    Raspberry Pi 4 Released !
    65 Posts 16 Posters 56.7k Views 13 Watching
    • Cr4z33C
      Cr4z33 @lavolp3
      @lavolp3 said in Raspberry Pi 4 Released !:
      @Cr4z33 ho ho, hold on you’re quite fast here with your conclusions.
      What else should one do to deliver the picture via HDMI?
      Have you heard of more people having problems with HDMI adapters and the Pi 4?
      Yes on a Rpi Facebook group.
      It surely might depend also on what adapter you are going to use, but don’t expect 100% guarantee that it will work fine at 4K@60Hz.
      I spent € 7,00 for that crap adapter, sent it back to Amazon and got a proper micro HDMI to HDMI cable certified for 4K for the same amount.
        dazza120 @lavolp3
        @dazza120 I’m afraid a heatsink won’t help much but am curious about your results. I haven’t had good results with heatsinks in the past.
        Only because you haven’t seen my thermal solution lol, this is one seriously hot chip, had it upto 82 for one reading on the stress test but still at 1.5Ghz on the CPU after that reading it dropped to 80degress this is with just the heat sink no fan. 82degress was during my second stress test and that was just one reading the gap between tests was about 30seconds during both tests no CPU throttling happened. I have put a cable tie around the board and heatsink to keep the pressure on it so it transfers good heat. Not the prettiest but behind a tv well it’s not out of place at all. PS the stress test is 100% cpu usage and no let up during the test had task manager up and CPU usage never fell below 💯
        1_1562257847858_883A09A1-4444-452C-92CD-6F401131E452.jpeg 0_1562257847857_177EFE9A-8D8A-4D4B-AD2C-6168ABC1BAC1.jpeg
        PS works fine on HDMI cable no issues at all
        Cr4z33C 1 Reply Last reply
        • Cr4z33C
          Cr4z33 @dazza120
          @dazza120 what heatsink beast is that? :grinning_face_with_smiling_eyes:
          D 1 Reply Last reply
            dazza120 @Cr4z33
            @Cr4z33 said in Raspberry Pi 4 Released !:
            😂 it’s from a HP comp pro 6300 fits the LGA1155 socket, had to grind a bit by the hdmi port to fit the cable but no issues at the back by the pins I put duct tape so it doesn’t get into any trouble back there. Those cheap ally cast heatsinks would have died long time heat pipes in cooling makes a lot of difference
            • Cr4z33C
              Cr4z33 @dazza120
              @dazza120 lol I see.
              I wanted to preorder a Flirc Rpi4 metal case, but shipping is costing TWICE the value of the case…
                dazza120 @Cr4z33
                Flirc case is the same it’s too hard to cool once heated no fins no way for it to shift it once upto temp you get the run away temp where it just keeps rising. My solution has no such issues even though it was like out of one of Linus Tech Tips handbooks lol. I would like to see any other heatsink or case do 20min stress test 😂 and my temp in the house is 26.5c so that’s dam good going
                • Cr4z33C
                  Cr4z33 @dazza120
                  @dazza120 and how did you fix the heatsink to the board?
                    dazza120 @Cr4z33
                    Thermal tape and a cable tie around the board and heat sink as long as the pi isn’t viewable then it doesn’t really matter it is a lot taller with the heat sink though. But at least if you really wanted to you could run this passively, I will have a little fan as well but that works when the tv is on so running the mirror in the background would be all of this heat sink no fan
                    • Cr4z33C
                      Cr4z33 @dazza120
                      @dazza120 oh alright that’s the same solution I used with another board. 👍🏼
                      D 2 Replies Last reply
                        dazza120 @Cr4z33
                        PS you will have to grid down the heat sink by the hdmi cable and the wings to allow it to fully seat the heat sink
                          dazza120 @Cr4z33
                          @Cr4z33 new heat sink now an it sits flush with one thermal pad temp is 78 after two tests back to back better contact with CPU and less thermal transfer material.
                          1_1562344703675_2163EFDF-F069-41AD-BD20-2AEB1DCCE781.jpeg 0_1562344703675_06FD03DB-B390-4522-A0C6-08D566722F1E.jpeg
                          mumblebajM 1 Reply Last reply
                          • mumblebajM
                            mumblebaj Module Developer @dazza120
                            @dazza120 I assume we dont need all that cooling power just to run the mirror? :rolling_on_the_floor_laughing:
                              dazza120 @mumblebaj
                              @mumblebaj said in Raspberry Pi 4 Released !:
                              😂 no but the Pi 4 is a really hot 🥵 CPU where cooling is most defo needed with heat sink it’s 55 at rest, others have reported it at 66 at rest and in a case at 77 heatsink is a must on this one. The second heatsink is more in line and I was able to bed it fully down with one thermal pad. Installing an update ie firmware took over 5mins on full gig and using 60 to 70% CPU that’s a lot of heat seen as my active cooling solution is only active with the TV on for the most part it will be passive, in the UK at the mo we are having a good summer so it’s hot room temp 25 so bigger the better 😝
                                MajorC Project Sponsor
                                I am in the beginning of my first MM project and would like to buy a Pi 4. What RAM would you recommend? Shall I go with the 4GB or is 2 more than enough?
                                Thank you
                                J 1 Reply Last reply
                                  j.e.f.f Project Sponsor Module Developer @MajorC
                                  @MajorC I would just go with the 4GB version as it is not a massive difference in price. Now that the Pi has better graphics we are likely going to see much more capable and sophisticated modules. I’m thinking in particular things like facial recognition can get to the point where it is much more responsive than it is today (not sure if the extra memory helps in this particular scenario, but it’s just one example of many I’m sure).
                                  Given how long it took for the 4 to be released, you’re better off future proofing yourself as much as you can now. It would be a shame to be handcuffed by a relatively inexpensive option you decided not to get.
                                  If you haven’t built a mirror yet, you’ll find that the price of the Pi is one of the least expensive parts of the project. Go with the best available.
                                    MajorC Project Sponsor @j.e.f.f
                                    @j-e-f-f thank you. I found some play-money today and can start the first step now. Buy a Pi and try out the software.
                                    • thedoorsfanaticT
                                      thedoorsfanatic @Guest
                                      @Sean
                                      The price has been reduced for the 2 GB version
                                      https://www.raspberrypi.org/products/raspberry-pi-4-model-b/
                                      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
                                      • 3 / 4
