This endpoint is scheduled to be removed in Home Assistant Core 2022.1.
                                  As a regular user of Home Assistant, this change should not affect you.
                                  (@ludeeus - #56097) (api docs)
                                  In the past I was having issues with https and the local IP address and then I changed it to the DNS hostname blabla.duckdsn.org and the external port for https (443) and it was working fine until the /api/discovery_info endpoint was deprecated.
                                  • cowboysdudeC
                                    cowboysdude Module Developer @Snille
                                    @snille Well that’s really not a deal breaker. It works and gaps the bridge. It’s a great module!
                                    • SnilleS
                                      @ivanov_d It’s still working for me, when using https. It got to be something else…
                                      I changed my conf to this and it works…
                                      	disabled: false,
                                      	hiddenOnStartup: false,
                                      		host: "my.ha.url.com",
                                      		port: "443",
                                      		https: true,
                                      		fade: 0,
                                      		noaddress: "Away",
                                      		token: "token...",
                                      		values: [
                                      				sensor: "sensor.living_room_temperature",
                                      				name: "Temp i Vardagsrummet %t%",
                                      				icons: [{
                                      I’m on Hass.IO (from start), maybe the api is still active there? I don’t get it…
                                      It does not work for me on port 8123, but that’s to be expected when using ssl.
                                      I 1 Reply Last reply Reply Quote 1
                                      • I
                                        Ivanov_d @Snille
                                        @snille what is the most up-to-date code repo? The one that I pulled from is https://github.com/theskyisthelimit/MMM-homeassistant-sensors.git
                                        Could it be that I have an old code base? I tried with different ports, URL/IP, still the same and still no errors in both logs HA or MM …
                                        EDIT: I tried with another HA instance that I have which doesn’t have SSL enabled and it worked, so now I need to figure out what the difference between the two are :)
                                        Will keep you posted.
                                        • SnilleS
                                          @ivanov_d Hmm… In my own adventures to find what’s going on, I managed to “break” my real mirror connection to HA (now getting the fetch-error) but my development mirror is still working (against the same HA instance).
                                          I don’t understand what’s going on. :)
                                          As for codebase I’m using my own fork: https://github.com/Snille/MMM-homeassistant-sensors.git
                                          Let me know if you get it to work again… :)
                                          • I
                                            Ivanov_d @Snille
                                            @snille lol sorry to hear that. I managed to get it to work on my main HA instance by removing SSL from my HA configuration.yaml file:
                                            However, that doesn’t suit my needs as I control my house through my phone over the Internet and I want SSL to be enabled. I am continuing testing. Will keep you posted.
                                            • 2 / 4
