    Magic Mirror wont start. :(
    11 Posts 6 Posters 10.9k Views 6 Watching
      MQ4
      I am new to Raspberry pi and Magic Mirror. Please help me! What am i doing wrong?
      • T Offline
        tajno
        May you try “npm install electron”?
          MQ4
          so just type “npm install electron”?
            MQ4
            ok. I tried it! but when I try to run “npm start” this is what I get.0_1480481100575_20161129_203750.jpg
              MQ4
              strawberry 3.141S C 2 Replies Last reply Reply Quote 0
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @MQ4
                @MQ4 did you run npm install in the MagicMirror directory? Looks like your missing some dependencies there
                • C Offline
                  chrisyy @MQ4
                  @MQ4
                  Looks like ur missing the module ‘express’. Did u try
                  $ npm install express
                  to install it manually?
                  • L Offline
                    Leotrap
                    I got the same problem… where can i find the express module? Thanks
                    • L Offline
                      Leotrap @chrisyy
                      @chrisyy I got the same problem… where can i find the express module? Thanks
                      reply
                      • bheplerB Offline
                        bhepler Module Developer @Leotrap
                        @Leotrap You shouldn’t have to find it, you just need to run the installation command: npm install express
                        Give it a go and let us know what happens. (be sure to do it from within the ~/MagicMirror folder).
                        @chrisyy Perhaps designating commands using the markdown features would make 'em stand out.
                          MQ4
                          Ok. I figured it out!!! There was a few things I was doing wrong… I found this tutorial and it is EPIC!! https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/3
                          Hope it helps!!
