    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 60.0k Views 21 Watching
    • RaspiManuR
      RaspiManu @RdP
      @RdP I would recommend editing your token out when posting code.
      R 1 Reply Last reply
        RdP @RaspiManu
        @RaspiManu
        I did use a dummy token
        J 1 Reply Last reply
          JohnBachini @RdP
          @RdP anything in the logs of home assistant ?
          I use this module and does work.
            RdP @JohnBachini
            @JohnBachini said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
            Nothing in the HA logs :-(
              RdP @RdP
              @RdP said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
              I get an error:
              My config is like this:
              	module: 'MMM-homeassistant-sensors',
              	position: 'top_left',
              		host: "192.168.0.185",
              		port: "8123",
              		https: false,
              		token: "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpiJmMmVQ4ODM0NzViYmQ4NzdlZTdlYmsImlhdCI6MTU5MjM5NjYxOSwiZXhwIjoxOTA3NzU2NjE5fQ.CxGIZP-TPWWZAFuNx3UV-sucjg8j8885ia00gCiG4vGg",
              		values: [
              				sensor: "sensor.jacuzzi_temperatuur",
              Any help is more than welcome
              Bump… Is there anyone who can point me in the right direction?
              S N 2 Replies Last reply
                sdetweil @RdP
                @RdP I don’t know anything about module, just asking questions
                it was working and stopped? or is this the 1st time?
                if u look at the logs (console, npm start, pm2 logs) or the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors, usually red text, do you see anything?
                  smoysauce
                  Love this module, I am just trying to figure out if it possible to merge the attribute pieces from this fork: https://github.com/moejetz/MMM-homeassistant-sensors with this one: to allow adding attributes. I’m trying to read up on how to do it, but not sure if it’s a lot of work to do or if there is an easy way to do it. I’m also checking for any guidance in the help forum. Any help would be appreciated!
                  • N
                    NLCarrII @RdP
                    @RdP
                    I had this last night and I got frustrated and shutdown the mirror and re-opened it via terminal and it worked. I only tested with one sensor. Then I added another sensor and I didn’t have to restart to have it show it up. Not sure what changed, but this might work for you. Something else I did was not install the right one TWICE, I instralled them as they appeared in the list on Github and found out about their issues, which caused me to install the next one and so on. At least I got experience installing modules. This was the last one I installed and I have a lock and a sensor displaying now. More to Come.
                    • K
                      Karlberg
                      i have the same problem. It never worked. I hassio i got “Login attempt failed
                      Login attempt or request with invalid authentication from raspberrypi (192.168.16.71)”
                      so something is wrong with this module.
                      SnilleS 1 Reply Last reply
                      • SnilleS
                        Snille Module Developer @Karlberg
                        @Karlberg Hi, the module should be working. It sounds like you have something wrong with the token if HA reports failed logins…
                        K 1 Reply Last reply
                        • K
                          Karlberg
                          • K
                            Karlberg @Snille
                            @Snille Yes something was wrong. its working with another token
                            SnilleS B 2 Replies Last reply
                            • SnilleS
                              @Karlberg Great! :)
                              • F
                                fribse @Snille
                                @Snille Looks very nice, good job!
                                • V
                                  vageesh79
                                  anyway to use https with self signed. I am getting error "“Error Fetching Stats”. No error on homeassistant and MM
                                    bachoo786 @Karlberg
                                    @karlberg hey man thanks for the module. However I am getting “Error fetching stats” there is no error in HA.
                                    Can you please help? thnaks
                                    • SnilleS
                                      Snille Module Developer @bachoo786
                                      @bachoo786 Hi, I’m using the module and it’s working. It may be that the “request” module is missing? Have you installed it?
                                      Go the to the module folder and do
                                      npm init
                                      npm install request
                                      Let me know if it works.
                                      hedmikH J 2 Replies Last reply
                                      • hedmikH
                                        hedmik @Snille
                                        @snille Hi, trying to use this module but getting below error.
                                        I followed your instructions i hope :-)
                                        [07.01.2022 17:10.13.062] [ERROR] (node:30547) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘body’)
                                        at /home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js:40:83
                                        at runMicrotasks ()
                                        at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                        [07.01.2022 17:10.13.067] [ERROR] (node:30547) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 46)
                                        • cowboysdudeC
                                          cowboysdude Module Developer @hedmik
                                          @hedmik Been trying to get it to work for a couple weeks now… no luck for me either… @Snille where you at? LOL
                                            sdetweil @cowboysdude
                                            @cowboysdude that error doesn’t line up with the code on GitHub
                                            line 40 col 83 is inside a routine making the url string, not handling a request response
                                            so, what code is actually being run?
                                            hedmikH 1 Reply Last reply
                                            • 1 / 4
