    Raspberry Pi 4 Released !
    65 Posts 16 Posters 47.2k Views 13 Watching
      SH20192
      All my modules work except MMM-SingleStock. So far it loads much faster than the Pi 3. I had to abandon using MM2 because I could not run it for more than 3 hours without crashing. Fingers crossed the 4 is more stable. Will let it run overnight to see.
        dazza120 @SH20192
        @SH20192 said in Raspberry Pi 4 Released !:
        Yeah my Pi 3 seems to run out of memory, I opted for 4Gb model should have enough grunt to run everything with any issues
          SH20192 @dazza120
          @dazza120 Pi 4 has been running for 10 hours now and no issues. Had never been able to run the Pi 3 overnight so I think we have a winner!
          Cr4z33C 1 Reply Last reply Reply Quote 2
          • Cr4z33C Offline
            Cr4z33 @SH20192
            @SH20192 are you using any cooling system and if yes what? :)
              SH20192 @Cr4z33
              @Cr4z33 said in Raspberry Pi 4 Released !:
              Yes, a small fan on an open plexiglass case. No heatsink. Without the fan it would complain about overheating.
              Should mention it’s running 4 RTSP streams.
              • lavolp3L Offline
                lavolp3 Module Developer @SH20192
                @SH20192 MM system works without changes on Raspbian Buster with the new kernel?
                I’m positively surprised…
                Gotta order a second one. Lol!
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                D S 2 Replies Last reply Reply Quote 1
                  dazza120 @lavolp3
                  @lavolp3 said in Raspberry Pi 4 Released !:
                  Can I just upgrade the Pi 3 to the Buster OS so i can just swap the ssd over. Can someone confirm if it’s a plug and play boot from OS on an SSD? Rather than through the bios bit to enable it. Really looking forward to this PI I might get a heat sink but I want a big one not the little ones, need to see if I still have the one from the sky box, got a fan already for it but only activates when the TV is on
                    SH20192 @lavolp3
                    Except for the one module mentioned above everything working for me on Buster. Haven’t looked at logs or anything to see if there are errors being thrown that I don’t notice but so far so good.
                    • Cr4z33C Offline
                      Cr4z33 @SH20192
                      @SH20192 I see.
                      I will start with an old Intel heatsink.
                      I got very good cooling results with a Rock Pi 4 B so I don’t think it will be any worse hehe.
                        dazza120 @Cr4z33
                        @SH20192 I see.
                        Would that even fit on the Pi?
                        • 6
                        • 7
                        • 3 / 7
