    Videostream of "Tagesschau in 100 Sekunden"?
    5 Posts 4 Posters 4.9k Views 5 Watching
    • lolobyteL Offline
      lolobyte
      Hi all,
      can someone create a module for a videostream of Tagesschau in 100 Sekunden?
      I think the optimal way to activate this stream is a switch.
      The stram can than start as, for exampe a overlay in the middle of the mirror. After 100 secons, the stream ends an the mirror modules are visible again.
      Thanks for participating
        Jopyth Moderator @lolobyte
        @lolobyte Two modules already exist: https://github.com/ptrbld/MMM-Podcast and https://github.com/PtrBld/MMM-Button
        You could give these a try.
        Helpful sticky: How to troubleshoot
        lolobyteL 1 Reply Last reply Reply Quote 0
        • lolobyteL Offline
          lolobyte @Jopyth
          @Jopyth
          ok, i will try this first.
          Thank you.
          • foxF Offline
            fox
            Did it work for you? Im also interested in Tagesschau in 100 Sekunden
            MrCoffeeM 1 Reply Last reply Reply Quote 0
            • MrCoffeeM Offline
              MrCoffee @fox
              @fox
              Did you get it running?
              I tinkered a little workaround because my MMM-podcast in combination with MMM-Button sometimes failed.
              The workaround was easier for me than solving the problem.
              I am definitly not good in coding. But however it works;-)
