    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 59.8k Views 21 Watching
    • SnilleS
      Snille Module Developer @sdetweil
      @sdetweil Thanks! :)
        @iorifly see this module
          RdP
          I get an error:
          My config is like this:
          	module: 'MMM-homeassistant-sensors',
          	position: 'top_left',
          		host: "192.168.0.185",
          		port: "8123",
          		https: false,
          		token: "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpiJmMmVQ4ODM0NzViYmQ4NzdlZTdlYmsImlhdCI6MTU5MjM5NjYxOSwiZXhwIjoxOTA3NzU2NjE5fQ.CxGIZP-TPWWZAFuNx3UV-sucjg8j8885ia00gCiG4vGg",
          		values: [
          				sensor: "sensor.jacuzzi_temperatuur",
          Any help is more than welcome
          RaspiManuR R 2 Replies Last reply
          • RaspiManuR
            RaspiManu @RdP
            @RdP I would recommend editing your token out when posting code.
            R 1 Reply Last reply
              RdP @RaspiManu
              @RaspiManu
              I did use a dummy token
              J 1 Reply Last reply
                JohnBachini @RdP
                @RdP anything in the logs of home assistant ?
                I use this module and does work.
                  RdP @JohnBachini
                  @JohnBachini said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
                  Nothing in the HA logs :-(
                    RdP @RdP
                    @RdP said in MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror:
                    I get an error:
                    		port: "8123",
                    		https: false,
                    		values: [
                    Bump… Is there anyone who can point me in the right direction?
                    S N 2 Replies Last reply
                      sdetweil @RdP
                      @RdP I don’t know anything about module, just asking questions
                      it was working and stopped? or is this the 1st time?
                      if u look at the logs (console, npm start, pm2 logs) or the developers window, ctrl-shift-i, select the console tab and scroll up to see any errors, usually red text, do you see anything?
                        smoysauce
                        Love this module, I am just trying to figure out if it possible to merge the attribute pieces from this fork: https://github.com/moejetz/MMM-homeassistant-sensors with this one: to allow adding attributes. I’m trying to read up on how to do it, but not sure if it’s a lot of work to do or if there is an easy way to do it. I’m also checking for any guidance in the help forum. Any help would be appreciated!
                        • N
                          NLCarrII @RdP
                          @RdP
                          I had this last night and I got frustrated and shutdown the mirror and re-opened it via terminal and it worked. I only tested with one sensor. Then I added another sensor and I didn’t have to restart to have it show it up. Not sure what changed, but this might work for you. Something else I did was not install the right one TWICE, I instralled them as they appeared in the list on Github and found out about their issues, which caused me to install the next one and so on. At least I got experience installing modules. This was the last one I installed and I have a lock and a sensor displaying now. More to Come.
                          • K
                            Karlberg
                            i have the same problem. It never worked. I hassio i got “Login attempt failed
                            Login attempt or request with invalid authentication from raspberrypi (192.168.16.71)”
                            so something is wrong with this module.
                            SnilleS 1 Reply Last reply
                            • SnilleS
                              Snille Module Developer @Karlberg
                              @Karlberg Hi, the module should be working. It sounds like you have something wrong with the token if HA reports failed logins…
                              K 1 Reply Last reply
                              • K
                                Karlberg
                                • K
                                  Karlberg @Snille
                                  @Snille Yes something was wrong. its working with another token
                                  SnilleS B 2 Replies Last reply
                                  • SnilleS
                                    @Karlberg Great! :)
                                    • F
                                      fribse @Snille
                                      @Snille Looks very nice, good job!
                                      • V
                                        vageesh79
                                        anyway to use https with self signed. I am getting error "“Error Fetching Stats”. No error on homeassistant and MM
                                          bachoo786 @Karlberg
                                          @karlberg hey man thanks for the module. However I am getting “Error fetching stats” there is no error in HA.
                                          Can you please help? thnaks
                                          • SnilleS
                                            Snille Module Developer @bachoo786
                                            @bachoo786 Hi, I’m using the module and it’s working. It may be that the “request” module is missing? Have you installed it?
                                            Go the to the module folder and do
                                            npm init
                                            npm install request
                                            Let me know if it works.
                                            hedmikH J 2 Replies Last reply
                                            • 1 / 4
