    hi, i need your help... tell me, how i do a new modules please
    14 Posts 5 Posters 4.9k Views 5 Watching
    • bjjsoulB Offline
      bjjsoul
      hi, i need your help, tell me , how i do to install a new madules please…
      in this moment i am trying to install a module,it is called snow , but i dont know how to insert the code.
      when i run magic mirror it says error
      		module: 'MMM-Snow',
      		position: 'fullscreen_above'
      		config: { // See 'Configuration options' for more information.
      			flakeCount: 100,
      			theme: "winter"
      • buzzkcB Offline
        buzzkc
        It’s missing a comma after the postion: ‘fullscreen_above’
        https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
        Darren
        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
        • buzzkcB Offline
          buzzkc
          Here is additional information on checking your config file that may help…
          https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
          Darren
          • bjjsoulB Offline
            bjjsoul
            in this moment, i am fix the comma, but no work it. now i am check the configuration and see like this…
            Checking file… /home/pi/MagicMirror/config/config.js
            Line 100 col 9 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
            Line 101 col 5 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘]’.
            Line 101 col 6 Missing semicolon.
            Line 101 col 5 Unrecoverable syntax error. (94% scanned).
            • bjjsoulB Offline
              bjjsoul
              this is a little part the file, config.js… tell me please whats is my wrong.
              i can install all magic mirror, in that is ok
              but i want install, alexa awesome, comand voice and other modules, and i have realy problem… :( thank dude for you help…
                 		module: "newsfeed",
                 		position: "bottom_bar",
                 			feeds: [
                 					title: "New York Times",
                 			showSourceTitle: true,
                 			showPublishDate: true,
                 			broadcastNewsFeeds: true,
                 			broadcastNewsUpdates: true
                 	module: "MMM-Snow",
                 	position: "fullscreen_above",
                 		flakeCount: 100,
                 		theme: "winter",
                please start using the markdown syntax and code blocks around your content…
                i have edited two posts… for clarity
                  sdetweil @bjjsoul
                  @bjjsoul said in hi, i need your help... tell me, how i do a new modules please:
                  so, you have an error, you look to the line PRIOR to the one called out,
                  so line 99… and see what is wrong with that… it says some [] group isn’t completed, cause it say } before ]
                  all brackets [] and braces {} have to be matched
                  • bjjsoulB Offline
                    bjjsoul
                    mmmm sorry , i dont understand… :( my magic mirror is run perfect , whitout this module0_1570743430371_WhatsApp Image 2019-10-07 at 9.50.47 AM.jpeg
                    AND THIS is , file MM-Snow.js
                    /* Magic Mirror
                     * Module: MMM-Snow
                     * MIT Licensed.
                     * Comment on terminology: a 'flake' is any moving item being shown on the mirror, while
                     * the specific themed items are called 'snow' or 'heart'. This applies to variable names
                     * file names and css class names.
                    Module.register("MMM-Snow",{
                    	defaults: {
                    		flakeCount: 100,
                    		theme: "winter"                 // pick from themes map below, i.e. winter, love
                    	themes: {
                    		"winter" : {
                    			"flakePrefix"  : "snow",    // prefix of css name, e.g. snow1
                    			"imagesCount"  : 3,         // number of images available in this theme, here:  snow1, snow2, snow3
                    			"downwards"    : true,      // direction of flake movements, snow goes downwards
                    			"sizeFactor"   : 1},        // adapt size of flakes to your liking, use original flake size
                    		"love"   : {
                    			"flakePrefix" : "heart",    // prefix of css name, e.g. heart1
                    			"imagesCount"  : 2,         // number of images in this theme, here:  heart1, heart2
                    			"downwards"    : false,     // direction of flake movements, hearts raise upwards
                    			"sizeFactor"   : 2},        // adapt size of flakes to your liking, we like bigger hearts
                    		"water"   : {
                    			"flakePrefix" : "bubble",   // prefix of css name, e.g. bubble1
                    			"imagesCount"  : 1,         // number of images in this theme, here:  bubble1
                    			"downwards"    : false,     // direction of flake movements, bubbles raise upwards
                    			"sizeFactor"   : 2}         // adapt size of flakes to your liking, we like bigger bubbles
                    	getStyles: function() {
                    		return [ "MMM-Snow.css" ]
                    	getDom: function() {
                    		var themeSettings = this.themes[this.config.theme];
                    		var wrapper = document.createElement("div")
                    		wrapper.className = "wrapper"
                    		var flake, jiggle, size;
                    		for(var i = 0; i < this.config.flakeCount; i++) {
                    			size = themeSettings.sizeFactor * (Math.random() * 0.75) + 0.25;
                    			flakeImage = document.createElement("div")
                    			var flakeSuffix = Math.round(1 + Math.random() * (themeSettings.imagesCount - 1));
                    			flakeImage.className = themeSettings.flakePrefix + flakeSuffix;
                    			flakeImage.style.transform = "scale(" + size +", " + size + ")";
                    			flakeImage.style.opacity = size;
                    			flake = document.createElement("div");
                    			if(themeSettings.downwards) {
                    				flake.className = "flake-downwards";
                    			else {
                    				flake.className = "flake-upwards"
                    			jiggle = document.createElement("div");
                    			jiggle.style.animationDelay = (Math.random() * 4) + "s";
                    			jiggle.style.animationDuration = ((Math.random() * 30) + 30) + "s";
                    			jiggle.appendChild(flakeImage);
                    			size = (Math.random() * 0.75) + 0.25;
                    			jiggle.style.transform = "scale(" + size +", " + size + ")";
                    			jiggle.style.opacity = size;
                    			flake.appendChild(jiggle);
                    			flake.style.left = ((Math.random() * 100) - 10) + "%";
                    			flake.style.animationDelay = (Math.random() * 100) + "s";
                    			flake.style.animationDuration = 100 - (Math.random() * 50 * size) + "s";
                    			wrapper.appendChild(flake);
                    		return wrapper;
                      sdetweil @bjjsoul
                      @bjjsoul can’t be perfect if you want to add another module
                         	{   < --- start module
                         		module: "newsfeed",
                         		config: {  < ---  start module config
                         			feeds: [  < --- start array of feeds
                         				{ < --- start feed
                         				}  < -- end feed
                         			], < --- end array (only one entry)
                         		} < ----  end module config
                         	}, < --- end module
                         	module: "MMM-Snow",
                         	config: {   < - start module config
                         		flakeCount: 100,
                         		theme: "winter",
                         } < ---- end module , no comma, no more modules to follow
                             },   < ------ what is this??????? -------------------------------
                         ]    < --- no more modules, end module array
                      • bjjsoulB Offline
                        bjjsoul
                        HEY BRO YOU ARE AWESOME … THANK YOU DUDE, I AM VERY HAPPY! IS WORKING … HEY BRO YOU HAVE WHATSAPP THIS MY NUMBER 504 98674031 … I AM GONNA BE NEEDING YOU, IN MY NEXT MODULES INSTALLATIONS… THANKS
                        VIDEO
                          sdetweil @bjjsoul
                          @bjjsoul no whatsapp…
                            Mykle1 Project Sponsor Module Developer @bjjsoul
                            @bjjsoul
                            Adding modules
                            • bjjsoulB Offline
                              bjjsoul
                              hey bro, i need help with mmm.awesomealexa… you know if this module is working
                                ryanroy837
                                thanks all for your responses. i was having similar questions and your answers were helpful to me.
