    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 58.9k Views 21 Watching
    • N
      NLCarrII @RdP
      @RdP
      I had this last night and I got frustrated and shutdown the mirror and re-opened it via terminal and it worked. I only tested with one sensor. Then I added another sensor and I didn’t have to restart to have it show it up. Not sure what changed, but this might work for you. Something else I did was not install the right one TWICE, I instralled them as they appeared in the list on Github and found out about their issues, which caused me to install the next one and so on. At least I got experience installing modules. This was the last one I installed and I have a lock and a sensor displaying now. More to Come.
      • K
        Karlberg
        i have the same problem. It never worked. I hassio i got “Login attempt failed
        Login attempt or request with invalid authentication from raspberrypi (192.168.16.71)”
        so something is wrong with this module.
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS
          Snille Module Developer @Karlberg
          @Karlberg Hi, the module should be working. It sounds like you have something wrong with the token if HA reports failed logins…
          • K
            Karlberg
            • K
              Karlberg @Snille
              @Snille Yes something was wrong. its working with another token
              SnilleS B 2 Replies Last reply Reply Quote 0
              • SnilleS
                @Karlberg Great! :)
                • F
                  fribse @Snille
                  @Snille Looks very nice, good job!
                  • V
                    vageesh79
                    anyway to use https with self signed. I am getting error "“Error Fetching Stats”. No error on homeassistant and MM
                      bachoo786 @Karlberg
                      @karlberg hey man thanks for the module. However I am getting “Error fetching stats” there is no error in HA.
                      Can you please help? thnaks
                      • SnilleS
                        Snille Module Developer @bachoo786
                        @bachoo786 Hi, I’m using the module and it’s working. It may be that the “request” module is missing? Have you installed it?
                        Go the to the module folder and do
                        npm init
                        npm install request
                        Let me know if it works.
                        hedmikH J 2 Replies Last reply Reply Quote 0
                        • hedmikH
                          hedmik @Snille
                          @snille Hi, trying to use this module but getting below error.
                          I followed your instructions i hope :-)
                          [07.01.2022 17:10.13.062] [ERROR] (node:30547) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘body’)
                          at /home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js:40:83
                          at runMicrotasks ()
                          at processTicksAndRejections (node:internal/process/task_queues:96:5)
                          [07.01.2022 17:10.13.067] [ERROR] (node:30547) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 46)
                          • cowboysdudeC
                            cowboysdude Module Developer @hedmik
                            @hedmik Been trying to get it to work for a couple weeks now… no luck for me either… @Snille where you at? LOL
                              sdetweil @cowboysdude
                              @cowboysdude that error doesn’t line up with the code on GitHub
                              line 40 col 83 is inside a routine making the url string, not handling a request response
                              so, what code is actually being run?
                              hedmikH 1 Reply Last reply Reply Quote 0
                              • hedmikH
                                hedmik @sdetweil
                                @sdetweil my code looks like this, perhaps it’s a need for an update…?
                                  sdetweil @hedmik
                                  @hedmik well, only the error part at the moment
                                  typically on error there is no body
                                     error.response.body
                                  I would change that to
                                    JSON.stringify(error,null,2)
                                  that way u see the whole error object
                                  then, on e we know the error, we can work on the cause
                                    joecas65 @Snille
                                    @snille Hi, I’m using this module , and today suddenly magic mirror doesn’t show anymore the pictures from ha sensors (persons). The web interface from a remote computer with chrome works as usual. How can i solve ?
                                    • SnilleS
                                      Snille Module Developer @joecas65
                                      @joecas65 Hi! Yes, I do have this issue as well, I have not yet figured out how to solve it. It has to do with the “CORS Policy”. But I’m not sure how to fix it yet. I have to read up a bit and for the moment I’m out of time… Any PR:s would be appreciated! :)
                                      • karsten13K
                                        karsten13 @Snille
                                        @snille
                                        the cors policies are more restricted with newer chromium releases and therefore in electron too.
                                        There are already some issues here 1, 2 …
                                        If HomeAssistent and mm are running on the same pi this may works when changing the host in the module config to localhost or 127.0.01.
                                        In other cases it will be difficult to access the picture urls from inside the <module-name>.js file, accessing them from the node_helper.js should work. So one solution could be to fetch them with node_helper.js to a mm directory and use these urls in <module-name>.js.
                                        Because I have no HomeAssistant I can not test this so this are only my thoughts so far …
                                        • A
                                          aseadc86
                                          I just set this module up and I love it. Great job. I was wondering if there was anyway to bring in 2 sensors on the same row? I’m mostly using it for temperature and humidity sensors in different rooms. Just to streamline, eliminate redundancy and save space.
                                          This:
                                          Master Bedroom: 70 / 40 F / %
                                          Instead of:
                                          Master Bedroom Temp: 70 F
                                          Master Bedroom Humidity: 40 %
                                          It would be really cool to have the icons directly after the value and then the units could be set to false:
                                          Master Bedroom: 70 mdi:thermostat / 40 mdi:water-percent
                                          I just comically dove through the code thinking I might be able to copy/paste my way through the changes. I know my limits…
                                          cowboysdudeC SnilleS 2 Replies Last reply Reply Quote 0
                                          • cowboysdudeC
                                            cowboysdude Module Developer @aseadc86
                                            This works so nice :) Thank you @Snille
                                            • 2 / 4
