    Magic mirror install on Ubuntu 16.04
    5 Posts 3 Posters 2.3k Views 3 Watching
    • P
      Preve
      Hi everybody,
      Since 2 day’s I try to install Magic mirror on an clean install Ubuntu 16.04. Also tried the 19.x.
      I keep running in the same problem.
      When doing the “npm install” i got stuck on “extract rxjs@^6.4.0…” It stops there and nothing happens.
      What ever I try to do, I’m alway’s stuck on the “npm install” part.
      Anyone knows what’s going on or is this a known issue?
      M 1 Reply Last reply
      • M
        MadScientist @Preve
        @Preve Hi there!
        The Other day I installed MM on the latest Linux Mint and it worked without any issues. All I did before the npm installwas to run curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash - which was poested by @Mykle1 poested in this post. There were no errors during the installation. Give it a try and report back if that worked for you. :slightly_smiling_face:
        P 1 Reply Last reply
        Reply Quote 1
        • P
          Preve @MadScientist
          @MadScientist
          After the 4’th re-install of the Ubuntu I’ve decided to go with ded.nodesource setup 8.x. Installed that and waited again for some time for a failure. This time I got a good error message regarding some permissions. There was even a commandline suggestuion on how to fix this. Done the required fix and suddenly the install of MM went onwards.
          So yes … now it runs fine. I wanted to test the Globe module and place all our branches on it. That works. Now showing my boss to placed this at the reception desk as an eye-catcher :)
          Now I have some small problems regarding the correct display on MMM Globe module. I can’t get the default pins to go away and only leave the ones I have set in the config file.
          Mykle1M 1 Reply Last reply
          Reply Quote 1
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Preve
            @Preve
            Take a look here sir.
            https://forum.magicmirror.builders/topic/6994/mm-and-ubuntu-made-for-each-other/24
            • P
              Preve @Mykle1
              @Mykle1 pleasse don’t Sir me. That’s not needed :)
              And yes, I have seen that post. One of the reasons why I went for Ubuntu since I had a decent computer for testing.
