    Need Help with Remote Control Module
    5 Posts 4 Posters 1.8k Views 3 Watching
    • F Offline
      frankiedux
      Hi guys
      Im new in magic mirrors and im having some problems with the configuration.
      I try to install the remote control module and when i put the module code the magic mirror stop working.
      I install too the weather module MMM-BMW and in this case the module only shows " acquiring your weather"
      Can anyone see where is the error?
      When i do Ctrl + Shift + I in the console tab says that Config File is missing.
      My code:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	//address: "localhost",
      	port: 8080,
      	ipWhitelist: [],
      	//ipWhitelist: [], // Set [] to allow all IP addresses
      	language: "pt",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "8012581",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "xxxxxxx"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "8012581",  //ID from https://openweathermap.org/city
      				appid: "xxxxx"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      disabled: false,
      module: "MMM-BMW-DS",
      position: "bottom_bar",               // bottom_bar is best
          apiKey: "xxxxxxxxxx", // Free API key @ darksky.net
          tempUnits: "c",		              // C of F
          lat: 'YOUR LATITUDE GOES HERE',
          lng: 'YOUR LONGITUDE GOES HERE',
          css: "2", // 1=default, 2=Clean, 3=Lord of the Rings, 4=handwriting, 5=Julee, 6=Englebert, "" = returns default css
          ownTitle: "Current Conditions",   // Use your own language and statement
          playSounds: "yes", // yes = weather sounds, no = no weather sounds
          useHeader: false,
          header: "Your header",
          maxWidth: "100%",
          module: 'MMM-Remote-Control'
          // uncomment the following line to show the URL of the remote control on the mirror
           , position: 'bottom_left'
          // you can hide this module afterwards from the remote control itself
              customCommand: {},  // Optional, See "Using Custom Commands" below
              customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              apiKey: "",         // Optional, See API/README.md for details
      • bheplerB Offline
        bhepler Module Developer
        For starters, please use the markdown features of the board when posting code. You can edit your post to add markdown marks by clicking on the three vertical dots on the lower right of your post.
        Second, are you getting any errors in the console or in the pm2 logs?
        • F Offline
          frankiedux @bhepler
          @bhepler no errors from config:check
            sdetweil @frankiedux
            @frankiedux
            This line is missing a trailing comma
            This should have shone in config:check
            The leading comma is from the prior non comment line (always bad for me to do leading commas)
              Mykle1 Project Sponsor Module Developer @frankiedux
              @frankiedux said in Need Help with Remote Control Module:
              Regarding MMM-BMW-DS
              1. I assume you have an apiKey.
              2. tempUnits: "C", // not lower case
              3. Enter your coordinates for lat and lng
