    disable the header in the Weather Forecast module
    9 Posts 6 Posters 3.9k Views 6 Watching
      brooksa
      Hello,
      Just jot my mirror up and running. Fun.
      I can’t seem to figure out how to disable the header in the Weather Forecast module.
      I feel like it should be simple.
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @brooksa
        @brooksa which weather module and what do you mean by header? do you have a screen shot?
          Mykle1 Project Sponsor Module Developer @brooksa
          @brooksa
          This should work. In custom.css file, add the following:
          .weatherforecast .module-header {
            display: none;
          B J 2 Replies Last reply Reply Quote 1
            brooksa @Mykle1
            @Mykle1 Thank YOU!!!
              jlnxaer @Mykle1
              @Mykle1 Hey,
              this didn’t work for me somehow? Could this be because of preset language? Mine would be German.
                Mykle1 Project Sponsor Module Developer @jlnxaer
                @jlnxaer said in disable the header in the Weather Forecast module:
                No sir. Make sure your custom.css entry is correct and NOT within the body.
                It works
                • F Offline
                  ftap
                  Yeah, doesn’t work for me either. If anyone finds this topic and knows the solution let us know!
                  • C Offline
                    chanster @ftap
                    @ftap Have you tried adding “appendLocationNameToHeader: false” to the config block ?
                                module: "weather",
                                    type: 'forecast',
                                    weatherEndpoint: "/onecall",
                                    apiKey: "***", // your OpenWeatherMap API key
                                    windUnits: "imperial",
                                    updateInterval: 180000,
                                    timeFormat: 12,
                                    showPeriod: true,
                                    showHumidity: true,
                                    degreeLabel: true,
                                    colored: true,
                                    fade: false,
                                    roundTemp: true,
                                    showPrecipitationAmount: true,
                                    appendLocationNameToHeader: false,
                                    lat: ***, // your latitude
                                    lon: ***, // your longitude
                    • F Offline
                      ftap @chanster
                      @chanster Actually just figured out that if I do visibility instead of display it works.
                      .weatherforecast .module-header { visibility: hidden; }
