    hi, i need your help... tell me, how i do a new modules please
    14 Posts 5 Posters 5.3k Views 5 Watching
    • buzzkcB Offline
      buzzkc
      It’s missing a comma after the postion: ‘fullscreen_above’
      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
      Darren
      My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
      • buzzkcB Offline
        buzzkc
        Here is additional information on checking your config file that may help…
        https://forum.magicmirror.builders/topic/5399/how-to-check-your-config-for-errors-for-absolute-beginners
        Darren
        • bjjsoulB Offline
          bjjsoul
          in this moment, i am fix the comma, but no work it. now i am check the configuration and see like this…
          Checking file… /home/pi/MagicMirror/config/config.js
          Line 100 col 9 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
          Line 101 col 5 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘]’.
          Line 101 col 6 Missing semicolon.
          Line 101 col 5 Unrecoverable syntax error. (94% scanned).
          • bjjsoulB Offline
            bjjsoul
            this is a little part the file, config.js… tell me please whats is my wrong.
            i can install all magic mirror, in that is ok
            but i want install, alexa awesome, comand voice and other modules, and i have realy problem… :( thank dude for you help…
               		module: "newsfeed",
               		position: "bottom_bar",
               			feeds: [
               					title: "New York Times",
               			showSourceTitle: true,
               			showPublishDate: true,
               			broadcastNewsFeeds: true,
               			broadcastNewsUpdates: true
               	module: "MMM-Snow",
               	position: "fullscreen_above",
               	config: { // See 'Configuration options' for more information.
               		flakeCount: 100,
               		theme: "winter",
              please start using the markdown syntax and code blocks around your content…
              i have edited two posts… for clarity
                sdetweil @bjjsoul
                @bjjsoul said in hi, i need your help... tell me, how i do a new modules please:
                so, you have an error, you look to the line PRIOR to the one called out,
                so line 99… and see what is wrong with that… it says some [] group isn’t completed, cause it say } before ]
                all brackets [] and braces {} have to be matched
                • bjjsoulB Offline
                  bjjsoul
                  mmmm sorry , i dont understand… :( my magic mirror is run perfect , whitout this module0_1570743430371_WhatsApp Image 2019-10-07 at 9.50.47 AM.jpeg
                  AND THIS is , file MM-Snow.js
                  /* Magic Mirror
                   * Module: MMM-Snow
                   * MIT Licensed.
                   * Comment on terminology: a 'flake' is any moving item being shown on the mirror, while
                   * the specific themed items are called 'snow' or 'heart'. This applies to variable names
                   * file names and css class names.
                  Module.register("MMM-Snow",{
                  	defaults: {
                  		flakeCount: 100,
                  		theme: "winter"                 // pick from themes map below, i.e. winter, love
                  	themes: {
                  		"winter" : {
                  			"flakePrefix"  : "snow",    // prefix of css name, e.g. snow1
                  			"imagesCount"  : 3,         // number of images available in this theme, here:  snow1, snow2, snow3
                  			"downwards"    : true,      // direction of flake movements, snow goes downwards
                  			"sizeFactor"   : 1},        // adapt size of flakes to your liking, use original flake size
                  		"love"   : {
                  			"flakePrefix" : "heart",    // prefix of css name, e.g. heart1
                  			"imagesCount"  : 2,         // number of images in this theme, here:  heart1, heart2
                  			"downwards"    : false,     // direction of flake movements, hearts raise upwards
                  			"sizeFactor"   : 2},        // adapt size of flakes to your liking, we like bigger hearts
                  		"water"   : {
                  			"flakePrefix" : "bubble",   // prefix of css name, e.g. bubble1
                  			"imagesCount"  : 1,         // number of images in this theme, here:  bubble1
                  			"downwards"    : false,     // direction of flake movements, bubbles raise upwards
                  			"sizeFactor"   : 2}         // adapt size of flakes to your liking, we like bigger bubbles
                  	getStyles: function() {
                  		return [ "MMM-Snow.css" ]
                  	getDom: function() {
                  		var themeSettings = this.themes[this.config.theme];
                  		var wrapper = document.createElement("div")
                  		wrapper.className = "wrapper"
                  		var flake, jiggle, size;
                  		for(var i = 0; i < this.config.flakeCount; i++) {
                  			size = themeSettings.sizeFactor * (Math.random() * 0.75) + 0.25;
                  			flakeImage = document.createElement("div")
                  			var flakeSuffix = Math.round(1 + Math.random() * (themeSettings.imagesCount - 1));
                  			flakeImage.className = themeSettings.flakePrefix + flakeSuffix;
                  			flakeImage.style.transform = "scale(" + size +", " + size + ")";
                  			flakeImage.style.opacity = size;
                  			flake = document.createElement("div");
                  			if(themeSettings.downwards) {
                  				flake.className = "flake-downwards";
                  			else {
                  				flake.className = "flake-upwards"
                  			jiggle = document.createElement("div");
                  			jiggle.style.animationDelay = (Math.random() * 4) + "s";
                  			jiggle.style.animationDuration = ((Math.random() * 30) + 30) + "s";
                  			jiggle.appendChild(flakeImage);
                  			size = (Math.random() * 0.75) + 0.25;
                  			jiggle.style.transform = "scale(" + size +", " + size + ")";
                  			jiggle.style.opacity = size;
                  			flake.appendChild(jiggle);
                  			flake.style.left = ((Math.random() * 100) - 10) + "%";
                  			flake.style.animationDelay = (Math.random() * 100) + "s";
                  			flake.style.animationDuration = 100 - (Math.random() * 50 * size) + "s";
                  			wrapper.appendChild(flake);
                  		return wrapper;
                    sdetweil @bjjsoul
                    @bjjsoul can’t be perfect if you want to add another module
                       	{   < --- start module
                       		module: "newsfeed",
                       		config: {  < ---  start module config
                       			feeds: [  < --- start array of feeds
                       				{ < --- start feed
                       				}  < -- end feed
                       			], < --- end array (only one entry)
                       		} < ----  end module config
                       	}, < --- end module
                       	module: "MMM-Snow",
                       	config: {   < - start module config
                       		flakeCount: 100,
                       		theme: "winter",
                       } < ---- end module , no comma, no more modules to follow
                           },   < ------ what is this??????? -------------------------------
                       ]    < --- no more modules, end module array
                    • bjjsoulB Offline
                      bjjsoul
                      HEY BRO YOU ARE AWESOME … THANK YOU DUDE, I AM VERY HAPPY! IS WORKING … HEY BRO YOU HAVE WHATSAPP THIS MY NUMBER 504 98674031 … I AM GONNA BE NEEDING YOU, IN MY NEXT MODULES INSTALLATIONS… THANKS
                      VIDEO
                        sdetweil @bjjsoul
                        @bjjsoul no whatsapp…
                          Mykle1 Project Sponsor Module Developer @bjjsoul
                          @bjjsoul
                          Adding modules
                          • bjjsoulB Offline
                            bjjsoul
                            hey bro, i need help with mmm.awesomealexa… you know if this module is working
                              ryanroy837
                              thanks all for your responses. i was having similar questions and your answers were helpful to me.
