    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 97.9k Views 15 Watching
      Binog
      Just have a look for the noir camera. Have a look for amazon.com. There is an official cam - I think - by the raspberry company. But any other that support the onboard psi cam plug is imho better than usb cam. But that is your decision.
        darbos @emos
        @emos
        I had that same issue. I ended up just creating a few mmm-mogioneye module entries in the config file
          SdeGeata @Binog
          @Binog
          Did you ever get an answer back on this one? I am having the same problem. I see everything fine without autohide active, but if I activate autohide, I see it for a bit during page load and never again after. I get detected motion emails and photo uploads so the detection isn’t the problem. It just doesn’t get fed to the mirror module somehow. Maybe my Web-hook config is off?
          It would be helpful to know if you fixed your issue and how you did it.
            Binog
            Hey, SdeGeata
            No, actually I didn’t
            I circumvented it by setting up a motioneyeos raspberry pi zero. As I needed the larger image on my Magicmirror I used “fast…?” option, which does not provide any of the motion activities,. what was fine to me.
            I do think, this is not merely a problem of motioneye, but of the MM its self.
            With every update of MM the Gap went bigger, I got more problems.
            Now, streaming the motioneyeos to two MMs it is more steady, nonetheless I do habe outages. I don’t see a picture,. although my browser directed to motioneyeos shows an actual one. Restarting MM solves that issue- normally,…
            Good look to You !
              SdeGeata @Binog
              @Binog
              Thanks for the info. I’ll keep trying stuff out and see what happens.
                SdeGeata @Cato
                @Cato
                So how do we use that Webhook URL to trigger the hidden module. I have been screwing with it for days trying to get it to work. Can you clarify the config for that?
                • O Offline
                  OberfragGER @SdeGeata
                  @Cato
                  I really want to use the AutoHide feature. But the stream is fixed and always displayed. Is there any possibility…?
                  		module: "MMM-MotionEye",
                  		position: "bottom_left",
                  			url: "http://pihole:8081",
                  			autoHide: true,
                  			autoHideDelay: "10000",
                  			forcedRefreshInterval: 60000,
                  			width: "400px",
                  			debug: false
                  • O Offline
                    OberfragGER @OberfragGER
                    @oberfragger
                    ok. solved.
                    Somehow it was working after an hour or so.
                    Also- you have to enable access to the mirror via
                    address: “0.0.0.0” and whitelist
                    The the commands http://mirror:8080/motioneye and http://mirror:8080/motioneye/hide are working.
                    • P Offline
                      piwy
                      Bonjour à tous, comme beaucoup apparement, j’ai installé le module motioneye sur mon MM avec ces lignes dans mon fichier “config”:
                      	module: 'MMM-MotionEye',
                      		position: 'bottom_left',
                      		url: "http://monip:8081",
                      		width: 400,
                      		debug: true
                      Mais quand je lance Magic Mirror , j’ai une petite icone avec une image cassée.
                      Lorsque je rentre cette adresse ip :“http://monip:8081”, dans mon navigateur sur mon pc , je tombe sur une page qui me dit : “ce site n’autorise pas la connexion”
                      J’ai essayé de voir si sur motioneye il n’y avait pas des autorisations de connexions a mettre mais je ne vois rien .
                      Infos peut etre importante, motioneye est installer sur docker à travers portainer sur une VM!
                      Merci pour votre aide
                        SdeGeata @piwy
                        @piwy Salut Piwy;
                        Essaye de changer des paramètres dans motion.conf & motioneye.conf. Il ne sont pas accessible de la GUI. Voir avec Terminal; /etc/motioneye/motion.conf et trouve webcontrol_localhost, si c’est “on” change ça pour “off”.
                        En /etc/motioneye/motioneye.conf Change motion_control_localhost true pour motion_control_localhost false .
                        Essaye ça.
                        • 4 / 4
