MagicMirror² v2.14.0 is available! For more information about this release, check out this topic.
HDMI/Monitor is switched Off
Hi All, hi @paviro
i recently setup my Mirror and even installed paviro/MMM-PIR-Sensor Module.
actually i wanted my mirror to run permanently.i removed my PIR, changed my config to stop powersaving. but my mirror is still turning off my monitor. i even removed the config for the PIR Sensor completly, same situation.
has anyone an idea what setting could be wrong?
kind regards
Christoph
Hi, have you test the PIR sensor before.
You can try here: https://diyhacking.com/raspberry-pi-gpio-control/
@cpramhofer could it be a screensaver option from raspbian os?
the PIR sensor is not connected anymore…could this be the reason?
screenserver setup is done as in the tutorials described.
