    Hi very beginners question here.
    6 Posts 3 Posters 1.8k Views 3 Watching
      steveuk
      Hi all.
      I’m very new to magic mirror.
      So I managed to get it running on the basic layout and thought I’d try my first module and with the simple dad jokes one.
      I have the folder showing in the modules folders and then 8 went to the main config.js file to enter the bit of code.
      var config = {
                  module: 'MMM-Dad-Jokes',
                  position: 'bottom_left', // Or wherever you want
                      updateInterval: 60000,
                      fadeSpeed: 4000
      But it’s not working I’m getting a error when loading saying about not having a valid config file.
      I think I’m copying and pasting it in the wrong part or I’m copying too much of it.
      Could someone break it down for me with what I do with the above code on a fresh config file as I’m not actually sure where to do the curser click when I click paste is it after the last closed bracket ?
      Cheers
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @steveuk
        @steveuk it looks good… try running the checker
        npm run check:config
        from the MM folder
        u need all that upper stuff too, right?
          address: "", // Address to listen on, can be:
          port: 8086,
          ipWhitelist: [], // Set [] to allow all IP addresses
          language:  "en",
          timeFormat: 12,
          units: "imperial",
          steveuk @sdetweil
          Hi thanks the reply yeah I have all the upper parts as normal.
          I deleted the file and tried again with a different module following YouTube and got it to work.
          I noticed some of these instructions on the module installation come with extra bits of text I don’t need to copy and paste in, I think I’m confusing myself with when I need the { } and },
          But like I say I did get a module to show up but in the config I put “bottom_right” but it shows on the top left.
          Thanks again.
            sdetweil @steveuk
            @steveuk a module entry will have at LEAST this
                module: 'module_name',
                position: 'some_region_name',
                    // module specific info
            see here for the region definitions
            https://forum.magicmirror.builders/topic/286/regions
              Mykle1 Project Sponsor Module Developer @steveuk
              @steveuk said in Hi very beginners question here.:
              It should look like this. Your entry was missing a comma after the last curly bracket.
                              fadeSpeed: 4000
              This will help you understand the format of a config entry.
              https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                steveuk @Mykle1
                @Mykle1 @sdetweil
                That’s great
                Thanks for the help guys.
