    MMM-HomeAssistant-Sensors (Development) - Show your HA Sensors on your Mirror
    66 Posts 19 Posters 55.6k Views 21 Watching
    • SnilleS Offline
      Snille Module Developer @Karlberg
      @Karlberg Great! :)
      • F Offline
        fribse @Snille
        @Snille Looks very nice, good job!
        • V Offline
          vageesh79
          anyway to use https with self signed. I am getting error "“Error Fetching Stats”. No error on homeassistant and MM
            bachoo786 @Karlberg
            @karlberg hey man thanks for the module. However I am getting “Error fetching stats” there is no error in HA.
            Can you please help? thnaks
            SnilleS 1 Reply Last reply Reply Quote 0
            • SnilleS Offline
              Snille Module Developer @bachoo786
              @bachoo786 Hi, I’m using the module and it’s working. It may be that the “request” module is missing? Have you installed it?
              Go the to the module folder and do
              npm init
              npm install request
              Let me know if it works.
              hedmikH J 2 Replies Last reply Reply Quote 0
              • hedmikH Offline
                hedmik @Snille
                @snille Hi, trying to use this module but getting below error.
                I followed your instructions i hope :-)
                [07.01.2022 17:10.13.062] [ERROR] (node:30547) UnhandledPromiseRejectionWarning: TypeError: Cannot read properties of undefined (reading ‘body’)
                at /home/pi/MagicMirror/modules/MMM-homeassistant-sensors/node_helper.js:40:83
                at runMicrotasks ()
                at processTicksAndRejections (node:internal/process/task_queues:96:5)
                [07.01.2022 17:10.13.067] [ERROR] (node:30547) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 46)
                • cowboysdudeC Offline
                  cowboysdude Module Developer @hedmik
                  @hedmik Been trying to get it to work for a couple weeks now… no luck for me either… @Snille where you at? LOL
                    sdetweil @cowboysdude
                    @cowboysdude that error doesn’t line up with the code on GitHub
                    line 40 col 83 is inside a routine making the url string, not handling a request response
                    so, what code is actually being run?
                    hedmikH 1 Reply Last reply Reply Quote 0
                    • hedmikH Offline
                      hedmik @sdetweil
                      @sdetweil my code looks like this, perhaps it’s a need for an update…?
                        sdetweil @hedmik
                        @hedmik well, only the error part at the moment
                        typically on error there is no body
                           error.response.body
                        I would change that to
                          JSON.stringify(error,null,2)
                        that way u see the whole error object
                        then, on e we know the error, we can work on the cause
                          joecas65 @Snille
                          @snille Hi, I’m using this module , and today suddenly magic mirror doesn’t show anymore the pictures from ha sensors (persons). The web interface from a remote computer with chrome works as usual. How can i solve ?
                          • SnilleS Offline
                            Snille Module Developer @joecas65
                            @joecas65 Hi! Yes, I do have this issue as well, I have not yet figured out how to solve it. It has to do with the “CORS Policy”. But I’m not sure how to fix it yet. I have to read up a bit and for the moment I’m out of time… Any PR:s would be appreciated! :)
                            • karsten13K Offline
                              karsten13 @Snille
                              @snille
                              the cors policies are more restricted with newer chromium releases and therefore in electron too.
                              There are already some issues here 1, 2 …
                              If HomeAssistent and mm are running on the same pi this may works when changing the host in the module config to localhost or 127.0.01.
                              In other cases it will be difficult to access the picture urls from inside the <module-name>.js file, accessing them from the node_helper.js should work. So one solution could be to fetch them with node_helper.js to a mm directory and use these urls in <module-name>.js.
                              Because I have no HomeAssistant I can not test this so this are only my thoughts so far …
                                aseadc86
                                I just set this module up and I love it. Great job. I was wondering if there was anyway to bring in 2 sensors on the same row? I’m mostly using it for temperature and humidity sensors in different rooms. Just to streamline, eliminate redundancy and save space.
                                This:
                                Master Bedroom: 70 / 40 F / %
                                Instead of:
                                Master Bedroom Temp: 70 F
                                Master Bedroom Humidity: 40 %
                                It would be really cool to have the icons directly after the value and then the units could be set to false:
                                Master Bedroom: 70 mdi:thermostat / 40 mdi:water-percent
                                I just comically dove through the code thinking I might be able to copy/paste my way through the changes. I know my limits…
                                cowboysdudeC SnilleS 2 Replies Last reply Reply Quote 0
                                  cowboysdude Module Developer @aseadc86
                                  This works so nice :) Thank you @Snille
                                  • SnilleS Offline
                                    Snille Module Developer @aseadc86
                                    @aseadc86 Thank you! :) It is not possible to get two values on the same row (I think) in it’s current form… And also the “pictures” from the sensors does not work. I’m just out of time to fix it… :)
                                    • I Offline
                                      Ivanov_d
                                      I have the same issue as some of the other users here “Error fetching stats” with no errors in MM or HA. I generated a new token and changed it in the config, still no luck.
                                      What version of HA are you running?
                                      It was working for me until HA 2021.10: https://forum.magicmirror.builders/topic/15751/mmm-homeassistant-sensors-stopped-working-after-ha-2021-10-update?_=1645122750604
                                      • SnilleS Offline
                                        Snille Module Developer @Ivanov_d
                                        @ivanov_d Hm… Am I missing something? It’s working fine here (except for the pictures), I’m on: Core Version core-2022.2.8 and Supervisor Version supervisor-2022.01.1
                                        Where do you get the error?
                                        • I Offline
                                          Ivanov_d @Snille
                                          @snille I don’t see any errors in either MM or HA, however I am still getting Error fetching stats in the module front end. Any suggestions for additional places where I could look? I checked the config and all seems fine to me.
                                          • SnilleS Offline
                                            @ivanov_d Strange… I’m running HA on it’s own machine and MM on it’s own machine as well, don’t know if that matters… The HA module works on both my “Development” build and the “Real” mirror…
                                            Oh, I’m NOT using a password for the API, that has in deed been deprecated…
                                            This is my “top” part of the Module:
                                            	disabled: false,
                                            	module: 'MMM-homeassistant-sensors',
                                            	hiddenOnStartup: true,
                                            	position: 'top_center',
                                            	classes: "Me Work Weather",
                                            		host: "X.X.X.X",
                                            		port: "8123",
                                            		https: false,
                                            		title: "Information",
                                            		updateInterval: 60000,
                                            		fade: 0,
                                            		token: "Very-Long-MM-Token...",
                                            		values:
                                            When did it stop working?
                                            • 2 / 4
