    hi, i need your help... tell me, how i do a new modules please
    14 Posts 5 Posters 4.7k Views 5 Watching
    • bjjsoulB Offline
      bjjsoul
      this is a little part the file, config.js… tell me please whats is my wrong.
      i can install all magic mirror, in that is ok
      but i want install, alexa awesome, comand voice and other modules, and i have realy problem… :( thank dude for you help…
         		module: "newsfeed",
         		position: "bottom_bar",
         			feeds: [
         					title: "New York Times",
         			showSourceTitle: true,
         			showPublishDate: true,
         			broadcastNewsFeeds: true,
         			broadcastNewsUpdates: true
         	module: "MMM-Snow",
         	position: "fullscreen_above",
         	config: { // See 'Configuration options' for more information.
         		flakeCount: 100,
         		theme: "winter",
        sdetweil
        please start using the markdown syntax and code blocks around your content…
        i have edited two posts… for clarity
          sdetweil @bjjsoul
          @bjjsoul said in hi, i need your help... tell me, how i do a new modules please:
          Line 100 col 9 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
          so, you have an error, you look to the line PRIOR to the one called out,
          so line 99… and see what is wrong with that… it says some [] group isn’t completed, cause it say } before ]
          all brackets [] and braces {} have to be matched
          • bjjsoulB Offline
            bjjsoul
            mmmm sorry , i dont understand… :( my magic mirror is run perfect , whitout this module0_1570743430371_WhatsApp Image 2019-10-07 at 9.50.47 AM.jpeg
            AND THIS is , file MM-Snow.js
            /* Magic Mirror
             * Module: MMM-Snow
             * MIT Licensed.
             * Comment on terminology: a 'flake' is any moving item being shown on the mirror, while
             * the specific themed items are called 'snow' or 'heart'. This applies to variable names
             * file names and css class names.
            Module.register("MMM-Snow",{
            	defaults: {
            		flakeCount: 100,
            		theme: "winter"                 // pick from themes map below, i.e. winter, love
            	themes: {
            		"winter" : {
            			"flakePrefix"  : "snow",    // prefix of css name, e.g. snow1
            			"imagesCount"  : 3,         // number of images available in this theme, here:  snow1, snow2, snow3
            			"downwards"    : true,      // direction of flake movements, snow goes downwards
            			"sizeFactor"   : 1},        // adapt size of flakes to your liking, use original flake size
            		"love"   : {
            			"flakePrefix" : "heart",    // prefix of css name, e.g. heart1
            			"imagesCount"  : 2,         // number of images in this theme, here:  heart1, heart2
            			"downwards"    : false,     // direction of flake movements, hearts raise upwards
            			"sizeFactor"   : 2},        // adapt size of flakes to your liking, we like bigger hearts
            		"water"   : {
            			"flakePrefix" : "bubble",   // prefix of css name, e.g. bubble1
            			"imagesCount"  : 1,         // number of images in this theme, here:  bubble1
            			"downwards"    : false,     // direction of flake movements, bubbles raise upwards
            			"sizeFactor"   : 2}         // adapt size of flakes to your liking, we like bigger bubbles
            	getStyles: function() {
            		return [ "MMM-Snow.css" ]
            	getDom: function() {
            		var themeSettings = this.themes[this.config.theme];
            		var wrapper = document.createElement("div")
            		wrapper.className = "wrapper"
            		var flake, jiggle, size;
            		for(var i = 0; i < this.config.flakeCount; i++) {
            			size = themeSettings.sizeFactor * (Math.random() * 0.75) + 0.25;
            			flakeImage = document.createElement("div")
            			var flakeSuffix = Math.round(1 + Math.random() * (themeSettings.imagesCount - 1));
            			flakeImage.className = themeSettings.flakePrefix + flakeSuffix;
            			flakeImage.style.transform = "scale(" + size +", " + size + ")";
            			flakeImage.style.opacity = size;
            			flake = document.createElement("div");
            			if(themeSettings.downwards) {
            				flake.className = "flake-downwards";
            			else {
            				flake.className = "flake-upwards"
            			jiggle = document.createElement("div");
            			jiggle.style.animationDelay = (Math.random() * 4) + "s";
            			jiggle.style.animationDuration = ((Math.random() * 30) + 30) + "s";
            			jiggle.appendChild(flakeImage);
            			size = (Math.random() * 0.75) + 0.25;
            			jiggle.style.transform = "scale(" + size +", " + size + ")";
            			jiggle.style.opacity = size;
            			flake.appendChild(jiggle);
            			flake.style.left = ((Math.random() * 100) - 10) + "%";
            			flake.style.animationDelay = (Math.random() * 100) + "s";
            			flake.style.animationDuration = 100 - (Math.random() * 50 * size) + "s";
            			wrapper.appendChild(flake);
            		return wrapper;
              sdetweil @bjjsoul
              @bjjsoul can’t be perfect if you want to add another module
                 	{   < --- start module
                 		module: "newsfeed",
                 		config: {  < ---  start module config
                 			feeds: [  < --- start array of feeds
                 				{ < --- start feed
                 				}  < -- end feed
                 			], < --- end array (only one entry)
                 		} < ----  end module config
                 	}, < --- end module
                 	module: "MMM-Snow",
                 	config: {   < - start module config
                 		flakeCount: 100,
                 		theme: "winter",
                 } < ---- end module , no comma, no more modules to follow
                     },   < ------ what is this??????? -------------------------------
                 ]    < --- no more modules, end module array
              • bjjsoulB Offline
                bjjsoul
                HEY BRO YOU ARE AWESOME … THANK YOU DUDE, I AM VERY HAPPY! IS WORKING … HEY BRO YOU HAVE WHATSAPP THIS MY NUMBER 504 98674031 … I AM GONNA BE NEEDING YOU, IN MY NEXT MODULES INSTALLATIONS… THANKS
                VIDEO
                  sdetweil @bjjsoul
                  @bjjsoul no whatsapp…
                    Mykle1 Project Sponsor Module Developer @bjjsoul
                    @bjjsoul
                    Adding modules
                    https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                    • bjjsoulB Offline
                      bjjsoul
                      hey bro, i need help with mmm.awesomealexa… you know if this module is working
                        ryanroy837
                        thanks all for your responses. i was having similar questions and your answers were helpful to me.
