    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 48.6k Views 21 Watching
    • SnilleS Offline
      Snille Module Developer
      I could not find a “good enough” Home Assistant Module for the Mirror, so I forked and developed a bit on the one I thought worked the best.
      Description:
      Adds the defined Home Assistant Sensors to your Magic Mirror.
      Screenshots:
      Simplest possible:
      simple
      Different pictures depending on values from the sensors (with some modified CSS):
      simple+css
      Different icons depending on values from the sensors:
      simple+icons
      And here is my personal advanced “look”… :)
      Advanced
      Download:
      [card:Snille/MMM-homeassistant-sensors]
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      S F 2 Replies Last reply Reply Quote 5
        sdetweil @Snille
        @Snille very nice!
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS Offline
          Snille Module Developer @sdetweil
          @sdetweil Thanks! :)
            @iorifly see this module
              RdP
              I get an error:
              My config is like this:
              	module: 'MMM-homeassistant-sensors',
              	position: 'top_left',
              		host: "192.168.0.185",
              		port: "8123",
              		https: false,
              		token: "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpiJmMmVQ4ODM0NzViYmQ4NzdlZTdlYmsImlhdCI6MTU5MjM5NjYxOSwiZXhwIjoxOTA3NzU2NjE5fQ.CxGIZP-TPWWZAFuNx3UV-sucjg8j8885ia00gCiG4vGg",
              		values: [
              				sensor: "sensor.jacuzzi_temperatuur",
              Any help is more than welcome
              RaspiManuR R 2 Replies Last reply Reply Quote 0
              • RaspiManuR Offline
                RaspiManu @RdP
                @RdP I would recommend editing your token out when posting code.
                  RdP @RaspiManu
                  @RaspiManu
                  I did use a dummy token
                    JohnBachini @RdP
                    @RdP anything in the logs of home assistant ?
                    I use this module and does work.
                      RdP @JohnBachini
                      @JohnBachini said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
                      Nothing in the HA logs :-(
                        RdP @RdP
                        @RdP said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
                        I get an error:
                        		port: "8123",
                        		https: false,
                        		values: [
                        Bump… Is there anyone who can point me in the right direction?
                        S N 2 Replies Last reply Reply Quote 0
                        • 1 / 7
