    Electron Browser outdated?
    25 Posts 7 Posters 11.1k Views 7 Watching
    • rudibaraniR Offline
      rudibarani Project Sponsor
      Dear all,
      I am using this page at night including a module (MMM-SmartWebDisplay from @AgP42) which used to show a livestream from the ISS until the ISS camera payload unfortunately reached its end of live a few weeks ago:
      alt text
      Now I noticed a message in the bottom corner of the livestream, claiming that the browser is outdated.
      The link redirects to this website: https://support.video.ibm.com/hc/en-us/articles/360000403129-Supported-Browsers-for-IBM-Watson-Media
      I am using MagicMirror² v2.8.0, Node v11.6.0 and npm 6.9.0.
      How do I update the electron browser accordingly?
      Thanks for your support!
      S Mykle1M 2 Replies Last reply Reply Quote 0
        sdetweil @rudibarani
        @rudibarani
        MagicMirror 2.8.0 is using Electron 3.0.13, and the latest version is 6.09 (4, 5 and 6 were all released since march of this year)…
        I don’t know Mitch’s plans for version updates… you might open an issue in the MagicMirror github repo.
        • lavolp3L Offline
          lavolp3 Module Developer
          Would be interesting to see what happens if electron 6 gets installed.
          Anybody here ready to give it a try and crash his mirror? :-D
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            Mykle1 Project Sponsor Module Developer @rudibarani
            @rudibarani
            The same happens on my MMM-ISS-Live module. However, in my case, I simply “X” out the message and the module continues to work properly. Yes, you need to be able to click.
            Odd, I just quit MM and relaunched and the message did NOT appear this time. Hmmm.
            1 Reply Last reply Reply Quote -1
              sdetweil
              I downloaded a fresh MagicMirror copy, and changed the electron version to “latest”, in package.json
              And then did npm install
              Default config runs fine
              Will try some other modules
              Pir, hotword, assistantmk2.
              Ubuntu 18.04.2 LTS, Intel,  electron v6.0.10, ok
                 node 8.10.0
                 npm 6.11.3
              Ubuntu 18.04.3 LTS, odroid, electron v6.0.10, ok
                 node 8.10.0
                 npm 6.10.2
                 MMM-PIR-Sensor fails, access denied, exportGPIO, /sys/class/gpio/export
                 MMM-Hotword, V2, ok.
                 MMM_AssistantMk2, ok
              Raspian stretch 9.4, pi V3,  electron v6.0.10, ok
                 node 10.6.0
                 npm, 6.11.3
                sdetweil
                so far, testing looks good… not on pi yet tho
                  @sdetweil pi 3 looks good.
                    Thanks @sdetweil - changing the electron to latest works fine for me on a Mac Mini. I tested all my modules and did not find glitch so far.
                    @MichMich: Is there a special reading why you stick to version 3.0.13?
                    S StoffbeuteluweS 3 Replies Last reply Reply Quote 0
                      @rudibarani cool. can u post the node and npm versions? thanks
                      rudibaraniR 1 Reply Last reply Reply Quote 0
                        rudibarani Project Sponsor @sdetweil
                        @sdetweil: I only updated electron without changing npm and node - so I am still using Node v11.6.0 and npm 6.9.0 on my Mac Mini (24/7 since 2009 :slightly_smiling_face:)
                          @rudibarani just wanting to know what the levels were. Thank you
                          • StoffbeuteluweS Offline
                            Stoffbeuteluwe Project Sponsor @rudibarani
                            @rudibarani how can I update electron?
                              @rudibarani I have a Mac mini
                              • lavolp3L Offline
                                lavolp3 Module Developer @Stoffbeuteluwe
                                @Stoffbeuteluwe go into the MagicMirror home folder and execute
                                npm install electron@latest
                                StoffbeuteluweS 3 Replies Last reply Reply Quote 2
                                • lavolp3L Offline
                                  Testing now electron@6.0.10 on a
                                  Raspberry Pi 4 with
                                  npm@6.10.2 and
                                  node@10.15.2
                                  Will report back as soon as I have something
                                    Stoffbeuteluwe Project Sponsor @lavolp3
                                    @lavolp3 thanks
                                      @lavolp3 works fine on Mac
                                        This post is deleted!
                                          sdetweil
                                          I have submitted change to upgrade to version 6.0.12 on next update
                                          • V Offline
                                            Vauxdvihl
                                            @lavolp3 said in Electron Browser outdated?:
                                            Hi all,
                                            i have updated the electron like above written (because i had the same issue)
                                            After update nothing works
                                            Error code
                                            pi@raspberrypi:~/MagicMirror $ npm start dev
                                            > magicmirror@2.9.0 start /home/pi/MagicMirror
                                            > sh run-start.sh "dev"
                                            /home/pi/MagicMirror/node_modules/electron/index.js:14
                                                throw new Error('Electron failed to install correctly, please delete node_modules/electron and try installing again')
                                            Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
                                                at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)
                                                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)
                                                at Module._compile (internal/modules/cjs/loader.js:778:30)
                                                at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                                at Module.load (internal/modules/cjs/loader.js:653:32)
                                                at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                                at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                                at Module.require (internal/modules/cjs/loader.js:692:17)
                                                at require (internal/modules/cjs/helpers.js:25:18)
                                                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
                                            npm ERR! code ELIFECYCLE
                                            npm ERR! errno 1
                                            npm ERR! magicmirror@2.9.0 start: `sh run-start.sh "dev"`
                                            npm ERR! Exit status 1
                                            npm ERR!
                                            npm ERR! Failed at the magicmirror@2.9.0 start script.
                                            npm ERR!     /home/pi/.npm/_logs/2019-11-22T22_16_40_595Z-debug.log
                                            Can please somebody help me
                                            Thanks a lot
                                            Regards
