    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 50.4k Views 21 Watching
    • SnilleS Offline
      Snille Module Developer
      I could not find a “good enough” Home Assistant Module for the Mirror, so I forked and developed a bit on the one I thought worked the best.
      Description:
      Adds the defined Home Assistant Sensors to your Magic Mirror.
      Screenshots:
      Simplest possible:
      simple
      Different pictures depending on values from the sensors (with some modified CSS):
      simple+css
      Different icons depending on values from the sensors:
      simple+icons
      And here is my personal advanced “look”… :)
      Advanced
      Download:
      [card:Snille/MMM-homeassistant-sensors]
      If you cant find it, make it and share it!
      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
      S F 2 Replies Last reply Reply Quote 5
        sdetweil @Snille
        @Snille very nice!
        SnilleS 1 Reply Last reply Reply Quote 0
        • SnilleS Offline
          Snille Module Developer @sdetweil
          @sdetweil Thanks! :)
            @iorifly see this module
              RdP
              I get an error:
              My config is like this:
              	module: 'MMM-homeassistant-sensors',
              	position: 'top_left',
              		host: "192.168.0.185",
              		port: "8123",
              		https: false,
              		token: "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpiJmMmVQ4ODM0NzViYmQ4NzdlZTdlYmsImlhdCI6MTU5MjM5NjYxOSwiZXhwIjoxOTA3NzU2NjE5fQ.CxGIZP-TPWWZAFuNx3UV-sucjg8j8885ia00gCiG4vGg",
              		values: [
              				sensor: "sensor.jacuzzi_temperatuur",
              Any help is more than welcome
              RaspiManuR R 2 Replies Last reply Reply Quote 0
              • RaspiManuR Offline
                RaspiManu @RdP
                @RdP I would recommend editing your token out when posting code.
                  RdP @RaspiManu
                  @RaspiManu
                  I did use a dummy token
                    JohnBachini @RdP
                    @RdP anything in the logs of home assistant ?
                    I use this module and does work.
                      RdP @JohnBachini
                      @JohnBachini said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
                      Nothing in the HA logs :-(
                        RdP @RdP
                        @RdP said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
                        I get an error:
                        		port: "8123",
                        		https: false,
                        		values: [
                        Bump… Is there anyone who can point me in the right direction?
                        S N 2 Replies Last reply Reply Quote 0
                          sdetweil @RdP
                          @RdP I don’t know anything about module, just asking questions
                          it was working and stopped? or is this the 1st time?
                          if u look at the logs (console, npm start, pm2 logs) or the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors, usually red text, do you see anything?
                            smoysauce
                            Love this module, I am just trying to figure out if it possible to merge the attribute pieces from this fork: https://github.com/moejetz/MMM-homeassistant-sensors with this one: to allow adding attributes. I’m trying to read up on how to do it, but not sure if it’s a lot of work to do or if there is an easy way to do it. I’m also checking for any guidance in the help forum. Any help would be appreciated!
                            • N Offline
                              NLCarrII @RdP
                              @RdP
                              I had this last night and I got frustrated and shutdown the mirror and re-opened it via terminal and it worked. I only tested with one sensor. Then I added another sensor and I didn’t have to restart to have it show it up. Not sure what changed, but this might work for you. Something else I did was not install the right one TWICE, I instralled them as they appeared in the list on Github and found out about their issues, which caused me to install the next one and so on. At least I got experience installing modules. This was the last one I installed and I have a lock and a sensor displaying now. More to Come.
                              • K Offline
                                Karlberg
                                i have the same problem. It never worked. I hassio i got “Login attempt failed
                                Login attempt or request with invalid authentication from raspberrypi (192.168.16.71)”
                                so something is wrong with this module.
                                • SnilleS Offline
                                  Snille Module Developer @Karlberg
                                  @Karlberg Hi, the module should be working. It sounds like you have something wrong with the token if HA reports failed logins…
                                  • K Offline
                                    Karlberg
                                    • K Offline
                                      Karlberg @Snille
                                      @Snille Yes something was wrong. its working with another token
                                      SnilleS B 2 Replies Last reply Reply Quote 0
                                      • SnilleS Offline
                                        @Karlberg Great! :)
                                        • F Offline
                                          fribse @Snille
                                          @Snille Looks very nice, good job!
                                          • V Offline
                                            vageesh79
                                            anyway to use https with self signed. I am getting error "“Error Fetching Stats”. No error on homeassistant and MM
                                            • 1 / 4
