    Can't upgrade MM 2.7.0 on Raspberry Pi Zero W
    9 Posts 5 Posters 3.7k Views 6 Watching
    • qu1queQ Offline
      qu1que Project Sponsor
      Hi @MichMich I’ve just try to update my mirrors to version 2.7.0. I’ve got one mirror with raspberry pi zero W, and another one with Raspberry Pi 3B.
      It seems the one with RPI 3B updates correctly, but when I try to update the mirrror with RPI ZeroW I get the following error with electron:
      Error: GET https://github.com/electron/electron/releases/download/v3.0.13/electron-v3.0.13-linux-armv6l.zip returned 404
      That url doesn’t work.
      How can I solved it?
      Thanks!
        maxberger
        Looks like electron 3.x is no longer available for the pi zero.
        I had to go back to the old version:
        diff --git a/package.json b/package.json
        index 14c7874..7a2aff4 100644
        --- a/package.json
        +++ b/package.json
        @@ -58,7 +58,7 @@
             "ajv": "6.5.5",
             "body-parser": "^1.18.2",
             "colors": "^1.1.2",
        -    "electron": "^3.0.13",
        +    "electron": "^2.0.18",
             "express": "^4.16.2",
             "express-ipfilter": "0.3.1",
             "feedme": "latest",
        See also: https://github.com/MichMich/MagicMirror/issues/1500 ; I just undid the change from that patch.
        Not sure if that has any other implications, for now this is still installing/building, let’s see if this works.
        Max
        qu1queQ 1 Reply Last reply Reply Quote 0
        • qu1queQ Offline
          qu1que Project Sponsor @maxberger
          @maxberger
          The thing is that I’ve updated MM, but it returns me that error on rpi Zero, but the final result is that MM finally is updated, and everything works ok in all the modules I have installed. How can I downgrade to the old version of electron?
          Thanks.
          Quique.
          • L Offline
            liamangelus
            did you find any solution to this issue?
            • qu1queQ Offline
              @liamangelus
              No at this moment. Here there is another user with the same problem:
              https://forum.magicmirror.builders/topic/9386/installing-on-a-pi-zero/52?page=6
              • T Offline
                tjk031
                I would also like to know… How can I downgrade to the old version of electron?
                  sdetweil @tjk031
                  @tjk031 edit the package.json and change the electron version from ^3.0.13 to ^2.0.4
                  then erase node_modules
                  rm -rf node_modules
                  and then
                  npm install
                  again
                  • T Offline
                    tjk031
                    Thanks!!!
                    • qu1queQ Offline
                      Again the same problem when updating to 2.8.0 version
